Help with XHC-HB04 Wireless Pendant needed
- MDM3D
01 May 2018 03:43 #109884
by MDM3D
Hello, I'm having some trouble getting my XHC-HB04 pendant to work above is the error log that occurs with start-up and I have been able to use the command line to send and receive command to the pendant but best I can tell there is a conflict with a probe pin any help is greatly appreciated. I think that I am almost there. I do have a nice probing page which I added a while ago that may be the part of the problem but would like to keep both the probing tab and the pendant working if possible. Thank you for your time.
Help with XHC-HB04 Wireless Pendant needed was created by MDM3D
Warning: Spoiler!
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.8
Machine configuration directory is '/home/mill/linuxcnc/configs/Mill'
Machine configuration file is 'Mill.ini'
INIFILE=/home/mill/linuxcnc/configs/Mill/Mill.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./Mill.hal
Found file(REL): ./custom.hal
Found file(LIB): /usr/share/linuxcnc/hallib/xhc-hb04.tcl
Killing task linuxcncsvr, PID=10269
xhc-hb04: waiting for XHC-HB04 device
xhc-hb04: found XHC-HB04 device
xhc-hb04: connection lost, cleaning up
Debug file information:
Pin 'motion.probe-input' was already linked to signal 'probe-in'
while executing
"hal net pendant:probe-z <= xhc-hb04.button-probe-z => motion.probe-input"
("eval" body line 1)
invoked from within
"eval hal net $args"
(procedure "net" line 1)
invoked from within
"net pendant:$bname <= $fullbname => $thepin"
(procedure "connect_pins" line 35)
invoked from within
"connect_pins "
(file "/usr/share/linuxcnc/hallib/xhc-hb04.tcl" line 546)
invoked from within
"source $filename"
invoked from within
"set result [source $filename]"
(file "/usr/bin/haltcl" line 55)
10269
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
libusbx: error [do_close] Device handle closed while transfer was still being processed, but the device is still connected as far as we know
libusbx: warning [do_close] A cancellation for an in-flight transfer hasn't completed but closing the device handle
*** Error in `xhc-hb04': free(): corrupted unsorted chunks: 0x0971f938 ***
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009ec00 (usable)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 00000000bfdffc00 (usable)
[ 0.000000] BIOS-e820: 00000000bfdffc00 - 00000000bfe53c00 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000bfe53c00 - 00000000bfe55c00 (ACPI data)
[ 0.000000] BIOS-e820: 00000000bfe55c00 - 00000000c0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000f8000000 - 00000000fc000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fed00400 (reserved)
[ 0.000000] BIOS-e820: 00000000fed20000 - 00000000feda0000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fef00000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved)
[ 0.000000] BIOS-e820: 0000000100000000 - 00000001b8000000 (usable)
[ 0.000000] using polling idle threads.
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.5 present.
[ 0.000000] DMI: Dell Inc. OptiPlex 780 /03NVJ6, BIOS A15 08/06/2013
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0xbfdff max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: write-back
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-D3FFF write-protect
[ 0.000000] D4000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 0BFF00000 mask FFFF00000 uncachable
[ 0.000000] 1 base 0C0000000 mask FC0000000 uncachable
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [c00fe710] fe710
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009a000] 9a000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 3567a000 - 36b35000
[ 0.000000] ACPI: RSDP 000fec00 00024 (v02 DELL )
[ 0.000000] ACPI: XSDT 000fc7f2 00074 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: FACP 000fc922 000F4 (v03 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: DSDT ffea3664 05035 (v01 DELL dt_ex 00001000 INTL 20050624)
[ 0.000000] ACPI: FACS bfdffc00 00040
[ 0.000000] ACPI: SSDT ffea87ba 000AC (v01 DELL st_ex 00001000 INTL 20050624)
[ 0.000000] ACPI: APIC 000fca16 00092 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: BOOT 000fcaa8 00028 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: ASF! 000fcad0 00096 (v32 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: MCFG 000fcb66 0003C (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: HPET 000fcba2 00038 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: TCPA 000fcdfe 00032 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: DMAR 000fce30 000D8 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: SLIC 000fcbda 00176 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 2182MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x000bfdff
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009e
[ 0.000000] 0: 0x00000100 -> 0x000bfdff
[ 0.000000] On node 0 totalpages: 785805
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f3e7a200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3950 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 4365 pages used for memmap
[ 0.000000] HighMem zone: 554228 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x05] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x06] lapic_id[0x01] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x07] lapic_id[0x02] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x08] lapic_id[0x03] disabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high level lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x08] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.000000] SMP: Allowing 8 CPUs, 4 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009e000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at c0000000 (gap: c0000000:38000000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f7763000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 779664
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=2bb7d87b-d5f1-46f6-913c-2b74ef6427fa ro quiet splash idle=poll
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 6287224 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:000bfdff)
[ 0.000000] Memory: 3083996k/3143676k available (3496k kernel code, 59224k reserved, 1237k data, 416k init, 2234372k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc136a04a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc136a04a (3496 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:744 16
[ 0.000000] CPU 0 irqstacks, hard=f6c06000 soft=f6c08000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 2393.957 MHz processor.
[ 0.004003] Calibrating delay loop (skipped), value calculated using timer frequency.. 4787.91 BogoMIPS (lpj=9575828)
[ 0.004007] pid_max: default: 32768 minimum: 301
[ 0.004051] Security Framework initialized
[ 0.004055] AppArmor: AppArmor disabled by boot time parameter
[ 0.004073] Mount-cache hash table entries: 512
[ 0.004281] Initializing cgroup subsys cpuacct
[ 0.004283] Initializing cgroup subsys memory
[ 0.004292] Initializing cgroup subsys devices
[ 0.004294] Initializing cgroup subsys freezer
[ 0.004296] Initializing cgroup subsys net_cls
[ 0.004298] Initializing cgroup subsys blkio
[ 0.004305] Initializing cgroup subsys perf_event
[ 0.004332] CPU: Physical Processor ID: 0
[ 0.004334] CPU: Processor Core ID: 0
[ 0.004336] mce: CPU supports 6 MCE banks
[ 0.004342] CPU0: Thermal monitoring enabled (TM1)
[ 0.004393] ACPI: Core revision 20120320
[ 0.148528] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.148893] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.188585] CPU0: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz stepping 0b
[ 0.192011] Performance Events: PEBS fmt0+, 4-deep LBR, Core2 events, Intel PMU driver.
[ 0.192011] PEBS disabled due to CPU errata.
[ 0.192011] ... version: 2
[ 0.192011] ... bit width: 40
[ 0.192011] ... generic registers: 2
[ 0.192011] ... value mask: 000000ffffffffff
[ 0.192011] ... max period: 000000007fffffff
[ 0.192011] ... fixed-purpose events: 3
[ 0.192011] ... event mask: 0000000700000003
[ 0.200127] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.212028] CPU 1 irqstacks, hard=f6d14000 soft=f6d16000
[ 0.212030] Booting Node 0, Processors #1
[ 0.008000] Initializing CPU#1
[ 0.224041] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.232036] CPU 2 irqstacks, hard=f6d26000 soft=f6d28000
[ 0.232039] #2
[ 0.008000] Initializing CPU#2
[ 0.244033] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.252032] CPU 3 irqstacks, hard=f6d38000 soft=f6d3a000
[ 0.252035] #3
[ 0.008000] Initializing CPU#3
[ 0.264035] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.264067] Brought up 4 CPUs
[ 0.264071] Total of 4 processors activated (19151.65 BogoMIPS).
[ 0.268145] devtmpfs: initialized
[ 0.268235] PM: Registering ACPI NVS region [mem 0xbfdffc00-0xbfe53bff] (344064 bytes)
[ 0.268235] dummy:
[ 0.268248] NET: Registered protocol family 16
[ 0.268378] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.268381] ACPI: bus type pci registered
[ 0.268444] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.268448] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.268450] PCI: Using MMCONFIG for extended config space
[ 0.268452] PCI: Using configuration type 1 for base access
[ 0.268464] dmi type 0xB1 record - unknown flag
[ 0.269029] bio: create slab <bio-0> at 0
[ 0.269029] ACPI: Added _OSI(Module Device)
[ 0.269029] ACPI: Added _OSI(Processor Device)
[ 0.269029] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.269029] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.269199] ACPI: EC: Look up EC in DSDT
[ 0.312221] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
[ 0.352077] ACPI Warning: Incorrect checksum in table [TCPA] - 0x00, should be 0x7F (20120320/tbutils-323)
[ 0.352301] ACPI: Interpreter enabled
[ 0.352310] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.352344] ACPI: Using IOAPIC for interrupt routing
[ 0.523864] ACPI: No dock devices found.
[ 0.523871] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.532380] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.550511] pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7]
[ 0.550511] pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff]
[ 0.550511] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.550511] pci_root PNP0A03:00: host bridge window [mem 0x000c0000-0x000effff]
[ 0.550511] pci_root PNP0A03:00: host bridge window [mem 0x000f0000-0x000fffff]
[ 0.550511] pci_root PNP0A03:00: host bridge window [mem 0xfc000000-0xfec00000]
[ 0.550511] pci_root PNP0A03:00: host bridge window [mem 0xbff00000-0xf7ffffff]
[ 0.550511] pci_root PNP0A03:00: host bridge window [mem 0xff980000-0xff980fff]
[ 0.550511] pci_root PNP0A03:00: host bridge window [mem 0xff97c000-0xff97ffff]
[ 0.550511] pci_root PNP0A03:00: host bridge window [mem 0xff970000-0xff9707ff]
[ 0.550511] pci_root PNP0A03:00: host bridge window [mem 0xfed20000-0xfed9ffff]
[ 0.550511] pci_root PNP0A03:00: host bridge window [mem 0xfeda6000-0xfeda6fff]
[ 0.550511] pci_root PNP0A03:00: host bridge window [mem 0xfeda7000-0xfeda7fff]
[ 0.550511] PCI host bridge to bus 0000:00
[ 0.550511] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
[ 0.550511] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.550511] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.550511] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000effff]
[ 0.550511] pci_bus 0000:00: root bus resource [mem 0x000f0000-0x000fffff]
[ 0.550511] pci_bus 0000:00: root bus resource [mem 0xfc000000-0xfec00000]
[ 0.550511] pci_bus 0000:00: root bus resource [mem 0xbff00000-0xf7ffffff]
[ 0.550511] pci_bus 0000:00: root bus resource [mem 0xff980000-0xff980fff]
[ 0.550511] pci_bus 0000:00: root bus resource [mem 0xff97c000-0xff97ffff]
[ 0.550511] pci_bus 0000:00: root bus resource [mem 0xff970000-0xff9707ff]
[ 0.550511] pci_bus 0000:00: root bus resource [mem 0xfed20000-0xfed9ffff]
[ 0.550511] pci_bus 0000:00: root bus resource [mem 0xfeda6000-0xfeda6fff]
[ 0.550511] pci_bus 0000:00: root bus resource [mem 0xfeda7000-0xfeda7fff]
[ 0.550511] pci 0000:00:00.0: [8086:2e10] type 00 class 0x060000
[ 0.550511] pci 0000:00:01.0: [8086:2e11] type 01 class 0x060400
[ 0.550511] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.550511] pci 0000:00:03.0: [8086:2e14] type 00 class 0x078000
[ 0.550511] pci 0000:00:03.0: reg 10: [mem 0xfeda6000-0xfeda600f 64bit]
[ 0.550511] pci 0000:00:03.0: PME# supported from D0 D3hot D3cold
[ 0.550511] pci 0000:00:03.2: [8086:2e16] type 00 class 0x010185
[ 0.550511] pci 0000:00:03.2: reg 10: [io 0xfe80-0xfe87]
[ 0.550511] pci 0000:00:03.2: reg 14: [io 0xfe90-0xfe93]
[ 0.550511] pci 0000:00:03.2: reg 18: [io 0xfea0-0xfea7]
[ 0.550511] pci 0000:00:03.2: reg 1c: [io 0xfeb0-0xfeb3]
[ 0.550511] pci 0000:00:03.2: reg 20: [io 0xfef0-0xfeff]
[ 0.550511] pci 0000:00:03.3: [8086:2e17] type 00 class 0x070002
[ 0.550511] pci 0000:00:03.3: reg 10: [io 0xecb8-0xecbf]
[ 0.550511] pci 0000:00:03.3: reg 14: [mem 0xf7fd8000-0xf7fd8fff]
[ 0.550511] pci 0000:00:19.0: [8086:10de] type 00 class 0x020000
[ 0.550511] pci 0000:00:19.0: reg 10: [mem 0xf7fe0000-0xf7ffffff]
[ 0.550511] pci 0000:00:19.0: reg 14: [mem 0xf7fd9000-0xf7fd9fff]
[ 0.550511] pci 0000:00:19.0: reg 18: [io 0xece0-0xecff]
[ 0.550511] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
[ 0.550511] pci 0000:00:1a.0: [8086:3a67] type 00 class 0x0c0300
[ 0.550511] pci 0000:00:1a.0: reg 20: [io 0xff20-0xff3f]
[ 0.550511] pci 0000:00:1a.1: [8086:3a68] type 00 class 0x0c0300
[ 0.550511] pci 0000:00:1a.1: reg 20: [io 0xff00-0xff1f]
[ 0.550511] pci 0000:00:1a.2: [8086:3a69] type 00 class 0x0c0300
[ 0.550511] pci 0000:00:1a.2: reg 20: [io 0xfc00-0xfc1f]
[ 0.550511] pci 0000:00:1a.7: [8086:3a6c] type 00 class 0x0c0320
[ 0.550511] pci 0000:00:1a.7: reg 10: [mem 0xf7fda000-0xf7fda3ff]
[ 0.550511] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[ 0.550511] pci 0000:00:1b.0: [8086:3a6e] type 00 class 0x040300
[ 0.550511] pci 0000:00:1b.0: reg 10: [mem 0xf7fdc000-0xf7fdffff 64bit]
[ 0.550511] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.550511] pci 0000:00:1c.0: [8086:3a70] type 01 class 0x060400
[ 0.550511] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.550511] pci 0000:00:1c.1: [8086:3a72] type 01 class 0x060400
[ 0.550511] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.550511] pci 0000:00:1d.0: [8086:3a64] type 00 class 0x0c0300
[ 0.550511] pci 0000:00:1d.0: reg 20: [io 0xff80-0xff9f]
[ 0.550511] pci 0000:00:1d.1: [8086:3a65] type 00 class 0x0c0300
[ 0.550511] pci 0000:00:1d.1: reg 20: [io 0xff60-0xff7f]
[ 0.550511] pci 0000:00:1d.2: [8086:3a66] type 00 class 0x0c0300
[ 0.550511] pci 0000:00:1d.2: reg 20: [io 0xff40-0xff5f]
[ 0.550511] pci 0000:00:1d.7: [8086:3a6a] type 00 class 0x0c0320
