about MAX_ACCELERATION in ini file
  • savoyyang
  • savoyyang's Avatar Topic Author
  • Junior Member
  • Junior Member
09 May 2018 07:29 #110410 by savoyyang
about MAX_ACCELERATION in ini file was created by savoyyang
hey man ,please watch the ini file configuration .I simply ran the following two actions.
c.jog(linuxcnc.JOG_CONTINUOUS,0,15000) => jog(linuxcnc.JOG_CONTINUOUS,0,0)
The time taken for the motor speed to go from 15000 to 0 should be equal to 2.5s [ (Vt-V0)/a = t ] [(15000-0)/6000=2.5s] , but I used 5.8s actually by looking at the oscilloscope's display value. I am sure MAX_ACCELERATION = 6000.0
Is there a problem in my configuration? My motor uses position interpolation mode.
[TRAJ]
AXES = 4
COORDINATES = X Y Z A
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
HOME = 0 0 0 0
#MAX_VELOCITY = 15
#MAX_VELOCITY = 600
MAX_VELOCITY = 210000
DEFAULT_VELOCITY = 500.0
DEFAULT_ANGULAR_VELOCITY = 0.25		#45
POSITION_FILE = position.txt
MAX_LINEAR_VELOCITY = 210000.0
MAX_ANGULAR_VELOCITY = 400.0			#90
MAX_ACCELERATION = 20000.0
NO_FORCE_HOMING = 1
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_FINAL_VEL = 15
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
HOME_OFFSET = 0
HOME_IGNORE_LIMITS = yes
BACKLASH = 0.000
MAX_VELOCITY = 210000.0
#MAX_ACCELERATION = 20000.0
FERROR = 400000
MIN_FERROR = 400000.5
MIN_LIMIT = -1e99
MAX_LIMIT = 1e99
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_FINAL_VEL = 15
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
HOME_OFFSET = 0
BACKLASH = 0.000
#MAX_ACCELERATION = 40000.0
FERROR = 400000
MIN_LIMIT = -1e99
MAX_LIMIT = 1e99
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
HOME_SEARCH_VEL = 0
HOME_LATCH_VEL = 0
HOME_FINAL_VEL = 15
HOME_USE_INDEX = NO
HOME_SEQUENCE = 0
HOME_OFFSET = 0
BACKLASH = 0.000
MAX_VELOCITY = 2100.0
FERROR = 400
MIN_FERROR = 400.5
MIN_LIMIT = -1e99
MAX_LIMIT = 1e99
15 May 2018 12:18 #110755 by andypugh
Replied by andypugh on topic about MAX_ACCELERATION in ini file
jogs use [TRAJ]DEFAULT_ACCELERATION
If that entry is missing from the INI I don't know what value is used.
linuxcnc.org/docs/2.7/html/config/ini-config.html
The following user(s) said Thank You: savoyyang
Time to create page: 0.097 seconds
