Problem trying to get config to work in Preempt Rt Stretch
  • Lcvette
  • Lcvette's Avatar Topic Author
  • Platinum Member
  • Platinum Member
12 May 2018 23:52 - 13 May 2018 00:09 #110624 by Lcvette
Hello all,
I am trying to get a config to work that is currently working on another system but is not wanting to work on a preempt rt stretch install. below is the debug report, I hve checked the paths and they are correct and lead to the same files as on the other system but just don't seem to work on this system. I am very new to linuxcnc so im certain im missing something easy or maybe not but im not sure how to find it and it was not as easy a fix as the other debugs i was able to work my way through in the hal and ini file. I would certainly appreciate your help on the issue!! anything you can do that might help would be great! things i have done currently are check to see that Python is installed and it is, version 2.7.13, check to see that the files are in the folders and they are, checked the paths are correct and they are.
not sure what the next step would be?
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.11
Machine configuration directory is '/home/chris/linuxcnc/configs/VMC2'
Machine configuration file is 'VMC2.ini'
INIFILE=/home/chris/linuxcnc/configs/VMC2/VMC2.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=gmoccapy
Starting LinuxCNC...
Found file(REL): ./VMC2.hal
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: Hardware address: 00:60:1b:13:03:d6
hm2_eth: discovered 7I92
hm2/hm2_7i92.0: Smart Serial Firmware Version 43
Board hm2_7i92.0.7i77.0.0 Hardware Mode 0 = standard
Board hm2_7i92.0.7i77.0.0 Software Mode 0 = input_output
Board hm2_7i92.0.7i77.0.0 Software Mode 1 = io_analog
Board hm2_7i92.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage
Board hm2_7i92.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage
Board hm2_7i92.0.7i77.0.1 Hardware Mode 0 = standard
Board hm2_7i92.0.7i77.0.1 Software Mode 0 = analogout_enables
Board hm2_7i92.0.7i76.0.3 Hardware Mode 0 = standard
Board hm2_7i92.0.7i76.0.3 Software Mode 0 = io_spin
Board hm2_7i92.0.7i76.0.3 Software Mode 1 = io_ana_spin
Board hm2_7i92.0.7i76.0.3 Software Mode 2 = io_enc_ana_spin_fv
hm2/hm2_7i92.0: 34 I/O Pins used:
hm2/hm2_7i92.0: IO Pin 000 (P2-01): IOPort
hm2/hm2_7i92.0: IO Pin 001 (P2-14): IOPort
hm2/hm2_7i92.0: IO Pin 002 (P2-02): IOPort
hm2/hm2_7i92.0: IO Pin 003 (P2-15): Smart Serial Interface #0, pin TxData1 (Output)
hm2/hm2_7i92.0: IO Pin 004 (P2-03): Smart Serial Interface #0, pin RxData1 (Input)
hm2/hm2_7i92.0: IO Pin 005 (P2-16): Smart Serial Interface #0, pin TxData0 (Output)
hm2/hm2_7i92.0: IO Pin 006 (P2-04): Smart Serial Interface #0, pin RxData0 (Input)
hm2/hm2_7i92.0: IO Pin 007 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
hm2/hm2_7i92.0: IO Pin 008 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
hm2/hm2_7i92.0: IO Pin 009 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
hm2/hm2_7i92.0: IO Pin 010 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
hm2/hm2_7i92.0: IO Pin 011 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
hm2/hm2_7i92.0: IO Pin 012 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
hm2/hm2_7i92.0: IO Pin 013 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
hm2/hm2_7i92.0: IO Pin 014 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
hm2/hm2_7i92.0: IO Pin 015 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
hm2/hm2_7i92.0: IO Pin 016 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
hm2/hm2_7i92.0: IO Pin 017 (P1-01): StepGen #0, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 018 (P1-14): StepGen #0, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 019 (P1-02): StepGen #1, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 020 (P1-15): StepGen #1, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 021 (P1-03): StepGen #2, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 022 (P1-16): StepGen #2, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 023 (P1-04): StepGen #3, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 024 (P1-17): StepGen #3, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 025 (P1-05): StepGen #4, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 026 (P1-06): StepGen #4, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 027 (P1-07): Smart Serial Interface #0, pin TxData3 (Output)
hm2/hm2_7i92.0: IO Pin 028 (P1-08): Smart Serial Interface #0, pin RxData3 (Input)
hm2/hm2_7i92.0: IO Pin 029 (P1-09): IOPort
hm2/hm2_7i92.0: IO Pin 030 (P1-10): IOPort
hm2/hm2_7i92.0: IO Pin 031 (P1-11): IOPort
hm2/hm2_7i92.0: IO Pin 032 (P1-12): IOPort
hm2/hm2_7i92.0: IO Pin 033 (P1-13): IOPort
hm2/hm2_7i92.0: registered
Found file(REL): ./custom.hal
Starting DISPLAY program: gmoccapy
Killing task linuxcncsvr, PID=21429
Killing task milltask, PID=21475
task: 239 cycles, min=0.000007, max=0.010333, avg=0.008711, 0 latency excursions (> 10x expected cycle time of 0.010000s)
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
Debug file information:
Note: Using POSIX realtime
/home/chris/linuxcnc/configs/VMC2/VMC2.ini:121: executing 'import sys
sys.path.append("/home/chris/linuxcnc/configs/VMC2/python")'
PythonPlugin: Python '2.7.13 (default, Nov 24 2017, 17:33:09)
[GCC 6.3.0 20170516]'
is_callable(__init__) = FALSE
21429
PID TTY STAT TIME COMMAND
21475
is_callable(__delete__) = FALSE
Stopping realtime threads
Unloading hal components
Kernel message information:
[22511.979283] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[22511.979285] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[22511.979287] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[22512.027119] BUG: scheduling while atomic: irq/17-ehci_hcd/149/0x00000002
[22512.027156] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[22512.027162] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[22512.027168] Preemption disabled at:
[22512.027169] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[22512.027172] CPU: 1 PID: 149 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[22512.027173] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[22512.027176] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50541093be8
[22512.027178] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[22512.027179] ffff97c77ece9a00 ffff97c77401de80 ffff97c77401de80 ffffb50541093c28
[22512.027180] Call Trace:
[22512.027186] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[22512.027187] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[22512.027190] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[22512.027193] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[22512.027195] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[22512.027196] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[22512.027198] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[22512.027215] [<ffffffffc0485e1e>] ? usb_hcd_unmap_urb_setup_for_dma+0x9e/0xc0 [usbcore]
[22512.027223] [<ffffffffc0485e56>] ? usb_hcd_unmap_urb_for_dma+0x16/0x160 [usbcore]
[22512.027231] [<ffffffffc0485ff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[22512.027240] [<ffffffffc0486175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[22512.027242] [<ffffffff93282366>] ? __tasklet_action.isra.16+0x56/0x110