[ 0.550511] pci 0000:00:1d.7: reg 10: [mem 0xff980000-0xff9803ff]
[ 0.550511] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.550511] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.550511] pci 0000:00:1f.0: [8086:3a14] type 00 class 0x060100
[ 0.550511] pci 0000:00:1f.2: [8086:3a02] type 00 class 0x010601
[ 0.550511] pci 0000:00:1f.2: reg 10: [io 0xfe00-0xfe07]
[ 0.550511] pci 0000:00:1f.2: reg 14: [io 0xfe10-0xfe13]
[ 0.550511] pci 0000:00:1f.2: reg 18: [io 0xfe20-0xfe27]
[ 0.550511] pci 0000:00:1f.2: reg 1c: [io 0xfe30-0xfe33]
[ 0.550511] pci 0000:00:1f.2: reg 20: [io 0xfec0-0xfedf]
[ 0.550511] pci 0000:00:1f.2: reg 24: [mem 0xff970000-0xff9707ff]
[ 0.550511] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.550511] pci 0000:00:1f.3: [8086:3a60] type 00 class 0x0c0500
[ 0.550511] pci 0000:00:1f.3: reg 10: [mem 0xf7fdb000-0xf7fdb0ff 64bit]
[ 0.550511] pci 0000:00:1f.3: reg 20: [io 0x0980-0x099f]
[ 0.550511] pci 0000:01:00.0: [1002:9498] type 00 class 0x030000
[ 0.550511] pci 0000:01:00.0: reg 10: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.550511] pci 0000:01:00.0: reg 18: [mem 0xf7df0000-0xf7dfffff 64bit]
[ 0.550511] pci 0000:01:00.0: reg 20: [io 0xdc00-0xdcff]
[ 0.550511] pci 0000:01:00.0: reg 30: [mem 0xf7e00000-0xf7e1ffff pref]
[ 0.550511] pci 0000:01:00.0: supports D1 D2
[ 0.550511] pci 0000:01:00.1: [1002:aa38] type 00 class 0x040300
[ 0.550511] pci 0000:01:00.1: reg 10: [mem 0xf7dec000-0xf7deffff 64bit]
[ 0.550511] pci 0000:01:00.1: supports D1 D2
[ 0.550511] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.550511] pci 0000:00:01.0: bridge window [io 0xd000-0xdfff]
[ 0.550511] pci 0000:00:01.0: bridge window [mem 0xf7d00000-0xf7efffff]
[ 0.550511] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.550511] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 0.550511] pci 0000:00:1c.0: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.550511] pci 0000:00:1c.1: PCI bridge to [bus 03-03]
[ 0.550511] pci 0000:00:1c.1: bridge window [mem 0xf7b00000-0xf7bfffff]
[ 0.550545] pci 0000:00:1e.0: PCI bridge to [bus 04-04] (subtractive decode)
[ 0.550556] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.550559] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.550562] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.550565] pci 0000:00:1e.0: bridge window [mem 0x000c0000-0x000effff] (subtractive decode)
[ 0.550567] pci 0000:00:1e.0: bridge window [mem 0x000f0000-0x000fffff] (subtractive decode)
[ 0.550570] pci 0000:00:1e.0: bridge window [mem 0xfc000000-0xfec00000] (subtractive decode)
[ 0.550573] pci 0000:00:1e.0: bridge window [mem 0xbff00000-0xf7ffffff] (subtractive decode)
[ 0.550576] pci 0000:00:1e.0: bridge window [mem 0xff980000-0xff980fff] (subtractive decode)
[ 0.550579] pci 0000:00:1e.0: bridge window [mem 0xff97c000-0xff97ffff] (subtractive decode)
[ 0.550581] pci 0000:00:1e.0: bridge window [mem 0xff970000-0xff9707ff] (subtractive decode)
[ 0.552037] pci 0000:00:1e.0: bridge window [mem 0xfed20000-0xfed9ffff] (subtractive decode)
[ 0.552041] pci 0000:00:1e.0: bridge window [mem 0xfeda6000-0xfeda6fff] (subtractive decode)
[ 0.552044] pci 0000:00:1e.0: bridge window [mem 0xfeda7000-0xfeda7fff] (subtractive decode)
[ 0.552063] pci_bus 0000:00: on NUMA node 0
[ 0.552067] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.553005] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI4._PRT]
[ 0.553511] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI2._PRT]
[ 0.553860] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI3._PRT]
[ 0.554213] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
[ 0.554648] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 4.250297] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 15)
[ 4.251086] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 *5 6 7 9 10 11 12 15)
[ 4.251880] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 *9 10 11 12 15)
[ 4.252958] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[ 4.253747] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[ 4.254533] ACPI: PCI Interrupt Link [LNKF] (IRQs *3 4 5 6 7 9 10 11 12 15)
[ 4.255317] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 6 7 9 10 11 12 15)
[ 4.256115] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[ 4.256360] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 4.256360] vgaarb: loaded
[ 4.256360] vgaarb: bridge control possible 0000:01:00.0
[ 4.256360] PCI: Using ACPI for IRQ routing
[ 4.257781] PCI: pci_cache_line_size set to 64 bytes
[ 4.257872] Expanded resource reserved due to conflict with PCI Bus 0000:00
[ 4.257875] Expanded resource reserved due to conflict with PCI Bus 0000:00
[ 4.257878] reserve RAM buffer: 000000000009ec00 - 000000000009ffff
[ 4.257881] reserve RAM buffer: 00000000bfdffc00 - 00000000bfffffff
[ 4.258026] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 4.258036] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 4.260056] Switching to clocksource hpet
[ 4.260266] pnp: PnP ACPI init
[ 4.260266] ACPI: bus type pnp registered
[ 4.270516] pnp 00:00: [bus 00-ff]
[ 4.270520] pnp 00:00: [io 0x0cf8-0x0cff]
[ 4.270523] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 4.270525] pnp 00:00: [io 0x0d00-0xffff window]
[ 4.270528] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 4.270531] pnp 00:00: [mem 0x000c0000-0x000effff window]
[ 4.270534] pnp 00:00: [mem 0x000f0000-0x000fffff window]
[ 4.270536] pnp 00:00: [mem 0xfc000000-0xfec00000 window]
[ 4.270539] pnp 00:00: [mem 0xbff00000-0xf7ffffff window]
[ 4.270541] pnp 00:00: [mem 0xfc000000-0xefffffff window]
[ 4.270544] pnp 00:00: [mem 0xff980000-0xff980fff window]
[ 4.270547] pnp 00:00: [mem 0xff97c000-0xff97ffff window]
[ 4.270549] pnp 00:00: [mem 0xff970000-0xff9707ff window]
[ 4.270552] pnp 00:00: [mem 0xfed20000-0xfed9ffff window]
[ 4.270555] pnp 00:00: [mem 0xfeda6000-0xfeda6fff window]
[ 4.270557] pnp 00:00: [mem 0xfeda7000-0xfeda7fff window]
[ 4.270599] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active)
[ 4.276254] pnp 00:01: [io 0x0060]
[ 4.276257] pnp 00:01: [io 0x0064]
[ 4.276259] pnp 00:01: [io 0x0062-0x0063]
[ 4.276263] pnp 00:01: [io 0x0065-0x006f]
[ 4.276265] pnp 00:01: [io 0x00e0-0x00ef]
[ 4.276268] pnp 00:01: [io 0x0800-0x085f]
[ 4.276270] pnp 00:01: [io 0x0c00-0x0c7f]
[ 4.276272] pnp 00:01: [io 0x0860-0x08ff]
[ 4.276327] system 00:01: [io 0x0800-0x085f] has been reserved
[ 4.276330] system 00:01: [io 0x0c00-0x0c7f] has been reserved
[ 4.276333] system 00:01: [io 0x0860-0x08ff] has been reserved
[ 4.276337] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 4.276624] pnp 00:02: [io 0x0080-0x009f]
[ 4.276627] pnp 00:02: [io 0x0000-0x001f]
[ 4.276629] pnp 00:02: [io 0x00c0-0x00df]
[ 4.276632] pnp 00:02: [dma 4]
[ 4.276661] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 4.276875] pnp 00:03: [io 0x00f0-0x00ff]
[ 4.276885] pnp 00:03: [irq 13]
[ 4.276916] pnp 00:03: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 4.277120] pnp 00:04: [io 0x0061]
[ 4.277150] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
[ 4.277363] pnp 00:05: [io 0x0070-0x007f]
[ 4.277369] pnp 00:05: [irq 8]
[ 4.277399] pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 4.297728] pnp 00:06: [io 0x0378-0x037f]
[ 4.297731] pnp 00:06: [io 0x0778-0x077f]
[ 4.297736] pnp 00:06: [irq 7]
[ 4.297739] pnp 00:06: [dma 0 disabled]
[ 4.298956] pnp 00:06: Plug and Play ACPI device, IDs PNP0401 (active)
[ 4.305297] pnp 00:07: [io 0x03f8-0x03ff]
[ 4.305304] pnp 00:07: [irq 4]
[ 4.305719] pnp 00:07: Plug and Play ACPI device, IDs PNP0501 (active)
[ 4.331403] pnp 00:08: [mem 0xfed00000-0xfed003ff]
[ 4.331442] pnp 00:08: Plug and Play ACPI device, IDs PNP0103 (active)
[ 4.331450] pnp: PnP ACPI: found 9 devices
[ 4.331452] ACPI: ACPI bus type pnp unregistered
[ 4.331455] PnPBIOS: Disabled by ACPI PNP
[ 4.368097] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 02-02] add_size 1000
[ 4.368101] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02-02] add_size 200000
[ 4.368111] pci 0000:00:1c.1: bridge window [io 0x1000-0x0fff] to [bus 03-03] add_size 1000
[ 4.368114] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03-03] add_size 200000
[ 4.368128] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 4.368131] pci 0000:00:1c.1: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 4.368134] pci 0000:00:1c.0: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 4.368137] pci 0000:00:1c.1: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 4.368142] pci 0000:00:1c.0: BAR 15: assigned [mem 0xfc000000-0xfc1fffff 64bit pref]
[ 4.368146] pci 0000:00:1c.1: BAR 15: assigned [mem 0xfc200000-0xfc3fffff 64bit pref]
[ 4.368150] pci 0000:00:1c.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 4.368153] pci 0000:00:1c.1: BAR 13: assigned [io 0x2000-0x2fff]
[ 4.368157] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 4.368160] pci 0000:00:01.0: bridge window [io 0xd000-0xdfff]
[ 4.368165] pci 0000:00:01.0: bridge window [mem 0xf7d00000-0xf7efffff]
[ 4.368168] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xefffffff 64bit pref]
[ 4.368173] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 4.368177] pci 0000:00:1c.0: bridge window [io 0x1000-0x1fff]
[ 4.368182] pci 0000:00:1c.0: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 4.368187] pci 0000:00:1c.0: bridge window [mem 0xfc000000-0xfc1fffff 64bit pref]
[ 4.368193] pci 0000:00:1c.1: PCI bridge to [bus 03-03]
[ 4.368197] pci 0000:00:1c.1: bridge window [io 0x2000-0x2fff]
[ 4.368202] pci 0000:00:1c.1: bridge window [mem 0xf7b00000-0xf7bfffff]
[ 4.368206] pci 0000:00:1c.1: bridge window [mem 0xfc200000-0xfc3fffff 64bit pref]
[ 4.368213] pci 0000:00:1e.0: PCI bridge to [bus 04-04]
[ 4.368255] pci 0000:00:1e.0: setting latency timer to 64
[ 4.368259] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 4.368262] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 4.368264] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 4.368267] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000effff]
[ 4.368269] pci_bus 0000:00: resource 8 [mem 0x000f0000-0x000fffff]
[ 4.368272] pci_bus 0000:00: resource 9 [mem 0xfc000000-0xfec00000]
[ 4.368275] pci_bus 0000:00: resource 10 [mem 0xbff00000-0xf7ffffff]
[ 4.368277] pci_bus 0000:00: resource 11 [mem 0xff980000-0xff980fff]
[ 4.368280] pci_bus 0000:00: resource 12 [mem 0xff97c000-0xff97ffff]
[ 4.368282] pci_bus 0000:00: resource 13 [mem 0xff970000-0xff9707ff]
[ 4.368285] pci_bus 0000:00: resource 14 [mem 0xfed20000-0xfed9ffff]
[ 4.368287] pci_bus 0000:00: resource 15 [mem 0xfeda6000-0xfeda6fff]
[ 4.368290] pci_bus 0000:00: resource 16 [mem 0xfeda7000-0xfeda7fff]
[ 4.368292] pci_bus 0000:01: resource 0 [io 0xd000-0xdfff]
[ 4.368295] pci_bus 0000:01: resource 1 [mem 0xf7d00000-0xf7efffff]
[ 4.368298] pci_bus 0000:01: resource 2 [mem 0xe0000000-0xefffffff 64bit pref]
[ 4.368301] pci_bus 0000:02: resource 0 [io 0x1000-0x1fff]
[ 4.368303] pci_bus 0000:02: resource 1 [mem 0xf7c00000-0xf7cfffff]
[ 4.368306] pci_bus 0000:02: resource 2 [mem 0xfc000000-0xfc1fffff 64bit pref]
[ 4.368308] pci_bus 0000:03: resource 0 [io 0x2000-0x2fff]
[ 4.368311] pci_bus 0000:03: resource 1 [mem 0xf7b00000-0xf7bfffff]
[ 4.368314] pci_bus 0000:03: resource 2 [mem 0xfc200000-0xfc3fffff 64bit pref]
[ 4.368316] pci_bus 0000:04: resource 4 [io 0x0000-0x0cf7]
[ 4.368319] pci_bus 0000:04: resource 5 [io 0x0d00-0xffff]
[ 4.368322] pci_bus 0000:04: resource 6 [mem 0x000a0000-0x000bffff]
[ 4.368324] pci_bus 0000:04: resource 7 [mem 0x000c0000-0x000effff]
[ 4.368327] pci_bus 0000:04: resource 8 [mem 0x000f0000-0x000fffff]
[ 4.368330] pci_bus 0000:04: resource 9 [mem 0xfc000000-0xfec00000]
[ 4.368332] pci_bus 0000:04: resource 10 [mem 0xbff00000-0xf7ffffff]
[ 4.368335] pci_bus 0000:04: resource 11 [mem 0xff980000-0xff980fff]
[ 4.368338] pci_bus 0000:04: resource 12 [mem 0xff97c000-0xff97ffff]
[ 4.368340] pci_bus 0000:04: resource 13 [mem 0xff970000-0xff9707ff]
[ 4.368343] pci_bus 0000:04: resource 14 [mem 0xfed20000-0xfed9ffff]
[ 4.368346] pci_bus 0000:04: resource 15 [mem 0xfeda6000-0xfeda6fff]
[ 4.368348] pci_bus 0000:04: resource 16 [mem 0xfeda7000-0xfeda7fff]
[ 4.368440] NET: Registered protocol family 2
[ 4.368516] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 4.368704] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 4.368995] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 4.369138] TCP: Hash tables configured (established 131072 bind 65536)
[ 4.369140] TCP: reno registered
[ 4.369143] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 4.369150] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 4.369245] NET: Registered protocol family 1
[ 4.369474] pci 0000:01:00.0: Boot video device
[ 4.369480] PCI: CLS 64 bytes, default 64
[ 4.369525] Unpacking initramfs...
[ 4.795375] Freeing initrd memory: 21228k freed
[ 4.803357] Simple Boot Flag at 0x7a set to 0x1
[ 4.803973] audit: initializing netlink socket (disabled)
[ 4.803995] type=2000 audit(1524952533.796:1): initialized
[ 4.815264] highmem bounce pool size: 64 pages
[ 4.815270] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 4.815490] VFS: Disk quotas dquot_6.5.2
[ 4.815524] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 4.815607] msgmni has been set to 1700
[ 4.815792] alg: No test for stdrng (krng)
[ 4.815826] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 4.815830] io scheduler noop registered
[ 4.815832] io scheduler deadline registered
[ 4.815857] io scheduler cfq registered (default)
[ 4.816128] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 4.816147] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 4.816149] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 4.816747] GHES: HEST is not enabled!
[ 4.816760] isapnp: Scanning for PnP cards...
[ 5.169625] isapnp: No Plug & Play device found
[ 5.169676] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 5.190045] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 5.210692] 00:07: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 5.230880] 0000:00:03.3: ttyS1 at I/O 0xecb8 (irq = 17) is a 16550A
[ 5.231226] Linux agpgart interface v0.103
[ 5.231538] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 5.234444] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 5.234476] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 5.234573] mousedev: PS/2 mouse device common for all mice
[ 5.234619] rtc_cmos 00:05: RTC can wake from S4
[ 5.234732] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 5.234757] rtc0: alarms up to one day, 242 bytes nvram, hpet irqs
[ 5.234883] TCP: cubic registered
[ 5.234955] NET: Registered protocol family 10
[ 5.235202] Mobile IPv6
[ 5.235205] NET: Registered protocol family 17
[ 5.235209] Registering the dns_resolver key type
[ 5.235260] Using IPI No-Shortcut mode
[ 5.235358] PM: Hibernation image not present or could not be loaded.
