LinuxCNC 2.8 Sections AXIS and JOINTS
8 years 5 months ago #110327 by Cornflakes
What are the differences in sections AXIS and JOINTS?
Parameters MIN_LIMIT, MAX_LIMIT seem to be equal in both sections
8 years 5 months ago #110345 by rodw
A joint is a motor, an axis is the cartesion direction.
In version 2.7 ech axis is hardcoded Joint 0 = X, Joint 1 = Y, Joint 2 = Z etc.
In 2.8, joints are totally independent of this and its possible to more easily define an axis that comprises multiple joints (motors). The simplest of which is a gantry, a more complex one might be a robot arm. This is a major change that affected a lot of the linuxCNC internals.
And yes, the limit of travel is usually the same for a joint and an axis in a simple 3 axis machine but maybe not if you had two joints extending a crane boom to make up 1 axis or something like that.
The following user(s) said Thank You: pklopping
8 years 5 months ago #110461 by andypugh
Cornflakes wrote: Parameters MIN_LIMIT, MAX_LIMIT seem to be equal in both sections
Most of the time they will be. But 2.8 allows them not to be where this is necessary or useful.
Time to create page: 0.313 seconds