[22512.027244] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[22512.027247] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[22512.027248] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[22512.027250] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[22512.027251] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[22512.027253] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[22512.027254] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[22512.027256] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[22512.027258] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[22512.027260] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[22512.027262] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[22514.007147] BUG: scheduling while atomic: irq/17-ehci_hcd/149/0x00000002
[22514.007191] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[22514.007199] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[22514.007206] Preemption disabled at:
[22514.007206] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[22514.007210] CPU: 1 PID: 149 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[22514.007211] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[22514.007215] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50541093c00
[22514.007218] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[22514.007220] ffff97c77ece9a00 ffff97c77401de80 ffff97c77401de80 ffffb50541093c40
[22514.007220] Call Trace:
[22514.007228] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[22514.007230] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[22514.007234] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[22514.007237] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[22514.007239] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[22514.007242] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[22514.007244] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[22514.007264] [<ffffffffc0485ec9>] ? usb_hcd_unmap_urb_for_dma+0x89/0x160 [usbcore]
[22514.007276] [<ffffffffc0485ff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[22514.007287] [<ffffffffc0486175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[22514.007290] [<ffffffff93282366>] ? __tasklet_action.isra.16+0x56/0x110
[22514.007292] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[22514.007295] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[22514.007297] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[22514.007299] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[22514.007301] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[22514.007303] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[22514.007305] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[22514.007307] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[22514.007310] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[22514.007313] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[22514.007315] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[22557.555955] BUG: scheduling while atomic: irq/17-ehci_hcd/149/0x00000002
[22557.556000] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[22557.556007] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[22557.556014] Preemption disabled at:
[22557.556014] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[22557.556018] CPU: 1 PID: 149 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[22557.556019] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[22557.556023] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50541093be8
[22557.556026] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[22557.556028] ffff97c77ece9a00 ffff97c77401de80 ffff97c77401de80 ffffb50541093c28
[22557.556028] Call Trace:
[22557.556035] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[22557.556038] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[22557.556041] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[22557.556045] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[22557.556047] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[22557.556049] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[22557.556052] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[22557.556071] [<ffffffffc0485e1e>] ? usb_hcd_unmap_urb_setup_for_dma+0x9e/0xc0 [usbcore]
[22557.556082] [<ffffffffc0485e56>] ? usb_hcd_unmap_urb_for_dma+0x16/0x160 [usbcore]
[22557.556093] [<ffffffffc0485ff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[22557.556104] [<ffffffffc0486175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[22557.556107] [<ffffffff93282366>] ? __tasklet_action.isra.16+0x56/0x110
[22557.556109] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[22557.556113] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[22557.556115] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[22557.556116] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[22557.556118] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[22557.556120] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[22557.556123] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[22557.556124] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[22557.556127] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[22557.556130] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[22557.556132] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[22643.457468] BUG: scheduling while atomic: irq/17-ehci_hcd/149/0x00000002
[22643.457504] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[22643.457511] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[22643.457516] Preemption disabled at:
[22643.457516] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[22643.457519] CPU: 1 PID: 149 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[22643.457520] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[22643.457523] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50541093c00
[22643.457524] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[22643.457526] ffff97c77ece9a00 ffff97c77401de80 ffff97c77401de80 ffffb50541093c40
[22643.457526] Call Trace:
[22643.457531] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[22643.457533] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[22643.457536] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[22643.457538] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[22643.457540] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[22643.457542] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[22643.457544] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[22643.457560] [<ffffffffc0485ec9>] ? usb_hcd_unmap_urb_for_dma+0x89/0x160 [usbcore]
[22643.457567] [<ffffffffc0485ff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[22643.457573] [<ffffffffc0486175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[22643.457575] [<ffffffff93282366>] ? __tasklet_action.isra.16+0x56/0x110
[22643.457577] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[22643.457579] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[22643.457580] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[22643.457581] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[22643.457582] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[22643.457584] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[22643.457585] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[22643.457586] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[22643.457588] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[22643.457590] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[22643.457591] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[22645.261516] BUG: scheduling while atomic: irq/17-ehci_hcd/149/0x00000002