[ 5.235368] registered taskstats version 1
[ 5.235791] rtc_cmos 00:05: setting system clock to 2018-04-28 21:55:34 UTC (1524952534)
[ 5.235909] Freeing unused kernel memory: 416k freed
[ 5.236119] Write protecting the kernel text: 3500k
[ 5.236145] Write protecting the kernel read-only data: 980k
[ 5.252349] systemd-udevd[68]: starting version 204
[ 5.259649] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 5.259659] ACPI: Power Button [VBTN]
[ 5.259735] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 5.259740] ACPI: Power Button [PWRF]
[ 5.263436] wmi: Mapper loaded
[ 5.265921] [drm] Initialized drm 1.1.0 20060810
[ 5.269779] SCSI subsystem initialized
[ 5.269962] e1000e: Intel(R) PRO/1000 Network Driver - 1.9.5-k
[ 5.269965] e1000e: Copyright(c) 1999 - 2012 Intel Corporation.
[ 5.270011] e1000e 0000:00:19.0: setting latency timer to 64
[ 5.270075] e1000e 0000:00:19.0: (unregistered net_device): Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 5.270588] usbcore: registered new interface driver usbfs
[ 5.270620] usbcore: registered new interface driver hub
[ 5.272575] libata version 3.00 loaded.
[ 5.273096] usbcore: registered new device driver usb
[ 5.274429] uhci_hcd: USB Universal Host Controller Interface driver
[ 5.275932] [drm] radeon defaulting to kernel modesetting.
[ 5.275936] [drm] radeon kernel modesetting enabled.
[ 5.276221] [drm] initializing kernel modesetting (RV730 0x1002:0x9498 0x174B:0xE109).
[ 5.276239] [drm] register mmio base: 0xF7DF0000
[ 5.276242] [drm] register mmio size: 65536
[ 5.276365] ATOM BIOS:
[ 5.276392] radeon 0000:01:00.0: VRAM: 512M 0x0000000000000000 - 0x000000001FFFFFFF (512M used)
[ 5.276398] radeon 0000:01:00.0: GTT: 512M 0x0000000020000000 - 0x000000003FFFFFFF
[ 5.279613] [drm] Detected VRAM RAM=512M, BAR=256M
[ 5.279617] [drm] RAM width 128bits DDR
[ 5.279753] [TTM] Zone kernel: Available graphics memory: 435634 kiB
[ 5.279756] [TTM] Zone highmem: Available graphics memory: 1552820 kiB
[ 5.279759] [TTM] Initializing pool allocator
[ 5.279786] [drm] radeon: 512M of VRAM memory ready
[ 5.279788] [drm] radeon: 512M of GTT memory ready.
[ 5.279811] [drm] GART: num cpu pages 131072, num gpu pages 131072
[ 5.280227] [drm] radeon: ib pool ready.
[ 5.280321] [drm] Loading RV730 Microcode
[ 5.284640] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 5.284643] Warning! ehci_hcd should always be loaded before uhci_hcd and ohci_hcd, not after
[ 5.294203] [drm] PCIE GART of 512M enabled (table at 0x0000000000040000).
[ 5.294242] radeon 0000:01:00.0: WB enabled
[ 5.294245] [drm] fence driver on ring 0 use gpu addr 0x20000c00 and cpu addr 0xff819c00
[ 5.294251] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 5.294253] [drm] Driver supports precise vblank timestamp query.
[ 5.294284] [drm] radeon: irq initialized.
[ 5.340222] [drm] ring test on 0 succeeded in 1 usecs
[ 5.340364] [drm] ib test on ring 0 succeeded in 0 usecs
[ 5.340649] [drm] Radeon Display Connectors
[ 5.340651] [drm] Connector 0:
[ 5.340653] [drm] VGA
[ 5.340656] [drm] DDC: 0x7e20 0x7e20 0x7e24 0x7e24 0x7e28 0x7e28 0x7e2c 0x7e2c
[ 5.340658] [drm] Encoders:
[ 5.340660] [drm] CRT2: INTERNAL_KLDSCP_DAC2
[ 5.340662] [drm] Connector 1:
[ 5.340664] [drm] HDMI-A
[ 5.340665] [drm] HPD2
[ 5.340668] [drm] DDC: 0x7f10 0x7f10 0x7f14 0x7f14 0x7f18 0x7f18 0x7f1c 0x7f1c
[ 5.340670] [drm] Encoders:
[ 5.340672] [drm] DFP2: INTERNAL_UNIPHY1
[ 5.340674] [drm] Connector 2:
[ 5.340676] [drm] DVI-I
[ 5.340678] [drm] HPD1
[ 5.340680] [drm] DDC: 0x7e40 0x7e40 0x7e44 0x7e44 0x7e48 0x7e48 0x7e4c 0x7e4c
[ 5.340682] [drm] Encoders:
[ 5.340683] [drm] CRT1: INTERNAL_KLDSCP_DAC1
[ 5.340685] [drm] DFP1: INTERNAL_UNIPHY
[ 5.340705] [drm] Internal thermal controller with fan control
[ 5.340747] [drm] radeon: power management initialized
[ 5.385761] [drm] fb mappable at 0xE0142000
[ 5.385764] [drm] vram apper at 0xE0000000
[ 5.385766] [drm] size 5242880
[ 5.385767] [drm] fb depth is 24
[ 5.385769] [drm] pitch is 5120
[ 5.385834] fbcon: radeondrmfb (fb0) is primary device
[ 5.464131] e1000e 0000:00:19.0: eth0: (PCI Express:2.5GT/s:Width x1) a4:ba:db:ea:95:9d
[ 5.464135] e1000e 0000:00:19.0: eth0: Intel(R) PRO/1000 Network Connection
[ 5.464180] e1000e 0000:00:19.0: eth0: MAC: 8, PHY: 8, PBA No: 2011FF-0FF
[ 5.464263] ata_generic 0000:00:03.2: setting latency timer to 64
[ 5.464613] scsi0 : ata_generic
[ 5.464740] scsi1 : ata_generic
[ 5.464789] ata1: PATA max UDMA/100 cmd 0xfe80 ctl 0xfe90 bmdma 0xfef0 irq 18
[ 5.464792] ata2: PATA max UDMA/100 cmd 0xfea0 ctl 0xfeb0 bmdma 0xfef8 irq 18
[ 5.464863] uhci_hcd 0000:00:1a.0: setting latency timer to 64
[ 5.464873] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 5.464899] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 5.464927] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000ff20
[ 5.464968] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[ 5.464970] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.464973] usb usb1: Product: UHCI Host Controller
[ 5.464975] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 5.464977] usb usb1: SerialNumber: 0000:00:1a.0
[ 5.465098] hub 1-0:1.0: USB hub found
[ 5.465103] hub 1-0:1.0: 2 ports detected
[ 5.465200] uhci_hcd 0000:00:1a.1: setting latency timer to 64
[ 5.465203] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 5.465212] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 2
[ 5.465247] uhci_hcd 0000:00:1a.1: irq 17, io base 0x0000ff00
[ 5.465284] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 5.465287] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.465289] usb usb2: Product: UHCI Host Controller
[ 5.465291] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 5.465293] usb usb2: SerialNumber: 0000:00:1a.1
[ 5.465405] hub 2-0:1.0: USB hub found
[ 5.465409] hub 2-0:1.0: 2 ports detected
[ 5.465498] uhci_hcd 0000:00:1a.2: setting latency timer to 64
[ 5.465502] uhci_hcd 0000:00:1a.2: UHCI Host Controller
[ 5.465511] uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 3
[ 5.465546] uhci_hcd 0000:00:1a.2: irq 22, io base 0x0000fc00
[ 5.465581] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 5.465585] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.465589] usb usb3: Product: UHCI Host Controller
[ 5.465593] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 5.465595] usb usb3: SerialNumber: 0000:00:1a.2
[ 5.465724] hub 3-0:1.0: USB hub found
[ 5.465730] hub 3-0:1.0: 2 ports detected
[ 5.465817] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 5.465822] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 5.465831] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 4
[ 5.465864] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000ff80
[ 5.465898] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 5.465902] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.465904] usb usb4: Product: UHCI Host Controller
[ 5.465906] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 5.465908] usb usb4: SerialNumber: 0000:00:1d.0
[ 5.466021] hub 4-0:1.0: USB hub found
[ 5.466025] hub 4-0:1.0: 2 ports detected
[ 5.466114] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 5.466118] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 5.466128] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 5
[ 5.466152] uhci_hcd 0000:00:1d.1: irq 17, io base 0x0000ff60
[ 5.466187] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 5.466192] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.466195] usb usb5: Product: UHCI Host Controller
[ 5.466197] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 5.466199] usb usb5: SerialNumber: 0000:00:1d.1
[ 5.466317] hub 5-0:1.0: USB hub found
[ 5.466321] hub 5-0:1.0: 2 ports detected
[ 5.466406] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 5.466409] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 5.466417] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 6
[ 5.466439] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000ff40
[ 5.466471] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 5.466473] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.466475] usb usb6: Product: UHCI Host Controller
[ 5.466477] usb usb6: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 5.466479] usb usb6: SerialNumber: 0000:00:1d.2
[ 5.466591] hub 6-0:1.0: USB hub found
[ 5.466596] hub 6-0:1.0: 2 ports detected
[ 5.466680] ahci 0000:00:1f.2: version 3.0
[ 5.466770] ahci 0000:00:1f.2: AHCI 0001.0200 32 slots 6 ports 3 Gbps 0x27 impl SATA mode
[ 5.466774] ahci 0000:00:1f.2: flags: 64bit ncq sntf led clo pio ems sxs
[ 5.466782] ahci 0000:00:1f.2: setting latency timer to 64
[ 5.488653] scsi2 : ahci
[ 5.488742] scsi3 : ahci
[ 5.488826] scsi4 : ahci
[ 5.488911] scsi5 : ahci
[ 5.488993] scsi6 : ahci
[ 5.489075] scsi7 : ahci
[ 5.489128] ata3: SATA max UDMA/133 abar m2048@0xff970000 port 0xff970100 irq 18
[ 5.489131] ata4: SATA max UDMA/133 abar m2048@0xff970000 port 0xff970180 irq 18
[ 5.489133] ata5: SATA max UDMA/133 abar m2048@0xff970000 port 0xff970200 irq 18
[ 5.489135] ata6: DUMMY
[ 5.489137] ata7: DUMMY
[ 5.489139] ata8: SATA max UDMA/133 abar m2048@0xff970000 port 0xff970380 irq 18
[ 5.489186] ehci_hcd 0000:00:1a.7: setting latency timer to 64
[ 5.489191] ehci_hcd 0000:00:1a.7: EHCI Host Controller
[ 5.489207] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 7
[ 5.489239] ehci_hcd 0000:00:1a.7: debug port 1
[ 5.493131] ehci_hcd 0000:00:1a.7: cache line size of 64 is not supported
[ 5.493137] ehci_hcd 0000:00:1a.7: irq 22, io mem 0xf7fda000
[ 5.504016] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[ 5.504040] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002
[ 5.504042] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.504045] usb usb7: Product: EHCI Host Controller
[ 5.504047] usb usb7: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 5.504049] usb usb7: SerialNumber: 0000:00:1a.7
[ 5.504167] hub 7-0:1.0: USB hub found
[ 5.504173] hub 7-0:1.0: 6 ports detected
[ 5.504281] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 5.504284] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 5.504292] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 8
[ 5.504315] ehci_hcd 0000:00:1d.7: debug port 1
[ 5.508207] ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
[ 5.508212] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xff980000
[ 5.520016] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 5.520034] usb usb8: New USB device found, idVendor=1d6b, idProduct=0002
[ 5.520037] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.520039] usb usb8: Product: EHCI Host Controller
[ 5.520041] usb usb8: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 5.520043] usb usb8: SerialNumber: 0000:00:1d.7
[ 5.520152] hub 8-0:1.0: USB hub found
[ 5.520156] hub 8-0:1.0: 6 ports detected
[ 5.788955] Console: switching to colour frame buffer device 160x64
[ 5.793358] fb0: radeondrmfb frame buffer device
[ 5.793364] drm: registered panic notifier
[ 5.793375] [drm] Initialized radeon 2.16.0 20080528 for 0000:01:00.0 on minor 0
[ 5.800015] Refined TSC clocksource calibration: 2393.999 MHz.
[ 5.800021] Switching to clocksource tsc
[ 5.808020] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 5.808040] ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 5.808058] ata5: SATA link down (SStatus 4 SControl 300)
[ 5.808621] ata3.00: ATA-7: WDC WD2500JS-75NCB1, 10.02E01, max UDMA/133
[ 5.808625] ata3.00: 488281250 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[ 5.809310] ata3.00: configured for UDMA/133
[ 5.809422] scsi 2:0:0:0: Direct-Access ATA WDC WD2500JS-75N 10.0 PQ: 0 ANSI: 5
[ 5.816024] ata8: SATA link down (SStatus 0 SControl 300)
[ 5.831382] ata4.00: ATAPI: TSSTcorp DVD+/-RW TS-L633C, DW40, max UDMA/100
[ 5.831385] ata4.00: applying bridge limits
[ 5.851587] ata4.00: configured for UDMA/100
[ 5.854497] scsi 3:0:0:0: CD-ROM TSSTcorp DVD+-RW TS-L633C DW40 PQ: 0 ANSI: 5
[ 5.868989] sd 2:0:0:0: [sda] 488281250 512-byte logical blocks: (250 GB/232 GiB)
[ 5.869059] sd 2:0:0:0: [sda] Write Protect is off
[ 5.869065] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 5.869094] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 5.873022] sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 5.873027] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 5.873171] sr 3:0:0:0: Attached scsi CD-ROM sr0
[ 5.893273] sda: sda1 sda2 sda3 < sda5 >
[ 5.893611] sd 2:0:0:0: [sda] Attached SCSI disk
[ 5.928019] usb 8-4: new high-speed USB device number 3 using ehci_hcd
[ 6.119011] usb 8-4: New USB device found, idVendor=0644, idProduct=0200
[ 6.119015] usb 8-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6.119018] usb 8-4: Product: CA-200
[ 6.119020] usb 8-4: Manufacturer: TEAC
[ 6.119022] usb 8-4: SerialNumber: 000004239BB8
[ 6.120365] Initializing USB Mass Storage driver...
[ 6.120475] scsi8 : usb-storage 8-4:1.0
[ 6.120551] usbcore: registered new interface driver usb-storage
[ 6.120554] USB Mass Storage support registered.
[ 6.348124] device-mapper: uevent: version 1.0.3
[ 6.348201] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: This email address is being protected from spambots. You need JavaScript enabled to view it.
