Tandem X axis won't move
- TRAUPMANN00
01 May 2018 18:02 #109925
by TRAUPMANN00
Tandem X axis won't move was created by TRAUPMANN00
3 out of 4 is great in baseball, but not in configuring a gantry!
I am running:
- MESA 6i25 with one 7i76 daughter card. (MESA shows 5i25 in download)
- Self Built Gantry of my own design 48x48x10
- (4) DQ860MA micro stepper drivers from Wantai
- (4) Mesa 34 Stepper Motors
- All wire-connected identically and checked numerous times
Issue:
- X axis does not move (East)
- X1 moves correctly (West)
- Y moves correctly
- Z moves correctly
- swapping X with Z stepper motor, X still doesn't move. (East)
- swapping X & X1 at the Micro-Stepper, the X1 moves not the X (new East)
- rewired 7i76 to micro-stepper with a heavier gage wire (16ga)
- all steppers lock up well when activated.
Basically, swapped Steppers, and swapped micro-stepper drivers to eliminate broken item with the same issue.
I have tried numerous configuration changes and nothing seems to work.
- acts like broken wire or poor solder -- all double checked.
- So I can only assume I am missing something in the HAL or INI files.
I am running:
Issue:
- Y moves correctly
- Z moves correctly
- Clive S
- Thank you received: 486
01 May 2018 18:31 #109927
by Clive S
Replied by Clive S on topic Tandem X axis won't move
Have you tried setting home sequence to -1 in both x motors ini file I think you have one set 1 and one set -1
- TRAUPMANN00
01 May 2018 18:42 #109929
by TRAUPMANN00
Replied by TRAUPMANN00 on topic Tandem X axis won't move
Yes, I had trouble earlier getting axes to sync, the sequence issue was a leavage from then. Still the same issue.
- Thank you received: 5308
01 May 2018 19:23 #109933
Replied by PCW on topic Tandem X axis won't move
It sounds like either a hardware issue with the 7I76 outputs or a configuration issue
One way to check is:
1. Check if the joint position moves (joint.1.motor-pos-cmd and joint.1.motor-pos-fb change as expected)
2. Check the step/dir outputs of the 7I76 ( you can do this with a voltmeter across the step or direction outputs while manually changing the output polarity)
In 2.8 you can change the output polarity by setting the parameter:
hm2_5i25.stepgen.NN.step.invert_output or hm2_5i25.stepgen.NN.direction.invert_output
true or false with halcmd
- Thank you received: 4138
01 May 2018 22:16 #109959
Replied by rodw on topic Tandem X axis won't move
What version of LinuxCNC 2.7 or the development branch (master)?
If master you will need to home the machine before jogging will work.
- TRAUPMANN00
01 May 2018 23:22 #109966
by TRAUPMANN00
1. there are changes to joint.1.motor.pos-fb (...cmd) & joint.0.motor.pos-fb (...cmd) which look normal to me.
I will need a bit more assistance on employing hm2_5i25.stepgen.NN.step.invert_output. I'm new to all this .hal and .ini as well as new to python, so a bit more explanation would be great.
- TRAUPMANN00
01 May 2018 23:25 #109967
by TRAUPMANN00
I knew I forgot something in the listing.
linuxCNC 2.8.pre.....
01 May 2018 23:30 - 01 May 2018 23:30 #109970
Start your linuxcnc configuration
I think the issue was with stepgen0?
so in a terminal window type
halcmd setp hm2_5i25.stepgen.00.step.invert_output true
and
halcmd setp hm2_5i25.stepgen.00.step.invert_output false
while measuring the voltage across the STEP0+ and STEP0- pins
They should read about +5V on one case and about -5V on the other case (no load)
and
Last edit: 01 May 2018 23:30 by PCW.
- TRAUPMANN00
02 May 2018 17:08 #110040
by TRAUPMANN00
I was unsuccessful in implementing the commands to the computer as seen in image below.
(perhaps more training is involved??)
The value is set at FALSE with a voltage of 3.7V on both 00 and 01 axes.
02 May 2018 17:22 #110042
that's weird... can you try:
halcmd show param *step*
then copy/paste the proper step invert parameter name into the setp command?
Time to create page: 0.184 seconds
