Running G-code Ripper from the desktop
27 Apr 2018 14:10 #109711 by Arnell
I'm new to Linux and I am sure I am missing something. I can run G-code ripper from the command prompt via Python but would like to run it by clicking on the icon from the desktop. When I try this the program flashes on the screen quickly and disappears. Any help would be appreciated.
Thank you.
28 Apr 2018 21:52 - 28 Apr 2018 21:54 #109776 by Grotius
Replied by Grotius on topic Running G-code Ripper from the desktop
Hi Arnell,
Hi if you place the tekst "gksudo" in your command line of your starter icon options. The program wil start as admin.
It is called launcher command, for example :
normal command for starting linuxcnc with desktop icon :
linuxcnc /home/grotius/linuxcnc/configs/my-mill/my-mill.ini
admin command to start graphical :
gksudo linuxcnc /home/grotius/linuxcnc/configs/my-mill/my-mill.ini
gksudo is the graphical way, sudo is the command line way.
Last edit: 28 Apr 2018 21:54 by Grotius.
Time to create page: 0.202 seconds