[ 6.443483] kjournald starting. Commit interval 5 seconds
[ 6.443503] EXT3-fs (sda5): mounted filesystem with ordered data mode
[ 6.468023] usb 1-2: new low-speed USB device number 2 using uhci_hcd
[ 6.644969] usb 1-2: New USB device found, idVendor=413c, idProduct=2107
[ 6.644973] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.644976] usb 1-2: Product: Dell USB Entry Keyboard
[ 6.644978] usb 1-2: Manufacturer: DELL
[ 6.888016] usb 4-1: new low-speed USB device number 2 using uhci_hcd
[ 7.070903] usb 4-1: New USB device found, idVendor=045e, idProduct=0047
[ 7.070906] usb 4-1: New USB device strings: Mfr=1, Product=3, SerialNumber=0
[ 7.070909] usb 4-1: Product: Microsoft 5-Button Mouse with IntelliEye(TM)
[ 7.070912] usb 4-1: Manufacturer: Microsoft
[ 7.130281] scsi 8:0:0:0: Direct-Access TEAC USB HS-CF Card 4.12 PQ: 0 ANSI: 0
[ 7.133900] scsi 8:0:0:1: Direct-Access TEAC USB HS-xD/SM 4.12 PQ: 0 ANSI: 0
[ 7.137399] scsi 8:0:0:2: Direct-Access TEAC USB HS-MS Card 4.12 PQ: 0 ANSI: 0
[ 7.140784] scsi 8:0:0:3: Direct-Access TEAC USB HS-SD Card 4.12 PQ: 0 ANSI: 0
[ 7.179769] sd 8:0:0:0: [sdb] Attached SCSI removable disk
[ 7.184767] sd 8:0:0:1: [sdc] Attached SCSI removable disk
[ 7.189268] sd 8:0:0:2: [sdd] Attached SCSI removable disk
[ 7.193267] sd 8:0:0:3: [sde] Attached SCSI removable disk
[ 7.312016] usb 6-1: new full-speed USB device number 2 using uhci_hcd
[ 7.465476] usb 6-1: New USB device found, idVendor=10ce, idProduct=eb70
[ 7.465479] usb 6-1: New USB device strings: Mfr=1, Product=0, SerialNumber=0
[ 7.465482] usb 6-1: Manufacturer: KTURT.LTD
[ 7.971850] init: ureadahead main process (211) terminated with status 5
[ 9.676915] EXT3-fs (sda5): using internal journal
[ 10.538810] systemd-udevd[340]: starting version 204
[ 11.580214] lp: driver loaded but no devices found
[ 12.155568] ppdev: user-space parallel port driver
[ 12.369689] parport_pc 00:06: reported by Plug and Play ACPI
[ 12.369742] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[ 12.464122] lp0: using parport0 (interrupt-driven).
[ 12.534119] fuse init (API version 7.18)
[ 12.986748] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 13.408396] microcode: CPU0 sig=0x6fb, pf=0x10, revision=0xba
[ 13.560383] device-mapper: multipath: version 1.3.0 loaded
[ 13.842473] coretemp coretemp.0: Using relative temperature scale!
[ 13.842981] coretemp coretemp.0: Using relative temperature scale!
[ 13.842993] coretemp coretemp.0: Using relative temperature scale!
[ 13.843003] coretemp coretemp.0: Using relative temperature scale!
[ 13.917812] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 14.128269] input: Dell WMI hotkeys as /devices/virtual/input/input2
[ 14.414336] init: cups main process (446) killed by HUP signal
[ 14.414349] init: cups main process ended, respawning
[ 14.669584] microcode: CPU1 sig=0x6fb, pf=0x10, revision=0xba
[ 14.675768] microcode: CPU2 sig=0x6fb, pf=0x10, revision=0xba
[ 14.676559] microcode: CPU3 sig=0x6fb, pf=0x10, revision=0xba
[ 14.677318] microcode: Microcode Update Driver: v2.00 <This email address is being protected from spambots. You need JavaScript enabled to view it.>, Peter Oruba
[ 15.685319] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input3
[ 15.833277] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input4
[ 16.190897] Bluetooth: Core ver 2.16
[ 16.190918] NET: Registered protocol family 31
[ 16.190921] Bluetooth: HCI device and connection manager initialized
[ 16.190925] Bluetooth: HCI socket layer initialized
[ 16.190929] Bluetooth: L2CAP socket layer initialized
[ 16.190936] Bluetooth: SCO socket layer initialized
[ 16.222604] Bluetooth: RFCOMM TTY layer initialized
[ 16.222613] Bluetooth: RFCOMM socket layer initialized
[ 16.222616] Bluetooth: RFCOMM ver 1.11
[ 17.026606] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 17.026609] Bluetooth: BNEP filters: protocol multicast
[ 18.275490] input: DELL Dell USB Entry Keyboard as /devices/pci0000:00/0000:00:1a.0/usb1/1-2/1-2:1.0/input/input5
[ 18.275741] generic-usb 0003:413C:2107.0001: input,hidraw0: USB HID v1.11 Keyboard [DELL Dell USB Entry Keyboard] on usb-0000:00:1a.0-2/input0
[ 18.290402] input: Microsoft Microsoft 5-Button Mouse with IntelliEye(TM) as /devices/pci0000:00/0000:00:1d.0/usb4/4-1/4-1:1.0/input/input6
[ 18.290548] generic-usb 0003:045E:0047.0002: input,hidraw1: USB HID v1.10 Mouse [Microsoft Microsoft 5-Button Mouse with IntelliEye(TM)] on usb-0000:00:1d.0-1/input0
[ 18.295795] generic-usb 0003:10CE:EB70.0003: hiddev0,hidraw2: USB HID v1.10 Device [KTURT.LTD] on usb-0000:00:1d.2-1/input0
[ 18.295819] usbcore: registered new interface driver usbhid
[ 18.295821] usbhid: USB HID core driver
[ 18.684674] init: failsafe main process (550) killed by TERM signal
[ 27.575182] init: samba-ad-dc main process (796) terminated with status 1
[ 28.414329] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 29.988860] e1000e: eth0 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[ 29.988866] e1000e 0000:00:19.0: eth0: 10/100 speed: disabling TSO
[ 29.988974] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 33.270985] init: plymouth-upstart-bridge main process ended, respawning
[ 41.024007] eth0: no IPv6 routers present
[ 42.924733] vboxdrv: Found 4 processor cores
[ 42.924948] vboxdrv: fAsync=0 offMin=0x2f4 offMax=0x1bab
[ 43.025024] vboxdrv: TSC mode is Synchronous, tentative frequency 2393998778 Hz
[ 43.025027] vboxdrv: Successfully loaded version 5.0.2 (interface 0x00230003)
[ 43.348892] VBoxNetFlt: Successfully started.
[ 43.463493] VBoxNetAdp: Successfully started.
[ 43.590234] VBoxPciLinuxInit
[ 43.604495] vboxpci: IOMMU not found (not compiled)
[ 45.825538] init: plymouth-stop pre-start process (2028) terminated with status 1
[ 141.323243] I-pipe: head domain RTAI registered.
[ 141.323250] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 141.323349] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 141.323353] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2393957000, CPU_FREQ 2393957000
[ 141.323357] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 141.323361] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 7717750
[ 141.413578] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 141.413616] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 141.413621] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[ 141.413624] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2393957000 hz.
[ 141.413627] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 141.464465] RTAI[math]: loaded.
[ 141.782631] config string '0x378 out'
[ 1476.697694] spurious APIC interrupt on CPU#0, should never happen.
[ 1476.697702] spurious APIC interrupt on CPU#3, should never happen.
[ 1476.701223] RTAI[math]: unloaded.
[ 1476.702956] SCHED releases registered named ALIEN PEDV$D
[ 1476.705784] RTAI[malloc]: unloaded.
[ 1476.804012] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1476.805894] I-pipe: head domain RTAI unregistered.
[ 1476.805999] RTAI[hal]: unmounted.
[ 3903.573023] I-pipe: head domain RTAI registered.
[ 3903.573028] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 3903.573138] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3903.573142] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2393957000, CPU_FREQ 2393957000
[ 3903.573146] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3903.573151] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 12099250
[ 3903.580027] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3903.580076] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3903.580083] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[ 3903.580089] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2393957000 hz.
[ 3903.580092] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 3903.589350] RTAI[math]: loaded.
[ 3903.741411] config string '0x378 out'
[ 3938.982424] RTAI[math]: unloaded.
[ 3938.984168] SCHED releases registered named ALIEN PEDV$D
[ 3938.987041] RTAI[malloc]: unloaded.
[ 3939.084023] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3939.085830] I-pipe: head domain RTAI unregistered.
[ 3939.085938] RTAI[hal]: unmounted.
[ 5180.314772] I-pipe: head domain RTAI registered.
[ 5180.314778] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 5180.314876] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 5180.314881] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2393957000, CPU_FREQ 2393957000
[ 5180.314884] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 5180.314889] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 6302750
[ 5180.321734] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 5180.321771] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 5180.321776] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[ 5180.321779] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2393957000 hz.
[ 5180.321782] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 5180.328052] RTAI[math]: loaded.
[ 5180.480708] config string '0x378 out'
[ 5644.833054] RTAI[math]: unloaded.
[ 5644.834705] SCHED releases registered named ALIEN PEDV$D
[ 5644.841959] RTAI[malloc]: unloaded.
[ 5644.940016] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 5644.943370] I-pipe: head domain RTAI unregistered.
[ 5644.943486] RTAI[hal]: unmounted.
[ 6413.523542] I-pipe: head domain RTAI registered.
[ 6413.523547] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 6413.523654] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 6413.523657] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2393957000, CPU_FREQ 2393957000
[ 6413.523660] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 6413.523664] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 7148500
[ 6413.530472] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 6413.530510] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 6413.530515] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[ 6413.530518] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2393957000 hz.
[ 6413.530522] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 6413.542140] RTAI[math]: loaded.
[ 6413.593101] config string '0x378 out'
[ 6416.131324] RTAI[math]: unloaded.
[ 6416.132961] SCHED releases registered named ALIEN PEDV$D
[ 6416.145518] RTAI[malloc]: unloaded.
[ 6416.244011] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 6416.245847] I-pipe: head domain RTAI unregistered.
[ 6416.245956] RTAI[hal]: unmounted.
[ 6832.633925] I-pipe: head domain RTAI registered.
[ 6832.633931] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 6832.634033] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 6832.634038] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2393957000, CPU_FREQ 2393957000
[ 6832.634041] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 6832.634045] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 16371750
[ 6832.640880] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 6832.640925] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 6832.640930] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[ 6832.640933] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2393957000 hz.
[ 6832.640935] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 6832.651828] RTAI[math]: loaded.
[ 6832.803807] config string '0x378 out'
[ 6835.228106] RTAI[math]: unloaded.
[ 6835.229799] SCHED releases registered named ALIEN PEDV$D
[ 6835.239392] RTAI[malloc]: unloaded.
[ 6835.336011] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 6835.337779] I-pipe: head domain RTAI unregistered.
[ 6835.337886] RTAI[hal]: unmounted.
[ 8077.963262] I-pipe: head domain RTAI registered.
[ 8077.963268] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 8077.963367] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 8077.963371] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2393957000, CPU_FREQ 2393957000
[ 8077.963375] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 8077.963379] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 15102750
[ 8077.970836] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 8077.970882] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 8077.970887] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[ 8077.970890] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2393957000 hz.
[ 8077.970893] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 8077.981612] RTAI[math]: loaded.
[ 8078.136085] config string '0x378 out'
[ 8080.629758] RTAI[math]: unloaded.
[ 8080.631880] SCHED releases registered named ALIEN PEDV$D
[ 8080.637602] RTAI[malloc]: unloaded.
[ 8080.736018] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 8080.737943] I-pipe: head domain RTAI unregistered.
[ 8080.738047] RTAI[hal]: unmounted.
[165933.032357] I-pipe: head domain RTAI registered.
[165933.032365] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[165933.032467] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[165933.032472] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2393957000, CPU_FREQ 2393957000
[165933.032475] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[165933.032479] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 16580500
[165933.039329] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[165933.039372] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[165933.039378] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[165933.039383] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2393957000 hz.
[165933.039386] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[165933.049361] RTAI[math]: loaded.
[165933.105823] config string '0x378 out'
[165935.607317] RTAI[math]: unloaded.
[165935.609105] SCHED releases registered named ALIEN PEDV$D
[165935.612605] RTAI[malloc]: unloaded.
[165935.712016] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[165935.713895] I-pipe: head domain RTAI unregistered.
[165935.714004] RTAI[hal]: unmounted.
[165993.166729] I-pipe: head domain RTAI registered.
[165993.166737] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[165993.166839] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[165993.166843] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2393957000, CPU_FREQ 2393957000
[165993.166846] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[165993.166850] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 15702250
[165993.173816] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[165993.173858] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[165993.173869] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[165993.173872] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2393957000 hz.
[165993.173875] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[165993.180869] RTAI[math]: loaded.
[165993.331620] config string '0x378 out'
[165995.793757] spurious APIC interrupt on CPU#1, should never happen.
[165995.797575] RTAI[math]: unloaded.
[165995.799343] SCHED releases registered named ALIEN PEDV$D
[165995.819374] RTAI[malloc]: unloaded.
[165995.916015] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[165995.917843] I-pipe: head domain RTAI unregistered.
[165995.917947] RTAI[hal]: unmounted.
[167668.132755] I-pipe: head domain RTAI registered.
[167668.132760] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[167668.132867] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[167668.132872] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2393957000, CPU_FREQ 2393957000
[167668.132877] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[167668.132881] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 16592750
[167668.139560] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[167668.139598] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[167668.139602] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[167668.139606] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2393957000 hz.
[167668.139608] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[167668.150455] RTAI[math]: loaded.
[167668.201408] config string '0x378 out'
[167670.696223] RTAI[math]: unloaded.
[167670.697953] SCHED releases registered named ALIEN PEDV$D
[167670.700855] RTAI[malloc]: unloaded.
[167670.800018] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[167670.801867] I-pipe: head domain RTAI unregistered.
[167670.801992] RTAI[hal]: unmounted.
[169126.795391] I-pipe: head domain RTAI registered.
[169126.795397] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[169126.795501] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[169126.795505] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2393957000, CPU_FREQ 2393957000
[169126.795508] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[169126.795511] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 16361250
[169126.802785] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[169126.802823] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[169126.802827] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[169126.802831] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2393957000 hz.
[169126.802833] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[169126.815871] RTAI[math]: loaded.
[169126.866608] config string '0x378 out'
[169129.347094] RTAI[math]: unloaded.
[169129.349402] SCHED releases registered named ALIEN PEDV$D
[169129.360741] RTAI[malloc]: unloaded.
[169129.460011] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[169129.461749] I-pipe: head domain RTAI unregistered.
[169129.461857] RTAI[hal]: unmounted.
[169607.759603] I-pipe: head domain RTAI registered.
[169607.759608] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[169607.759718] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[169607.759721] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2393957000, CPU_FREQ 2393957000
[169607.759724] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[169607.759727] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 16055000
[169607.766524] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[169607.766560] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[169607.766565] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[169607.766569] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2393957000 hz.
[169607.766572] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[169607.771185] RTAI[math]: loaded.
[169607.936076] config string '0x378 out'
[169610.418957] RTAI[math]: unloaded.
[169610.420729] SCHED releases registered named ALIEN PEDV$D
[169610.432518] RTAI[malloc]: unloaded.
[169610.532011] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[169610.533858] I-pipe: head domain RTAI unregistered.
[169610.533962] RTAI[hal]: unmounted.
[178132.047503] I-pipe: head domain RTAI registered.
[178132.047508] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[178132.047608] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[178132.047612] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2393957000, CPU_FREQ 2393957000
[178132.047615] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[178132.047618] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 16437500
[178132.054439] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[178132.054474] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[178132.054479] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[178132.054482] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2393957000 hz.
[178132.054484] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[178132.060065] RTAI[math]: loaded.
[178132.213793] config string '0x378 out'
[178134.701173] RTAI[math]: unloaded.
[178134.702922] SCHED releases registered named ALIEN PEDV$D
[178134.706118] RTAI[malloc]: unloaded.
[178134.804011] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[178134.805808] I-pipe: head domain RTAI unregistered.
[178134.805917] RTAI[hal]: unmounted.
