Interrogating LinuxCNC for realtime information (position, etc.)
30 Apr 2018 23:04 #109875 by ericm
What's the best way to get realtime information about position, velocity, program line number, etc. from LinuxCNC? I want to be able to take this data and send it to another server for display on an operational dashboard. I've been poking around and it seems like there are a ton of ways to do this, but I'm not sure what would be the best. In this case, "best" is a combination of easiest, least likely to break in the future, and that puts the least load on the processor.
Thanks in advance!
02 May 2018 15:03 #110026 by bevins
09 May 2018 11:53 #110423 by andypugh
One very easy way is to ssh in to the LinuxCNC machine and "halcmd loadusr halmeter".
I do that quite often, typically to monitor motion.program-line to see when the machine is finished or waiting for a (manual) tool change.
You can look at any HAL pin this way, and can open mutliple instances of halmeter.
A very similar way would be to create a custom Glade panel with pins that link to the HAL pins of interest, and then to load that in a remote X session on the other machine (halcmd loadusr gladevcp mypanel...).
I think that you could relatively easily have the Glade panel link its own pins, but there is also the option of having it poll linuxnc_stat
linuxcnc.org/docs/2.7/html/config/python...ding_linuxcnc_status
Or your remote widget could send linuxcncrsh commands and parse the return values:
linuxcnc.org/docs/2.7/html/man/man1/linuxcncrsh.1.html
As you say, there are lots of ways to do this. Halmeter is the least work. (because it is no work)
The following user(s) said Thank You: ericm
11 May 2018 02:07 #110557 by ericm
Thanks! That's exactly the info was looking for.
Cheers,
Eric
Time to create page: 0.087 seconds
