Mesa 7I96
8 years 6 months ago #109876 by dbanks
Mesa 7I96 was created by dbanks
What's the easiest way to connect to this board? When selecting from the networking on the home screen it connects, and then proceeds to disconnnect itself. Either that or it just doesn't connect whatsoever, after attempting for a bit. I've read around, and have been unsuccessful in locating a solution.
Obligatory, I'm pretty new to all of this.
  • ozzyrob
  • New Member
  • New Member
8 years 6 months ago #109879 by ozzyrob
Replied by ozzyrob on topic Mesa 7I96
8 years 6 months ago - 8 years 6 months ago #109881 by PCW
Replied by PCW on topic Mesa 7I96
Most initial issues with Mesa Ethernet FPGA cards are network setup related
You need:
1. A dedicated Ethernet port on the host PC
2. This port needs to be setup with a static IP address (IPV4)
Typically the host port will be setup for 192.168.1.1 for a Ethernet FPGA card at IP address 192.168.1.121 or
10.10.10.1 for a Ethernet FPGA card at IP address 10.10.10.10.
10.10.10.10 is usually a better option for the Ethernet FPGA card since it does not overlap existing NAT ranges.
Note that this setup is basic Linux network setup and not specific to LinuxCNC or the Ethernet FPGA cards.
The hm2_eth manual page a a very short description of doing this setup in the etc/network/interfaces
file. You can also use the net manager GUI to set this up.
Last edit: 8 years 6 months ago by PCW.
Time to create page: 0.161 seconds