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.8
Machine configuration directory is '/home/mill/linuxcnc/configs/Mill'
Machine configuration file is 'Mill.ini'
INIFILE=/home/mill/linuxcnc/configs/Mill/Mill.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./Mill.hal
Found file(REL): ./custom.hal
Found file(LIB): /usr/share/linuxcnc/hallib/xhc-hb04.tcl
Killing task linuxcncsvr, PID=10269
xhc-hb04: waiting for XHC-HB04 device
xhc-hb04: found XHC-HB04 device
xhc-hb04: connection lost, cleaning up
Debug file information:
Pin 'motion.probe-input' was already linked to signal 'probe-in'
while executing
"hal net pendant:probe-z <= xhc-hb04.button-probe-z => motion.probe-input"
("eval" body line 1)
invoked from within
"eval hal net $args"
(procedure "net" line 1)
invoked from within
"net pendant:$bname <= $fullbname => $thepin"
(procedure "connect_pins" line 35)
invoked from within
"connect_pins "
(file "/usr/share/linuxcnc/hallib/xhc-hb04.tcl" line 546)
invoked from within
"source $filename"
invoked from within
"set result [source $filename]"
(file "/usr/bin/haltcl" line 55)
10269
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
libusbx: error [do_close] Device handle closed while transfer was still being processed, but the device is still connected as far as we know
libusbx: warning [do_close] A cancellation for an in-flight transfer hasn't completed but closing the device handle
*** Error in `xhc-hb04': free(): corrupted unsorted chunks: 0x0971f938 ***
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009ec00 (usable)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 00000000bfdffc00 (usable)
[ 0.000000] BIOS-e820: 00000000bfdffc00 - 00000000bfe53c00 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000bfe53c00 - 00000000bfe55c00 (ACPI data)
[ 0.000000] BIOS-e820: 00000000bfe55c00 - 00000000c0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000f8000000 - 00000000fc000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fed00400 (reserved)
[ 0.000000] BIOS-e820: 00000000fed20000 - 00000000feda0000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fef00000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved)
[ 0.000000] BIOS-e820: 0000000100000000 - 00000001b8000000 (usable)
[ 0.000000] using polling idle threads.
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.5 present.
[ 0.000000] DMI: Dell Inc. OptiPlex 780 /03NVJ6, BIOS A15 08/06/2013
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0xbfdff max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: write-back
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-D3FFF write-protect
[ 0.000000] D4000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 0BFF00000 mask FFFF00000 uncachable
[ 0.000000] 1 base 0C0000000 mask FC0000000 uncachable
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [c00fe710] fe710
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009a000] 9a000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 3567a000 - 36b35000
[ 0.000000] ACPI: RSDP 000fec00 00024 (v02 DELL )
[ 0.000000] ACPI: XSDT 000fc7f2 00074 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: FACP 000fc922 000F4 (v03 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: DSDT ffea3664 05035 (v01 DELL dt_ex 00001000 INTL 20050624)
[ 0.000000] ACPI: FACS bfdffc00 00040
[ 0.000000] ACPI: SSDT ffea87ba 000AC (v01 DELL st_ex 00001000 INTL 20050624)
[ 0.000000] ACPI: APIC 000fca16 00092 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: BOOT 000fcaa8 00028 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: ASF! 000fcad0 00096 (v32 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: MCFG 000fcb66 0003C (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: HPET 000fcba2 00038 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: TCPA 000fcdfe 00032 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: DMAR 000fce30 000D8 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: SLIC 000fcbda 00176 (v01 DELL B10K 00000015 ASL 00000061)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 2182MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x000bfdff
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009e
[ 0.000000] 0: 0x00000100 -> 0x000bfdff
[ 0.000000] On node 0 totalpages: 785805
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f3e7a200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3950 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 4365 pages used for memmap
[ 0.000000] HighMem zone: 554228 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x05] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x06] lapic_id[0x01] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x07] lapic_id[0x02] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x08] lapic_id[0x03] disabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high level lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x08] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.000000] SMP: Allowing 8 CPUs, 4 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009e000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at c0000000 (gap: c0000000:38000000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f7763000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 779664
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=2bb7d87b-d5f1-46f6-913c-2b74ef6427fa ro quiet splash idle=poll
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 6287224 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:000bfdff)
[ 0.000000] Memory: 3083996k/3143676k available (3496k kernel code, 59224k reserved, 1237k data, 416k init, 2234372k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc136a04a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc136a04a (3496 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:744 16
[ 0.000000] CPU 0 irqstacks, hard=f6c06000 soft=f6c08000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 2393.957 MHz processor.
[ 0.004003] Calibrating delay loop (skipped), value calculated using timer frequency.. 4787.91 BogoMIPS (lpj=9575828)
[ 0.004007] pid_max: default: 32768 minimum: 301
[ 0.004051] Security Framework initialized
[ 0.004055] AppArmor: AppArmor disabled by boot time parameter
[ 0.004073] Mount-cache hash table entries: 512
[ 0.004281] Initializing cgroup subsys cpuacct
[ 0.004283] Initializing cgroup subsys memory
[ 0.004292] Initializing cgroup subsys devices
[ 0.004294] Initializing cgroup subsys freezer
[ 0.004296] Initializing cgroup subsys net_cls
[ 0.004298] Initializing cgroup subsys blkio
[ 0.004305] Initializing cgroup subsys perf_event
[ 0.004332] CPU: Physical Processor ID: 0
[ 0.004334] CPU: Processor Core ID: 0
[ 0.004336] mce: CPU supports 6 MCE banks
[ 0.004342] CPU0: Thermal monitoring enabled (TM1)
[ 0.004393] ACPI: Core revision 20120320
[ 0.148528] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.148893] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.188585] CPU0: Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz stepping 0b
[ 0.192011] Performance Events: PEBS fmt0+, 4-deep LBR, Core2 events, Intel PMU driver.
[ 0.192011] PEBS disabled due to CPU errata.
[ 0.192011] ... version: 2
[ 0.192011] ... bit width: 40
[ 0.192011] ... generic registers: 2
[ 0.192011] ... value mask: 000000ffffffffff
[ 0.192011] ... max period: 000000007fffffff
[ 0.192011] ... fixed-purpose events: 3
[ 0.192011] ... event mask: 0000000700000003
[ 0.200127] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.212028] CPU 1 irqstacks, hard=f6d14000 soft=f6d16000
[ 0.212030] Booting Node 0, Processors #1
[ 0.008000] Initializing CPU#1
[ 0.224041] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.232036] CPU 2 irqstacks, hard=f6d26000 soft=f6d28000
[ 0.232039] #2
[ 0.008000] Initializing CPU#2
[ 0.244033] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.252032] CPU 3 irqstacks, hard=f6d38000 soft=f6d3a000
[ 0.252035] #3
[ 0.008000] Initializing CPU#3
[ 0.264035] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.264067] Brought up 4 CPUs
[ 0.264071] Total of 4 processors activated (19151.65 BogoMIPS).
[ 0.268145] devtmpfs: initialized
[ 0.268235] PM: Registering ACPI NVS region [mem 0xbfdffc00-0xbfe53bff] (344064 bytes)
[ 0.268235] dummy:
[ 0.268248] NET: Registered protocol family 16
[ 0.268378] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.268381] ACPI: bus type pci registered
[ 0.268444] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.268448] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.268450] PCI: Using MMCONFIG for extended config space
[ 0.268452] PCI: Using configuration type 1 for base access
[ 0.268464] dmi type 0xB1 record - unknown flag
[ 0.269029] bio: create slab <bio-0> at 0
[ 0.269029] ACPI: Added _OSI(Module Device)
[ 0.269029] ACPI: Added _OSI(Processor Device)
[ 0.269029] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.269029] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.269199] ACPI: EC: Look up EC in DSDT
[ 0.312221] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
[ 0.352077] ACPI Warning: Incorrect checksum in table [TCPA] - 0x00, should be 0x7F (20120320/tbutils-323)
[ 0.352301] ACPI: Interpreter enabled
[ 0.352310] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.352344] ACPI: Using IOAPIC for interrupt routing
[ 0.523864] ACPI: No dock devices found.
[ 0.523871] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.532380] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.550511] pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7]
[ 0.550511] pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff]
[ 0.550511] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.550511] pci_root PNP0A03:00: host bridge window [mem 0x000c0000-0x000effff]
[ 0.550511] pci_root PNP0A03:00: host bridge window [mem 0x000f0000-0x000fffff]
[ 0.550511] pci_root PNP0A03:00: host bridge window [mem 0xfc000000-0xfec00000]
[ 0.550511] pci_root PNP0A03:00: host bridge window [mem 0xbff00000-0xf7ffffff]
[ 0.550511] pci_root PNP0A03:00: host bridge window [mem 0xff980000-0xff980fff]
[ 0.550511] pci_root PNP0A03:00: host bridge window [mem 0xff97c000-0xff97ffff]
[ 0.550511] pci_root PNP0A03:00: host bridge window [mem 0xff970000-0xff9707ff]
[ 0.550511] pci_root PNP0A03:00: host bridge window [mem 0xfed20000-0xfed9ffff]
[ 0.550511] pci_root PNP0A03:00: host bridge window [mem 0xfeda6000-0xfeda6fff]
[ 0.550511] pci_root PNP0A03:00: host bridge window [mem 0xfeda7000-0xfeda7fff]
[ 0.550511] PCI host bridge to bus 0000:00
[ 0.550511] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
[ 0.550511] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.550511] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.550511] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000effff]
[ 0.550511] pci_bus 0000:00: root bus resource [mem 0x000f0000-0x000fffff]
[ 0.550511] pci_bus 0000:00: root bus resource [mem 0xfc000000-0xfec00000]
[ 0.550511] pci_bus 0000:00: root bus resource [mem 0xbff00000-0xf7ffffff]
[ 0.550511] pci_bus 0000:00: root bus resource [mem 0xff980000-0xff980fff]
[ 0.550511] pci_bus 0000:00: root bus resource [mem 0xff97c000-0xff97ffff]
[ 0.550511] pci_bus 0000:00: root bus resource [mem 0xff970000-0xff9707ff]
[ 0.550511] pci_bus 0000:00: root bus resource [mem 0xfed20000-0xfed9ffff]
[ 0.550511] pci_bus 0000:00: root bus resource [mem 0xfeda6000-0xfeda6fff]
[ 0.550511] pci_bus 0000:00: root bus resource [mem 0xfeda7000-0xfeda7fff]
[ 0.550511] pci 0000:00:00.0: [8086:2e10] type 00 class 0x060000
[ 0.550511] pci 0000:00:01.0: [8086:2e11] type 01 class 0x060400
[ 0.550511] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.550511] pci 0000:00:03.0: [8086:2e14] type 00 class 0x078000
[ 0.550511] pci 0000:00:03.0: reg 10: [mem 0xfeda6000-0xfeda600f 64bit]
[ 0.550511] pci 0000:00:03.0: PME# supported from D0 D3hot D3cold
[ 0.550511] pci 0000:00:03.2: [8086:2e16] type 00 class 0x010185
[ 0.550511] pci 0000:00:03.2: reg 10: [io 0xfe80-0xfe87]
[ 0.550511] pci 0000:00:03.2: reg 14: [io 0xfe90-0xfe93]
[ 0.550511] pci 0000:00:03.2: reg 18: [io 0xfea0-0xfea7]
[ 0.550511] pci 0000:00:03.2: reg 1c: [io 0xfeb0-0xfeb3]
[ 0.550511] pci 0000:00:03.2: reg 20: [io 0xfef0-0xfeff]
[ 0.550511] pci 0000:00:03.3: [8086:2e17] type 00 class 0x070002
[ 0.550511] pci 0000:00:03.3: reg 10: [io 0xecb8-0xecbf]
[ 0.550511] pci 0000:00:03.3: reg 14: [mem 0xf7fd8000-0xf7fd8fff]
[ 0.550511] pci 0000:00:19.0: [8086:10de] type 00 class 0x020000
[ 0.550511] pci 0000:00:19.0: reg 10: [mem 0xf7fe0000-0xf7ffffff]
[ 0.550511] pci 0000:00:19.0: reg 14: [mem 0xf7fd9000-0xf7fd9fff]
[ 0.550511] pci 0000:00:19.0: reg 18: [io 0xece0-0xecff]
[ 0.550511] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
[ 0.550511] pci 0000:00:1a.0: [8086:3a67] type 00 class 0x0c0300
[ 0.550511] pci 0000:00:1a.0: reg 20: [io 0xff20-0xff3f]
[ 0.550511] pci 0000:00:1a.1: [8086:3a68] type 00 class 0x0c0300
[ 0.550511] pci 0000:00:1a.1: reg 20: [io 0xff00-0xff1f]
[ 0.550511] pci 0000:00:1a.2: [8086:3a69] type 00 class 0x0c0300
[ 0.550511] pci 0000:00:1a.2: reg 20: [io 0xfc00-0xfc1f]
[ 0.550511] pci 0000:00:1a.7: [8086:3a6c] type 00 class 0x0c0320
[ 0.550511] pci 0000:00:1a.7: reg 10: [mem 0xf7fda000-0xf7fda3ff]
[ 0.550511] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[ 0.550511] pci 0000:00:1b.0: [8086:3a6e] type 00 class 0x040300
[ 0.550511] pci 0000:00:1b.0: reg 10: [mem 0xf7fdc000-0xf7fdffff 64bit]
[ 0.550511] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.550511] pci 0000:00:1c.0: [8086:3a70] type 01 class 0x060400
[ 0.550511] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.550511] pci 0000:00:1c.1: [8086:3a72] type 01 class 0x060400
[ 0.550511] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.550511] pci 0000:00:1d.0: [8086:3a64] type 00 class 0x0c0300
[ 0.550511] pci 0000:00:1d.0: reg 20: [io 0xff80-0xff9f]
[ 0.550511] pci 0000:00:1d.1: [8086:3a65] type 00 class 0x0c0300
[ 0.550511] pci 0000:00:1d.1: reg 20: [io 0xff60-0xff7f]
[ 0.550511] pci 0000:00:1d.2: [8086:3a66] type 00 class 0x0c0300
[ 0.550511] pci 0000:00:1d.2: reg 20: [io 0xff40-0xff5f]
[ 0.550511] pci 0000:00:1d.7: [8086:3a6a] type 00 class 0x0c0320
[ 0.550511] pci 0000:00:1d.7: reg 10: [mem 0xff980000-0xff9803ff]
[ 0.550511] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.550511] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.550511] pci 0000:00:1f.0: [8086:3a14] type 00 class 0x060100
[ 0.550511] pci 0000:00:1f.2: [8086:3a02] type 00 class 0x010601
[ 0.550511] pci 0000:00:1f.2: reg 10: [io 0xfe00-0xfe07]
[ 0.550511] pci 0000:00:1f.2: reg 14: [io 0xfe10-0xfe13]
[ 0.550511] pci 0000:00:1f.2: reg 18: [io 0xfe20-0xfe27]
[ 0.550511] pci 0000:00:1f.2: reg 1c: [io 0xfe30-0xfe33]
[ 0.550511] pci 0000:00:1f.2: reg 20: [io 0xfec0-0xfedf]
[ 0.550511] pci 0000:00:1f.2: reg 24: [mem 0xff970000-0xff9707ff]
[ 0.550511] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.550511] pci 0000:00:1f.3: [8086:3a60] type 00 class 0x0c0500
[ 0.550511] pci 0000:00:1f.3: reg 10: [mem 0xf7fdb000-0xf7fdb0ff 64bit]
[ 0.550511] pci 0000:00:1f.3: reg 20: [io 0x0980-0x099f]
[ 0.550511] pci 0000:01:00.0: [1002:9498] type 00 class 0x030000
