Error Running VFD and Spindle
06 May 2018 18:51 - 06 May 2018 19:26 #110287 by javelin
Error Running VFD and Spindle was created by javelin
Note that I am running Linuxcnc Master.
Also I am running a 7i76e and setup via Pncconfig
I have a Huanyang VFD which I have set up as per the manpage
The error I receive when attempting to start linuxcnc is as follows:
Debug file information:
Note: Using POSIX realtime
./custom.hal:4: execv(vfd): No such file or directory
./custom.hal:4: waitpid failed vfd vfd
./custom.hal:4: vfd exited without becoming ready
5584
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Also note that when I open a terminal and use the following commands that I CAN get the spindle to run.
halrun
loadusr -W hy_vfd -d /dev/ttyUSB0
show pin
setp hy_hy_vfd.enable 1
setp hy_vfd.speed-command 600
setp hy_vfd.spindle-forward 1
setp hy_vfd.spindle-on 1
With the above terminal commands through halrun the spindle WILL turn on and run. Having discovered this I know that the usb device is wired properly to the vfd, and through halrun it is communicating properly to get the spindle moving. Nevertheless I am lost as to why Linuxcnc would give me the above mentioned error when attempting to start the program. I have attached the hal and custom hal files as well as the ini file although it may be irrelevant. If anyone can point me to the error of my ways I would greatly appreciate it.
File Name: machinetes...5-06.ini
File Size:4 KB
File Name: custom_2018-05-06.hal
File Size:0 KB
File Name: machinetes...5-06.hal
File Size:10 KB
Last edit: 06 May 2018 19:26 by javelin.
06 May 2018 20:10 - 06 May 2018 20:11 #110290 by javelin
Replied by javelin on topic Error Running VFD and Spindle
Maybe this will help you guys help me. I edited the custom hal file from this:
loadusr -W vfd hy_vfd -d /dev/ttyUSB0
to read this:
and I received this error:
open: Permission denied
./custom.hal:4: waitpid failed hy_vfd hy_vfd
./custom.hal:4: hy_vfd exited without becoing ready 9470
PID TTY Stat Time Comand
Stopping realtie threads
Last edit: 06 May 2018 20:11 by javelin.
06 May 2018 20:27 #110291 by javelin
to read this:
I answered my own question there. Thanks to an old post by andypugh I went back and charmod the permissions on the USB.. so a new update:
Linuxcnc did open with the above command so that much works.
New issue is that the commands that you will find in the custom hal file posted above are not recognized as pins. Apparently those are old pin names and not serving Master version of linuxcnc. Most documentation I can see is for 2.7. Any help with setting the right pins in the custom hal to get it running would be a great help. I am combing through the info I can find to see if I can fix this myself and will update this thread if I get it running.
06 May 2018 21:03 #110293 by javelin
SOLVED!!!
If the forum mods would like to remove this post please feel free to do so. Yet I will post new files here for the sake of posterity.
There were several problems that I had to work out. Namely most directions I found online were attempting to set up this from files generated from the stepconfig wizard and I used the pncconfig wizard. Also.... watch the flipping names of things when coding... I swear it can give you fits.
The difference between the examples you see online and when using another wizard such as the pncconfig is that with pncconfig it will wire pins for you. I had to go back and # out the pins which were wired, then go into the custom hal to rewire them.
Also there are some obvious pin name changes from some of the older examples online. If anyone wanted to see what the pins look like under Master (which isnt different from 2.7) and then compare to older versions of linuxcnc feel free to download the custom hal file I will attach. Please ignore all of the # out lines as they are useless and were other various attempts.
Now for a final question for the experts out there:
Since I had to # out the pins in the main hal file, is there any way possible that I can fix this so I do not have to go back into the main hal file to edit those pins again every time I rerun the pncconfig wizard? Once I run the wizard again it will automatically reset those wired pins back to active.
By the way, thanks guys for the great work in the past to help me figure this out. You are always awesome even for those who lurk here but may not ask many questions. The older posts by andypugh helped immensely.
File Name: machinetes...06-2.hal
File Size:10 KB
File Name: custom_201...06-2.hal
File Size:1 KB
06 May 2018 22:44 #110301 by rodw
Replied by rodw on topic Error Running VFD and Spindle
Just don't go back into pncconf. Generally its used to generate a basic config and then you edit the generated files by hand moving forward.
  • Todd Zuercher
  • Todd Zuercher's Avatar
  • Platinum Member
  • Platinum Member
07 May 2018 00:50 #110305 by Todd Zuercher
Replied by Todd Zuercher on topic Error Running VFD and Spindle
Yes, you can. If you set up your custom hal file to use the same signal names as pnccofig used. Signals and their hal pin connections can span multiple hal files.
09 May 2018 21:41 #110458 by andypugh
Replied by andypugh on topic Error Running VFD and Spindle
You can use the "unlinkp" command in the custom HAL to undo the connections made by the PnCConf-created HAL.
But, in practice, once the machine is working you shouldn't need to use PnCConf again. And once you have the config it is generally easier to make the changes directly in the HAL and INI anyway.