[ 0.550511] pci 0000:01:00.0: reg 10: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.550511] pci 0000:01:00.0: reg 18: [mem 0xf7df0000-0xf7dfffff 64bit]
[ 0.550511] pci 0000:01:00.0: reg 20: [io 0xdc00-0xdcff]
[ 0.550511] pci 0000:01:00.0: reg 30: [mem 0xf7e00000-0xf7e1ffff pref]
[ 0.550511] pci 0000:01:00.0: supports D1 D2
[ 0.550511] pci 0000:01:00.1: [1002:aa38] type 00 class 0x040300
[ 0.550511] pci 0000:01:00.1: reg 10: [mem 0xf7dec000-0xf7deffff 64bit]
[ 0.550511] pci 0000:01:00.1: supports D1 D2
[ 0.550511] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.550511] pci 0000:00:01.0: bridge window [io 0xd000-0xdfff]
[ 0.550511] pci 0000:00:01.0: bridge window [mem 0xf7d00000-0xf7efffff]
[ 0.550511] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.550511] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 0.550511] pci 0000:00:1c.0: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 0.550511] pci 0000:00:1c.1: PCI bridge to [bus 03-03]
[ 0.550511] pci 0000:00:1c.1: bridge window [mem 0xf7b00000-0xf7bfffff]
[ 0.550545] pci 0000:00:1e.0: PCI bridge to [bus 04-04] (subtractive decode)
[ 0.550556] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.550559] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.550562] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.550565] pci 0000:00:1e.0: bridge window [mem 0x000c0000-0x000effff] (subtractive decode)
[ 0.550567] pci 0000:00:1e.0: bridge window [mem 0x000f0000-0x000fffff] (subtractive decode)
[ 0.550570] pci 0000:00:1e.0: bridge window [mem 0xfc000000-0xfec00000] (subtractive decode)
[ 0.550573] pci 0000:00:1e.0: bridge window [mem 0xbff00000-0xf7ffffff] (subtractive decode)
[ 0.550576] pci 0000:00:1e.0: bridge window [mem 0xff980000-0xff980fff] (subtractive decode)
[ 0.550579] pci 0000:00:1e.0: bridge window [mem 0xff97c000-0xff97ffff] (subtractive decode)
[ 0.550581] pci 0000:00:1e.0: bridge window [mem 0xff970000-0xff9707ff] (subtractive decode)
[ 0.552037] pci 0000:00:1e.0: bridge window [mem 0xfed20000-0xfed9ffff] (subtractive decode)
[ 0.552041] pci 0000:00:1e.0: bridge window [mem 0xfeda6000-0xfeda6fff] (subtractive decode)
[ 0.552044] pci 0000:00:1e.0: bridge window [mem 0xfeda7000-0xfeda7fff] (subtractive decode)
[ 0.552063] pci_bus 0000:00: on NUMA node 0
[ 0.552067] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.553005] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI4._PRT]
[ 0.553511] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI2._PRT]
[ 0.553860] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI3._PRT]
[ 0.554213] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
[ 0.554648] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 4.250297] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 15)
[ 4.251086] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 *5 6 7 9 10 11 12 15)
[ 4.251880] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 *9 10 11 12 15)
[ 4.252958] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[ 4.253747] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[ 4.254533] ACPI: PCI Interrupt Link [LNKF] (IRQs *3 4 5 6 7 9 10 11 12 15)
[ 4.255317] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 6 7 9 10 11 12 15)
[ 4.256115] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[ 4.256360] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 4.256360] vgaarb: loaded
[ 4.256360] vgaarb: bridge control possible 0000:01:00.0
[ 4.256360] PCI: Using ACPI for IRQ routing
[ 4.257781] PCI: pci_cache_line_size set to 64 bytes
[ 4.257872] Expanded resource reserved due to conflict with PCI Bus 0000:00
[ 4.257875] Expanded resource reserved due to conflict with PCI Bus 0000:00
[ 4.257878] reserve RAM buffer: 000000000009ec00 - 000000000009ffff
[ 4.257881] reserve RAM buffer: 00000000bfdffc00 - 00000000bfffffff
[ 4.258026] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 4.258036] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 4.260056] Switching to clocksource hpet
[ 4.260266] pnp: PnP ACPI init
[ 4.260266] ACPI: bus type pnp registered
[ 4.270516] pnp 00:00: [bus 00-ff]
[ 4.270520] pnp 00:00: [io 0x0cf8-0x0cff]
[ 4.270523] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 4.270525] pnp 00:00: [io 0x0d00-0xffff window]
[ 4.270528] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 4.270531] pnp 00:00: [mem 0x000c0000-0x000effff window]
[ 4.270534] pnp 00:00: [mem 0x000f0000-0x000fffff window]
[ 4.270536] pnp 00:00: [mem 0xfc000000-0xfec00000 window]
[ 4.270539] pnp 00:00: [mem 0xbff00000-0xf7ffffff window]
[ 4.270541] pnp 00:00: [mem 0xfc000000-0xefffffff window]
[ 4.270544] pnp 00:00: [mem 0xff980000-0xff980fff window]
[ 4.270547] pnp 00:00: [mem 0xff97c000-0xff97ffff window]
[ 4.270549] pnp 00:00: [mem 0xff970000-0xff9707ff window]
[ 4.270552] pnp 00:00: [mem 0xfed20000-0xfed9ffff window]
[ 4.270555] pnp 00:00: [mem 0xfeda6000-0xfeda6fff window]
[ 4.270557] pnp 00:00: [mem 0xfeda7000-0xfeda7fff window]
[ 4.270599] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active)
[ 4.276254] pnp 00:01: [io 0x0060]
[ 4.276257] pnp 00:01: [io 0x0064]
[ 4.276259] pnp 00:01: [io 0x0062-0x0063]
[ 4.276263] pnp 00:01: [io 0x0065-0x006f]
[ 4.276265] pnp 00:01: [io 0x00e0-0x00ef]
[ 4.276268] pnp 00:01: [io 0x0800-0x085f]
[ 4.276270] pnp 00:01: [io 0x0c00-0x0c7f]
[ 4.276272] pnp 00:01: [io 0x0860-0x08ff]
[ 4.276327] system 00:01: [io 0x0800-0x085f] has been reserved
[ 4.276330] system 00:01: [io 0x0c00-0x0c7f] has been reserved
[ 4.276333] system 00:01: [io 0x0860-0x08ff] has been reserved
[ 4.276337] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 4.276624] pnp 00:02: [io 0x0080-0x009f]
[ 4.276627] pnp 00:02: [io 0x0000-0x001f]
[ 4.276629] pnp 00:02: [io 0x00c0-0x00df]
[ 4.276632] pnp 00:02: [dma 4]
[ 4.276661] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 4.276875] pnp 00:03: [io 0x00f0-0x00ff]
[ 4.276885] pnp 00:03: [irq 13]
[ 4.276916] pnp 00:03: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 4.277120] pnp 00:04: [io 0x0061]
[ 4.277150] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
[ 4.277363] pnp 00:05: [io 0x0070-0x007f]
[ 4.277369] pnp 00:05: [irq 8]
[ 4.277399] pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 4.297728] pnp 00:06: [io 0x0378-0x037f]
[ 4.297731] pnp 00:06: [io 0x0778-0x077f]
[ 4.297736] pnp 00:06: [irq 7]
[ 4.297739] pnp 00:06: [dma 0 disabled]
[ 4.298956] pnp 00:06: Plug and Play ACPI device, IDs PNP0401 (active)
[ 4.305297] pnp 00:07: [io 0x03f8-0x03ff]
[ 4.305304] pnp 00:07: [irq 4]
[ 4.305719] pnp 00:07: Plug and Play ACPI device, IDs PNP0501 (active)
[ 4.331403] pnp 00:08: [mem 0xfed00000-0xfed003ff]
[ 4.331442] pnp 00:08: Plug and Play ACPI device, IDs PNP0103 (active)
[ 4.331450] pnp: PnP ACPI: found 9 devices
[ 4.331452] ACPI: ACPI bus type pnp unregistered
[ 4.331455] PnPBIOS: Disabled by ACPI PNP
[ 4.368097] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 02-02] add_size 1000
[ 4.368101] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02-02] add_size 200000
[ 4.368111] pci 0000:00:1c.1: bridge window [io 0x1000-0x0fff] to [bus 03-03] add_size 1000
[ 4.368114] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03-03] add_size 200000
[ 4.368128] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 4.368131] pci 0000:00:1c.1: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 4.368134] pci 0000:00:1c.0: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 4.368137] pci 0000:00:1c.1: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 4.368142] pci 0000:00:1c.0: BAR 15: assigned [mem 0xfc000000-0xfc1fffff 64bit pref]
[ 4.368146] pci 0000:00:1c.1: BAR 15: assigned [mem 0xfc200000-0xfc3fffff 64bit pref]
[ 4.368150] pci 0000:00:1c.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 4.368153] pci 0000:00:1c.1: BAR 13: assigned [io 0x2000-0x2fff]
[ 4.368157] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 4.368160] pci 0000:00:01.0: bridge window [io 0xd000-0xdfff]
[ 4.368165] pci 0000:00:01.0: bridge window [mem 0xf7d00000-0xf7efffff]
[ 4.368168] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xefffffff 64bit pref]
[ 4.368173] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 4.368177] pci 0000:00:1c.0: bridge window [io 0x1000-0x1fff]
[ 4.368182] pci 0000:00:1c.0: bridge window [mem 0xf7c00000-0xf7cfffff]
[ 4.368187] pci 0000:00:1c.0: bridge window [mem 0xfc000000-0xfc1fffff 64bit pref]
[ 4.368193] pci 0000:00:1c.1: PCI bridge to [bus 03-03]
[ 4.368197] pci 0000:00:1c.1: bridge window [io 0x2000-0x2fff]
[ 4.368202] pci 0000:00:1c.1: bridge window [mem 0xf7b00000-0xf7bfffff]
[ 4.368206] pci 0000:00:1c.1: bridge window [mem 0xfc200000-0xfc3fffff 64bit pref]
[ 4.368213] pci 0000:00:1e.0: PCI bridge to [bus 04-04]
[ 4.368255] pci 0000:00:1e.0: setting latency timer to 64
[ 4.368259] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 4.368262] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 4.368264] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 4.368267] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000effff]
[ 4.368269] pci_bus 0000:00: resource 8 [mem 0x000f0000-0x000fffff]
[ 4.368272] pci_bus 0000:00: resource 9 [mem 0xfc000000-0xfec00000]
[ 4.368275] pci_bus 0000:00: resource 10 [mem 0xbff00000-0xf7ffffff]
[ 4.368277] pci_bus 0000:00: resource 11 [mem 0xff980000-0xff980fff]
[ 4.368280] pci_bus 0000:00: resource 12 [mem 0xff97c000-0xff97ffff]
[ 4.368282] pci_bus 0000:00: resource 13 [mem 0xff970000-0xff9707ff]
[ 4.368285] pci_bus 0000:00: resource 14 [mem 0xfed20000-0xfed9ffff]
[ 4.368287] pci_bus 0000:00: resource 15 [mem 0xfeda6000-0xfeda6fff]
[ 4.368290] pci_bus 0000:00: resource 16 [mem 0xfeda7000-0xfeda7fff]
[ 4.368292] pci_bus 0000:01: resource 0 [io 0xd000-0xdfff]
[ 4.368295] pci_bus 0000:01: resource 1 [mem 0xf7d00000-0xf7efffff]
[ 4.368298] pci_bus 0000:01: resource 2 [mem 0xe0000000-0xefffffff 64bit pref]
[ 4.368301] pci_bus 0000:02: resource 0 [io 0x1000-0x1fff]
[ 4.368303] pci_bus 0000:02: resource 1 [mem 0xf7c00000-0xf7cfffff]
[ 4.368306] pci_bus 0000:02: resource 2 [mem 0xfc000000-0xfc1fffff 64bit pref]
[ 4.368308] pci_bus 0000:03: resource 0 [io 0x2000-0x2fff]
[ 4.368311] pci_bus 0000:03: resource 1 [mem 0xf7b00000-0xf7bfffff]
[ 4.368314] pci_bus 0000:03: resource 2 [mem 0xfc200000-0xfc3fffff 64bit pref]
[ 4.368316] pci_bus 0000:04: resource 4 [io 0x0000-0x0cf7]
[ 4.368319] pci_bus 0000:04: resource 5 [io 0x0d00-0xffff]
[ 4.368322] pci_bus 0000:04: resource 6 [mem 0x000a0000-0x000bffff]
[ 4.368324] pci_bus 0000:04: resource 7 [mem 0x000c0000-0x000effff]
[ 4.368327] pci_bus 0000:04: resource 8 [mem 0x000f0000-0x000fffff]
[ 4.368330] pci_bus 0000:04: resource 9 [mem 0xfc000000-0xfec00000]
[ 4.368332] pci_bus 0000:04: resource 10 [mem 0xbff00000-0xf7ffffff]
[ 4.368335] pci_bus 0000:04: resource 11 [mem 0xff980000-0xff980fff]
[ 4.368338] pci_bus 0000:04: resource 12 [mem 0xff97c000-0xff97ffff]
[ 4.368340] pci_bus 0000:04: resource 13 [mem 0xff970000-0xff9707ff]
[ 4.368343] pci_bus 0000:04: resource 14 [mem 0xfed20000-0xfed9ffff]
[ 4.368346] pci_bus 0000:04: resource 15 [mem 0xfeda6000-0xfeda6fff]
[ 4.368348] pci_bus 0000:04: resource 16 [mem 0xfeda7000-0xfeda7fff]
[ 4.368440] NET: Registered protocol family 2
[ 4.368516] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 4.368704] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 4.368995] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 4.369138] TCP: Hash tables configured (established 131072 bind 65536)
[ 4.369140] TCP: reno registered
[ 4.369143] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 4.369150] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 4.369245] NET: Registered protocol family 1
[ 4.369474] pci 0000:01:00.0: Boot video device
[ 4.369480] PCI: CLS 64 bytes, default 64
[ 4.369525] Unpacking initramfs...
[ 4.795375] Freeing initrd memory: 21228k freed
[ 4.803357] Simple Boot Flag at 0x7a set to 0x1
[ 4.803973] audit: initializing netlink socket (disabled)
[ 4.803995] type=2000 audit(1524952533.796:1): initialized
[ 4.815264] highmem bounce pool size: 64 pages
[ 4.815270] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 4.815490] VFS: Disk quotas dquot_6.5.2
[ 4.815524] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 4.815607] msgmni has been set to 1700
[ 4.815792] alg: No test for stdrng (krng)
[ 4.815826] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 4.815830] io scheduler noop registered
[ 4.815832] io scheduler deadline registered
[ 4.815857] io scheduler cfq registered (default)
[ 4.816128] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 4.816147] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 4.816149] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 4.816747] GHES: HEST is not enabled!
[ 4.816760] isapnp: Scanning for PnP cards...
[ 5.169625] isapnp: No Plug & Play device found
[ 5.169676] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 5.190045] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 5.210692] 00:07: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 5.230880] 0000:00:03.3: ttyS1 at I/O 0xecb8 (irq = 17) is a 16550A
[ 5.231226] Linux agpgart interface v0.103
[ 5.231538] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 5.234444] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 5.234476] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 5.234573] mousedev: PS/2 mouse device common for all mice
[ 5.234619] rtc_cmos 00:05: RTC can wake from S4
[ 5.234732] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 5.234757] rtc0: alarms up to one day, 242 bytes nvram, hpet irqs
[ 5.234883] TCP: cubic registered
[ 5.234955] NET: Registered protocol family 10
[ 5.235202] Mobile IPv6
[ 5.235205] NET: Registered protocol family 17
[ 5.235209] Registering the dns_resolver key type
[ 5.235260] Using IPI No-Shortcut mode
[ 5.235358] PM: Hibernation image not present or could not be loaded.
[ 5.235368] registered taskstats version 1
[ 5.235791] rtc_cmos 00:05: setting system clock to 2018-04-28 21:55:34 UTC (1524952534)
[ 5.235909] Freeing unused kernel memory: 416k freed
[ 5.236119] Write protecting the kernel text: 3500k
[ 5.236145] Write protecting the kernel read-only data: 980k
[ 5.252349] systemd-udevd[68]: starting version 204
[ 5.259649] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 5.259659] ACPI: Power Button [VBTN]
[ 5.259735] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 5.259740] ACPI: Power Button [PWRF]
[ 5.263436] wmi: Mapper loaded
[ 5.265921] [drm] Initialized drm 1.1.0 20060810
[ 5.269779] SCSI subsystem initialized
[ 5.269962] e1000e: Intel(R) PRO/1000 Network Driver - 1.9.5-k
[ 5.269965] e1000e: Copyright(c) 1999 - 2012 Intel Corporation.
[ 5.270011] e1000e 0000:00:19.0: setting latency timer to 64
[ 5.270075] e1000e 0000:00:19.0: (unregistered net_device): Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 5.270588] usbcore: registered new interface driver usbfs
[ 5.270620] usbcore: registered new interface driver hub
[ 5.272575] libata version 3.00 loaded.
[ 5.273096] usbcore: registered new device driver usb
[ 5.274429] uhci_hcd: USB Universal Host Controller Interface driver
[ 5.275932] [drm] radeon defaulting to kernel modesetting.
[ 5.275936] [drm] radeon kernel modesetting enabled.
[ 5.276221] [drm] initializing kernel modesetting (RV730 0x1002:0x9498 0x174B:0xE109).
[ 5.276239] [drm] register mmio base: 0xF7DF0000
[ 5.276242] [drm] register mmio size: 65536
[ 5.276365] ATOM BIOS:
[ 5.276392] radeon 0000:01:00.0: VRAM: 512M 0x0000000000000000 - 0x000000001FFFFFFF (512M used)
[ 5.276398] radeon 0000:01:00.0: GTT: 512M 0x0000000020000000 - 0x000000003FFFFFFF
[ 5.279613] [drm] Detected VRAM RAM=512M, BAR=256M
[ 5.279617] [drm] RAM width 128bits DDR
[ 5.279753] [TTM] Zone kernel: Available graphics memory: 435634 kiB
[ 5.279756] [TTM] Zone highmem: Available graphics memory: 1552820 kiB
[ 5.279759] [TTM] Initializing pool allocator
[ 5.279786] [drm] radeon: 512M of VRAM memory ready
[ 5.279788] [drm] radeon: 512M of GTT memory ready.
[ 5.279811] [drm] GART: num cpu pages 131072, num gpu pages 131072
[ 5.280227] [drm] radeon: ib pool ready.
[ 5.280321] [drm] Loading RV730 Microcode
[ 5.284640] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 5.284643] Warning! ehci_hcd should always be loaded before uhci_hcd and ohci_hcd, not after
[ 5.294203] [drm] PCIE GART of 512M enabled (table at 0x0000000000040000).
[ 5.294242] radeon 0000:01:00.0: WB enabled
[ 5.294245] [drm] fence driver on ring 0 use gpu addr 0x20000c00 and cpu addr 0xff819c00
[ 5.294251] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 5.294253] [drm] Driver supports precise vblank timestamp query.
[ 5.294284] [drm] radeon: irq initialized.
[ 5.340222] [drm] ring test on 0 succeeded in 1 usecs
[ 5.340364] [drm] ib test on ring 0 succeeded in 0 usecs
[ 5.340649] [drm] Radeon Display Connectors
[ 5.340651] [drm] Connector 0:
[ 5.340653] [drm] VGA
[ 5.340656] [drm] DDC: 0x7e20 0x7e20 0x7e24 0x7e24 0x7e28 0x7e28 0x7e2c 0x7e2c
[ 5.340658] [drm] Encoders:
[ 5.340660] [drm] CRT2: INTERNAL_KLDSCP_DAC2
[ 5.340662] [drm] Connector 1:
[ 5.340664] [drm] HDMI-A
[ 5.340665] [drm] HPD2
[ 5.340668] [drm] DDC: 0x7f10 0x7f10 0x7f14 0x7f14 0x7f18 0x7f18 0x7f1c 0x7f1c
[ 5.340670] [drm] Encoders:
[ 5.340672] [drm] DFP2: INTERNAL_UNIPHY1
[ 5.340674] [drm] Connector 2:
[ 5.340676] [drm] DVI-I
[ 5.340678] [drm] HPD1
[ 5.340680] [drm] DDC: 0x7e40 0x7e40 0x7e44 0x7e44 0x7e48 0x7e48 0x7e4c 0x7e4c
[ 5.340682] [drm] Encoders:
[ 5.340683] [drm] CRT1: INTERNAL_KLDSCP_DAC1
[ 5.340685] [drm] DFP1: INTERNAL_UNIPHY
[ 5.340705] [drm] Internal thermal controller with fan control
[ 5.340747] [drm] radeon: power management initialized
[ 5.385761] [drm] fb mappable at 0xE0142000
[ 5.385764] [drm] vram apper at 0xE0000000
[ 5.385766] [drm] size 5242880
[ 5.385767] [drm] fb depth is 24
[ 5.385769] [drm] pitch is 5120
[ 5.385834] fbcon: radeondrmfb (fb0) is primary device
[ 5.464131] e1000e 0000:00:19.0: eth0: (PCI Express:2.5GT/s:Width x1) a4:ba:db:ea:95:9d
[ 5.464135] e1000e 0000:00:19.0: eth0: Intel(R) PRO/1000 Network Connection
[ 5.464180] e1000e 0000:00:19.0: eth0: MAC: 8, PHY: 8, PBA No: 2011FF-0FF
[ 5.464263] ata_generic 0000:00:03.2: setting latency timer to 64
[ 5.464613] scsi0 : ata_generic
[ 5.464740] scsi1 : ata_generic
[ 5.464789] ata1: PATA max UDMA/100 cmd 0xfe80 ctl 0xfe90 bmdma 0xfef0 irq 18
[ 5.464792] ata2: PATA max UDMA/100 cmd 0xfea0 ctl 0xfeb0 bmdma 0xfef8 irq 18
[ 5.464863] uhci_hcd 0000:00:1a.0: setting latency timer to 64
[ 5.464873] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 5.464899] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 1
[ 5.464927] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000ff20
[ 5.464968] usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
[ 5.464970] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.464973] usb usb1: Product: UHCI Host Controller
[ 5.464975] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 5.464977] usb usb1: SerialNumber: 0000:00:1a.0
[ 5.465098] hub 1-0:1.0: USB hub found
[ 5.465103] hub 1-0:1.0: 2 ports detected
[ 5.465200] uhci_hcd 0000:00:1a.1: setting latency timer to 64
[ 5.465203] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 5.465212] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 2
[ 5.465247] uhci_hcd 0000:00:1a.1: irq 17, io base 0x0000ff00
[ 5.465284] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 5.465287] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.465289] usb usb2: Product: UHCI Host Controller
[ 5.465291] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 5.465293] usb usb2: SerialNumber: 0000:00:1a.1
[ 5.465405] hub 2-0:1.0: USB hub found
[ 5.465409] hub 2-0:1.0: 2 ports detected
[ 5.465498] uhci_hcd 0000:00:1a.2: setting latency timer to 64
[ 5.465502] uhci_hcd 0000:00:1a.2: UHCI Host Controller
[ 5.465511] uhci_hcd 0000:00:1a.2: new USB bus registered, assigned bus number 3
[ 5.465546] uhci_hcd 0000:00:1a.2: irq 22, io base 0x0000fc00
[ 5.465581] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 5.465585] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.465589] usb usb3: Product: UHCI Host Controller
[ 5.465593] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 5.465595] usb usb3: SerialNumber: 0000:00:1a.2
[ 5.465724] hub 3-0:1.0: USB hub found
[ 5.465730] hub 3-0:1.0: 2 ports detected
[ 5.465817] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 5.465822] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 5.465831] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 4
[ 5.465864] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000ff80
[ 5.465898] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 5.465902] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.465904] usb usb4: Product: UHCI Host Controller
[ 5.465906] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 5.465908] usb usb4: SerialNumber: 0000:00:1d.0
[ 5.466021] hub 4-0:1.0: USB hub found
[ 5.466025] hub 4-0:1.0: 2 ports detected
[ 5.466114] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 5.466118] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 5.466128] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 5
[ 5.466152] uhci_hcd 0000:00:1d.1: irq 17, io base 0x0000ff60
[ 5.466187] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 5.466192] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.466195] usb usb5: Product: UHCI Host Controller
[ 5.466197] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 5.466199] usb usb5: SerialNumber: 0000:00:1d.1
[ 5.466317] hub 5-0:1.0: USB hub found
[ 5.466321] hub 5-0:1.0: 2 ports detected
[ 5.466406] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 5.466409] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 5.466417] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 6
[ 5.466439] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000ff40
[ 5.466471] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 5.466473] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.466475] usb usb6: Product: UHCI Host Controller
[ 5.466477] usb usb6: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 5.466479] usb usb6: SerialNumber: 0000:00:1d.2
[ 5.466591] hub 6-0:1.0: USB hub found
[ 5.466596] hub 6-0:1.0: 2 ports detected
[ 5.466680] ahci 0000:00:1f.2: version 3.0
[ 5.466770] ahci 0000:00:1f.2: AHCI 0001.0200 32 slots 6 ports 3 Gbps 0x27 impl SATA mode
[ 5.466774] ahci 0000:00:1f.2: flags: 64bit ncq sntf led clo pio ems sxs
[ 5.466782] ahci 0000:00:1f.2: setting latency timer to 64
[ 5.488653] scsi2 : ahci
[ 5.488742] scsi3 : ahci
[ 5.488826] scsi4 : ahci
[ 5.488911] scsi5 : ahci
[ 5.488993] scsi6 : ahci
[ 5.489075] scsi7 : ahci
[ 5.489128] ata3: SATA max UDMA/133 abar m2048@0xff970000 port 0xff970100 irq 18
[ 5.489131] ata4: SATA max UDMA/133 abar m2048@0xff970000 port 0xff970180 irq 18
[ 5.489133] ata5: SATA max UDMA/133 abar m2048@0xff970000 port 0xff970200 irq 18
[ 5.489135] ata6: DUMMY
[ 5.489137] ata7: DUMMY
[ 5.489139] ata8: SATA max UDMA/133 abar m2048@0xff970000 port 0xff970380 irq 18
[ 5.489186] ehci_hcd 0000:00:1a.7: setting latency timer to 64
[ 5.489191] ehci_hcd 0000:00:1a.7: EHCI Host Controller
[ 5.489207] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 7
[ 5.489239] ehci_hcd 0000:00:1a.7: debug port 1
[ 5.493131] ehci_hcd 0000:00:1a.7: cache line size of 64 is not supported
[ 5.493137] ehci_hcd 0000:00:1a.7: irq 22, io mem 0xf7fda000
[ 5.504016] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[ 5.504040] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002
[ 5.504042] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.504045] usb usb7: Product: EHCI Host Controller
[ 5.504047] usb usb7: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 5.504049] usb usb7: SerialNumber: 0000:00:1a.7
[ 5.504167] hub 7-0:1.0: USB hub found
[ 5.504173] hub 7-0:1.0: 6 ports detected
[ 5.504281] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 5.504284] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 5.504292] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 8
[ 5.504315] ehci_hcd 0000:00:1d.7: debug port 1
[ 5.508207] ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
[ 5.508212] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xff980000
[ 5.520016] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 5.520034] usb usb8: New USB device found, idVendor=1d6b, idProduct=0002
[ 5.520037] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.520039] usb usb8: Product: EHCI Host Controller
[ 5.520041] usb usb8: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 5.520043] usb usb8: SerialNumber: 0000:00:1d.7
[ 5.520152] hub 8-0:1.0: USB hub found
[ 5.520156] hub 8-0:1.0: 6 ports detected
[ 5.788955] Console: switching to colour frame buffer device 160x64
[ 5.793358] fb0: radeondrmfb frame buffer device
[ 5.793364] drm: registered panic notifier
[ 5.793375] [drm] Initialized radeon 2.16.0 20080528 for 0000:01:00.0 on minor 0
[ 5.800015] Refined TSC clocksource calibration: 2393.999 MHz.
[ 5.800021] Switching to clocksource tsc
[ 5.808020] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 5.808040] ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 5.808058] ata5: SATA link down (SStatus 4 SControl 300)
[ 5.808621] ata3.00: ATA-7: WDC WD2500JS-75NCB1, 10.02E01, max UDMA/133
[ 5.808625] ata3.00: 488281250 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[ 5.809310] ata3.00: configured for UDMA/133
[ 5.809422] scsi 2:0:0:0: Direct-Access ATA WDC WD2500JS-75N 10.0 PQ: 0 ANSI: 5
[ 5.816024] ata8: SATA link down (SStatus 0 SControl 300)
[ 5.831382] ata4.00: ATAPI: TSSTcorp DVD+/-RW TS-L633C, DW40, max UDMA/100
[ 5.831385] ata4.00: applying bridge limits
[ 5.851587] ata4.00: configured for UDMA/100
[ 5.854497] scsi 3:0:0:0: CD-ROM TSSTcorp DVD+-RW TS-L633C DW40 PQ: 0 ANSI: 5
[ 5.868989] sd 2:0:0:0: [sda] 488281250 512-byte logical blocks: (250 GB/232 GiB)
[ 5.869059] sd 2:0:0:0: [sda] Write Protect is off
[ 5.869065] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 5.869094] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 5.873022] sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[ 5.873027] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 5.873171] sr 3:0:0:0: Attached scsi CD-ROM sr0
[ 5.893273] sda: sda1 sda2 sda3 < sda5 >
[ 5.893611] sd 2:0:0:0: [sda] Attached SCSI disk
[ 5.928019] usb 8-4: new high-speed USB device number 3 using ehci_hcd
[ 6.119011] usb 8-4: New USB device found, idVendor=0644, idProduct=0200
[ 6.119015] usb 8-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6.119018] usb 8-4: Product: CA-200
[ 6.119020] usb 8-4: Manufacturer: TEAC
[ 6.119022] usb 8-4: SerialNumber: 000004239BB8
[ 6.120365] Initializing USB Mass Storage driver...
[ 6.120475] scsi8 : usb-storage 8-4:1.0
[ 6.120551] usbcore: registered new interface driver usb-storage
[ 6.120554] USB Mass Storage support registered.
[ 6.348124] device-mapper: uevent: version 1.0.3
[ 6.348201] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: This email address is being protected from spambots. You need JavaScript enabled to view it.
[ 6.443483] kjournald starting. Commit interval 5 seconds
[ 6.443503] EXT3-fs (sda5): mounted filesystem with ordered data mode
[ 6.468023] usb 1-2: new low-speed USB device number 2 using uhci_hcd
[ 6.644969] usb 1-2: New USB device found, idVendor=413c, idProduct=2107
[ 6.644973] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.644976] usb 1-2: Product: Dell USB Entry Keyboard
[ 6.644978] usb 1-2: Manufacturer: DELL
[ 6.888016] usb 4-1: new low-speed USB device number 2 using uhci_hcd
[ 7.070903] usb 4-1: New USB device found, idVendor=045e, idProduct=0047
[ 7.070906] usb 4-1: New USB device strings: Mfr=1, Product=3, SerialNumber=0
[ 7.070909] usb 4-1: Product: Microsoft 5-Button Mouse with IntelliEye(TM)
[ 7.070912] usb 4-1: Manufacturer: Microsoft
[ 7.130281] scsi 8:0:0:0: Direct-Access TEAC USB HS-CF Card 4.12 PQ: 0 ANSI: 0
[ 7.133900] scsi 8:0:0:1: Direct-Access TEAC USB HS-xD/SM 4.12 PQ: 0 ANSI: 0
[ 7.137399] scsi 8:0:0:2: Direct-Access TEAC USB HS-MS Card 4.12 PQ: 0 ANSI: 0
[ 7.140784] scsi 8:0:0:3: Direct-Access TEAC USB HS-SD Card 4.12 PQ: 0 ANSI: 0
[ 7.179769] sd 8:0:0:0: [sdb] Attached SCSI removable disk
[ 7.184767] sd 8:0:0:1: [sdc] Attached SCSI removable disk
[ 7.189268] sd 8:0:0:2: [sdd] Attached SCSI removable disk
[ 7.193267] sd 8:0:0:3: [sde] Attached SCSI removable disk
[ 7.312016] usb 6-1: new full-speed USB device number 2 using uhci_hcd
[ 7.465476] usb 6-1: New USB device found, idVendor=10ce, idProduct=eb70
[ 7.465479] usb 6-1: New USB device strings: Mfr=1, Product=0, SerialNumber=0
[ 7.465482] usb 6-1: Manufacturer: KTURT.LTD
[ 7.971850] init: ureadahead main process (211) terminated with status 5
[ 9.676915] EXT3-fs (sda5): using internal journal
[ 10.538810] systemd-udevd[340]: starting version 204
[ 11.580214] lp: driver loaded but no devices found
[ 12.155568] ppdev: user-space parallel port driver
[ 12.369689] parport_pc 00:06: reported by Plug and Play ACPI
[ 12.369742] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[ 12.464122] lp0: using parport0 (interrupt-driven).
[ 12.534119] fuse init (API version 7.18)
[ 12.986748] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 13.408396] microcode: CPU0 sig=0x6fb, pf=0x10, revision=0xba
[ 13.560383] device-mapper: multipath: version 1.3.0 loaded
[ 13.842473] coretemp coretemp.0: Using relative temperature scale!
[ 13.842981] coretemp coretemp.0: Using relative temperature scale!
[ 13.842993] coretemp coretemp.0: Using relative temperature scale!
[ 13.843003] coretemp coretemp.0: Using relative temperature scale!
[ 13.917812] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 14.128269] input: Dell WMI hotkeys as /devices/virtual/input/input2
[ 14.414336] init: cups main process (446) killed by HUP signal
[ 14.414349] init: cups main process ended, respawning
[ 14.669584] microcode: CPU1 sig=0x6fb, pf=0x10, revision=0xba
[ 14.675768] microcode: CPU2 sig=0x6fb, pf=0x10, revision=0xba
[ 14.676559] microcode: CPU3 sig=0x6fb, pf=0x10, revision=0xba
[ 14.677318] microcode: Microcode Update Driver: v2.00 <This email address is being protected from spambots. You need JavaScript enabled to view it.>, Peter Oruba
[ 15.685319] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input3
[ 15.833277] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input4
[ 16.190897] Bluetooth: Core ver 2.16
[ 16.190918] NET: Registered protocol family 31
[ 16.190921] Bluetooth: HCI device and connection manager initialized
[ 16.190925] Bluetooth: HCI socket layer initialized
[ 16.190929] Bluetooth: L2CAP socket layer initialized
[ 16.190936] Bluetooth: SCO socket layer initialized
[ 16.222604] Bluetooth: RFCOMM TTY layer initialized
[ 16.222613] Bluetooth: RFCOMM socket layer initialized
[ 16.222616] Bluetooth: RFCOMM ver 1.11
[ 17.026606] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 17.026609] Bluetooth: BNEP filters: protocol multicast
[ 18.275490] input: DELL Dell USB Entry Keyboard as /devices/pci0000:00/0000:00:1a.0/usb1/1-2/1-2:1.0/input/input5
[ 18.275741] generic-usb 0003:413C:2107.0001: input,hidraw0: USB HID v1.11 Keyboard [DELL Dell USB Entry Keyboard] on usb-0000:00:1a.0-2/input0
[ 18.290402] input: Microsoft Microsoft 5-Button Mouse with IntelliEye(TM) as /devices/pci0000:00/0000:00:1d.0/usb4/4-1/4-1:1.0/input/input6
[ 18.290548] generic-usb 0003:045E:0047.0002: input,hidraw1: USB HID v1.10 Mouse [Microsoft Microsoft 5-Button Mouse with IntelliEye(TM)] on usb-0000:00:1d.0-1/input0
[ 18.295795] generic-usb 0003:10CE:EB70.0003: hiddev0,hidraw2: USB HID v1.10 Device [KTURT.LTD] on usb-0000:00:1d.2-1/input0
[ 18.295819] usbcore: registered new interface driver usbhid
[ 18.295821] usbhid: USB HID core driver
[ 18.684674] init: failsafe main process (550) killed by TERM signal
[ 27.575182] init: samba-ad-dc main process (796) terminated with status 1
[ 28.414329] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 29.988860] e1000e: eth0 NIC Link is Up 100 Mbps Full Duplex, Flow Control: Rx/Tx
[ 29.988866] e1000e 0000:00:19.0: eth0: 10/100 speed: disabling TSO
[ 29.988974] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 33.270985] init: plymouth-upstart-bridge main process ended, respawning
[ 41.024007] eth0: no IPv6 routers present
[ 42.924733] vboxdrv: Found 4 processor cores
[ 42.924948] vboxdrv: fAsync=0 offMin=0x2f4 offMax=0x1bab
[ 43.025024] vboxdrv: TSC mode is Synchronous, tentative frequency 2393998778 Hz
[ 43.025027] vboxdrv: Successfully loaded version 5.0.2 (interface 0x00230003)
[ 43.348892] VBoxNetFlt: Successfully started.
[ 43.463493] VBoxNetAdp: Successfully started.
[ 43.590234] VBoxPciLinuxInit
[ 43.604495] vboxpci: IOMMU not found (not compiled)
[ 45.825538] init: plymouth-stop pre-start process (2028) terminated with status 1
[ 141.323243] I-pipe: head domain RTAI registered.
[ 141.323250] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 141.323349] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 141.323353] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2393957000, CPU_FREQ 2393957000
[ 141.323357] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 141.323361] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 7717750
[ 141.413578] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 141.413616] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 141.413621] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[ 141.413624] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2393957000 hz.
[ 141.413627] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 141.464465] RTAI[math]: loaded.
[ 141.782631] config string '0x378 out'
[ 1476.697694] spurious APIC interrupt on CPU#0, should never happen.
[ 1476.697702] spurious APIC interrupt on CPU#3, should never happen.
[ 1476.701223] RTAI[math]: unloaded.
[ 1476.702956] SCHED releases registered named ALIEN PEDV$D
[ 1476.705784] RTAI[malloc]: unloaded.
[ 1476.804012] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1476.805894] I-pipe: head domain RTAI unregistered.
[ 1476.805999] RTAI[hal]: unmounted.
[ 3903.573023] I-pipe: head domain RTAI registered.
[ 3903.573028] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 3903.573138] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3903.573142] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2393957000, CPU_FREQ 2393957000
[ 3903.573146] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3903.573151] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 12099250
[ 3903.580027] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3903.580076] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3903.580083] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[ 3903.580089] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2393957000 hz.
[ 3903.580092] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 3903.589350] RTAI[math]: loaded.
[ 3903.741411] config string '0x378 out'
[ 3938.982424] RTAI[math]: unloaded.
[ 3938.984168] SCHED releases registered named ALIEN PEDV$D
[ 3938.987041] RTAI[malloc]: unloaded.
[ 3939.084023] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3939.085830] I-pipe: head domain RTAI unregistered.
[ 3939.085938] RTAI[hal]: unmounted.
[ 5180.314772] I-pipe: head domain RTAI registered.
[ 5180.314778] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 5180.314876] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 5180.314881] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2393957000, CPU_FREQ 2393957000
[ 5180.314884] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 5180.314889] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 6302750
[ 5180.321734] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 5180.321771] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 5180.321776] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[ 5180.321779] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2393957000 hz.
[ 5180.321782] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 5180.328052] RTAI[math]: loaded.
[ 5180.480708] config string '0x378 out'
[ 5644.833054] RTAI[math]: unloaded.
[ 5644.834705] SCHED releases registered named ALIEN PEDV$D
[ 5644.841959] RTAI[malloc]: unloaded.
[ 5644.940016] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 5644.943370] I-pipe: head domain RTAI unregistered.
[ 5644.943486] RTAI[hal]: unmounted.
[ 6413.523542] I-pipe: head domain RTAI registered.
[ 6413.523547] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 6413.523654] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 6413.523657] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2393957000, CPU_FREQ 2393957000
[ 6413.523660] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 6413.523664] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 7148500
[ 6413.530472] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 6413.530510] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 6413.530515] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[ 6413.530518] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2393957000 hz.
[ 6413.530522] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 6413.542140] RTAI[math]: loaded.
[ 6413.593101] config string '0x378 out'
[ 6416.131324] RTAI[math]: unloaded.
[ 6416.132961] SCHED releases registered named ALIEN PEDV$D
[ 6416.145518] RTAI[malloc]: unloaded.
[ 6416.244011] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 6416.245847] I-pipe: head domain RTAI unregistered.
[ 6416.245956] RTAI[hal]: unmounted.
[ 6832.633925] I-pipe: head domain RTAI registered.
[ 6832.633931] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 6832.634033] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 6832.634038] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2393957000, CPU_FREQ 2393957000
[ 6832.634041] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 6832.634045] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 16371750
[ 6832.640880] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 6832.640925] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 6832.640930] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[ 6832.640933] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2393957000 hz.
[ 6832.640935] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 6832.651828] RTAI[math]: loaded.
[ 6832.803807] config string '0x378 out'
[ 6835.228106] RTAI[math]: unloaded.
[ 6835.229799] SCHED releases registered named ALIEN PEDV$D
[ 6835.239392] RTAI[malloc]: unloaded.
[ 6835.336011] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 6835.337779] I-pipe: head domain RTAI unregistered.
[ 6835.337886] RTAI[hal]: unmounted.
[ 8077.963262] I-pipe: head domain RTAI registered.
[ 8077.963268] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 8077.963367] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 8077.963371] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2393957000, CPU_FREQ 2393957000
[ 8077.963375] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 8077.963379] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 15102750
[ 8077.970836] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 8077.970882] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 8077.970887] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[ 8077.970890] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2393957000 hz.
[ 8077.970893] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 8077.981612] RTAI[math]: loaded.
[ 8078.136085] config string '0x378 out'
[ 8080.629758] RTAI[math]: unloaded.
[ 8080.631880] SCHED releases registered named ALIEN PEDV$D
[ 8080.637602] RTAI[malloc]: unloaded.
[ 8080.736018] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 8080.737943] I-pipe: head domain RTAI unregistered.
[ 8080.738047] RTAI[hal]: unmounted.
[165933.032357] I-pipe: head domain RTAI registered.
[165933.032365] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[165933.032467] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[165933.032472] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2393957000, CPU_FREQ 2393957000
[165933.032475] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[165933.032479] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 16580500
[165933.039329] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[165933.039372] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[165933.039378] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[165933.039383] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2393957000 hz.
[165933.039386] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[165933.049361] RTAI[math]: loaded.
[165933.105823] config string '0x378 out'
[165935.607317] RTAI[math]: unloaded.
[165935.609105] SCHED releases registered named ALIEN PEDV$D
[165935.612605] RTAI[malloc]: unloaded.
[165935.712016] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[165935.713895] I-pipe: head domain RTAI unregistered.
[165935.714004] RTAI[hal]: unmounted.
[165993.166729] I-pipe: head domain RTAI registered.
[165993.166737] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[165993.166839] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[165993.166843] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2393957000, CPU_FREQ 2393957000
[165993.166846] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[165993.166850] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 15702250
[165993.173816] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[165993.173858] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[165993.173869] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[165993.173872] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2393957000 hz.
[165993.173875] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[165993.180869] RTAI[math]: loaded.
[165993.331620] config string '0x378 out'
[165995.793757] spurious APIC interrupt on CPU#1, should never happen.
[165995.797575] RTAI[math]: unloaded.
[165995.799343] SCHED releases registered named ALIEN PEDV$D
[165995.819374] RTAI[malloc]: unloaded.
[165995.916015] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[165995.917843] I-pipe: head domain RTAI unregistered.
[165995.917947] RTAI[hal]: unmounted.
[167668.132755] I-pipe: head domain RTAI registered.
[167668.132760] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[167668.132867] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[167668.132872] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2393957000, CPU_FREQ 2393957000
[167668.132877] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[167668.132881] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 16592750
[167668.139560] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[167668.139598] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[167668.139602] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[167668.139606] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2393957000 hz.
[167668.139608] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[167668.150455] RTAI[math]: loaded.
[167668.201408] config string '0x378 out'
[167670.696223] RTAI[math]: unloaded.
[167670.697953] SCHED releases registered named ALIEN PEDV$D
[167670.700855] RTAI[malloc]: unloaded.
[167670.800018] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[167670.801867] I-pipe: head domain RTAI unregistered.
[167670.801992] RTAI[hal]: unmounted.
[169126.795391] I-pipe: head domain RTAI registered.
[169126.795397] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[169126.795501] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[169126.795505] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2393957000, CPU_FREQ 2393957000
[169126.795508] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[169126.795511] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 16361250
[169126.802785] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[169126.802823] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[169126.802827] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[169126.802831] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2393957000 hz.
[169126.802833] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[169126.815871] RTAI[math]: loaded.
[169126.866608] config string '0x378 out'
[169129.347094] RTAI[math]: unloaded.
[169129.349402] SCHED releases registered named ALIEN PEDV$D
[169129.360741] RTAI[malloc]: unloaded.
[169129.460011] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[169129.461749] I-pipe: head domain RTAI unregistered.
[169129.461857] RTAI[hal]: unmounted.
[169607.759603] I-pipe: head domain RTAI registered.
[169607.759608] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[169607.759718] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[169607.759721] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2393957000, CPU_FREQ 2393957000
[169607.759724] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[169607.759727] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 16055000
[169607.766524] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[169607.766560] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[169607.766565] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[169607.766569] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2393957000 hz.
[169607.766572] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[169607.771185] RTAI[math]: loaded.
[169607.936076] config string '0x378 out'
[169610.418957] RTAI[math]: unloaded.
[169610.420729] SCHED releases registered named ALIEN PEDV$D
[169610.432518] RTAI[malloc]: unloaded.
[169610.532011] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[169610.533858] I-pipe: head domain RTAI unregistered.
[169610.533962] RTAI[hal]: unmounted.
[178132.047503] I-pipe: head domain RTAI registered.
[178132.047508] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[178132.047608] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[178132.047612] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2393957000, CPU_FREQ 2393957000
[178132.047615] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[178132.047618] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 16437500
[178132.054439] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[178132.054474] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[178132.054479] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[178132.054482] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2393957000 hz.
[178132.054484] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[178132.060065] RTAI[math]: loaded.
[178132.213793] config string '0x378 out'
[178134.701173] RTAI[math]: unloaded.
[178134.702922] SCHED releases registered named ALIEN PEDV$D
[178134.706118] RTAI[malloc]: unloaded.
[178134.804011] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[178134.805808] I-pipe: head domain RTAI unregistered.
[178134.805917] RTAI[hal]: unmounted.
Hello, I'm having some trouble getting my XHC-HB04 pendant to work above is the error log that occurs with start-up and I have been able to use the command line to send and receive command to the pendant but best I can tell there is a conflict with a probe pin any help is greatly appreciated. I think that I am almost there. I do have a nice probing page which I added a while ago that may be the part of the problem but would like to keep both the probing tab and the pendant working if possible. Thank you for your time.
- billykid
- Thank you received: 83
01 May 2018 08:47 - 01 May 2018 09:22 #109888
by billykid
Replied by billykid on topic Help with XHC-HB04 Wireless Pendant needed
Hello
I have a working hb04, it does not work because you have two connections to motion probe input
hal: net probe-in => motion.probe-input
is ok
why and already in the ini file:
probe-z = motion.probe-input.
you have to make sure you only have one.
is ok
Last edit: 01 May 2018 09:22 by billykid.
- MDM3D
01 May 2018 14:59 #109912
by MDM3D
Replied by MDM3D on topic Help with XHC-HB04 Wireless Pendant needed
So I am unable to have a UI button in axis and a physical button on the HB04 to activate a probe?
- billykid
01 May 2018 15:43 #109919
by billykid
the probe electrically works already, after it must be used with g38.2 for example.
probe-z = halui.mdi-command-06
MDI_COMMAND=o100 call
- MDM3D
02 May 2018 03:33 - 02 May 2018 03:35 #109995
by MDM3D
billykid, Thank you for your hb04.hal example. That allowed my machine to actually start and I can use my pendant as intended. Awesome! I am starting to understand the .hal files a little better. I have another question though, Where am I supposed to place the subroutine code?
Also can you please explain why
means the same thing as
because I read each line as independent of each other although they obviously interfere with each other?
I had assumed that I could have a bunch of different things look at the same "pin" state at the same time for things like conditional statements........
Last edit: 02 May 2018 03:35 by MDM3D.
- billykid
02 May 2018 07:29 #110001
by billykid
Good ! first of all add this line in section ini
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
SUBROUTINE_PATH = / home / cnc / linuxcnc / nc_files
your path
put o100.ngc in nc_files.
I try to explain myself but it's not my language I'm Italian
net probe-in => motion.probe-input is the link you do not need anything else, after use with g38. *.
you can do operations with the signals first, but the motion component only wants one input.
[RS274NGC]
your path
Time to create page: 0.187 seconds