[22645.261551] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[22645.261557] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[22645.261562] Preemption disabled at:
[22645.261562] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[22645.261565] CPU: 1 PID: 149 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[22645.261566] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[22645.261569] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50541093c00
[22645.261571] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[22645.261572] ffff97c77ece9a00 ffff97c77401de80 ffff97c77401de80 ffffb50541093c40
[22645.261573] Call Trace:
[22645.261578] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[22645.261579] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[22645.261582] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[22645.261585] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[22645.261586] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[22645.261588] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[22645.261590] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[22645.261607] [<ffffffffc0485ec9>] ? usb_hcd_unmap_urb_for_dma+0x89/0x160 [usbcore]
[22645.261613] [<ffffffffc0485ff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[22645.261620] [<ffffffffc0486175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[22645.261622] [<ffffffff93282366>] ? __tasklet_action.isra.16+0x56/0x110
[22645.261624] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[22645.261626] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[22645.261627] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[22645.261628] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[22645.261630] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[22645.261631] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[22645.261632] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[22645.261633] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[22645.261635] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[22645.261637] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[22645.261638] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[22646.161543] BUG: scheduling while atomic: irq/17-ehci_hcd/149/0x00000002
[22646.161578] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[22646.161584] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[22646.161590] Preemption disabled at:
[22646.161590] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[22646.161593] CPU: 1 PID: 149 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[22646.161593] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[22646.161597] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50541093c00
[22646.161599] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[22646.161600] ffff97c77ece9a00 ffff97c77401de80 ffff97c77401de80 ffffb50541093c40
[22646.161601] Call Trace:
[22646.161606] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[22646.161607] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[22646.161610] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[22646.161612] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[22646.161614] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[22646.161615] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[22646.161617] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[22646.161636] [<ffffffffc0485ec9>] ? usb_hcd_unmap_urb_for_dma+0x89/0x160 [usbcore]
[22646.161643] [<ffffffffc0485ff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[22646.161649] [<ffffffffc0486175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[22646.161652] [<ffffffff93282366>] ? __tasklet_action.isra.16+0x56/0x110
[22646.161653] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[22646.161656] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[22646.161657] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[22646.161658] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[22646.161660] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[22646.161661] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[22646.161662] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[22646.161663] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[22646.161666] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[22646.161668] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[22646.161669] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[22648.093556] BUG: scheduling while atomic: irq/17-ehci_hcd/149/0x00000002
[22648.093591] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[22648.093597] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[22648.093603] Preemption disabled at:
[22648.093603] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[22648.093605] CPU: 1 PID: 149 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[22648.093606] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[22648.093609] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50541093be8
[22648.093611] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[22648.093612] ffff97c77ece9a00 ffff97c77401de80 ffff97c77401de80 ffffb50541093c28
[22648.093612] Call Trace:
[22648.093618] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[22648.093620] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[22648.093622] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[22648.093625] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[22648.093626] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[22648.093628] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[22648.093630] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[22648.093649] [<ffffffffc0485e1e>] ? usb_hcd_unmap_urb_setup_for_dma+0x9e/0xc0 [usbcore]
[22648.093656] [<ffffffffc0485e56>] ? usb_hcd_unmap_urb_for_dma+0x16/0x160 [usbcore]
[22648.093662] [<ffffffffc0485ff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[22648.093669] [<ffffffffc0486175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[22648.093671] [<ffffffff93282366>] ? __tasklet_action.isra.16+0x56/0x110
[22648.093672] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[22648.093674] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[22648.093676] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[22648.093677] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[22648.093678] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[22648.093679] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[22648.093680] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[22648.093681] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[22648.093683] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[22648.093685] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[22648.093686] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[22648.157547] BUG: scheduling while atomic: irq/17-ehci_hcd/149/0x00000002
[22648.157580] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[22648.157586] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[22648.157592] Preemption disabled at:
[22648.157592] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[22648.157594] CPU: 1 PID: 149 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[22648.157595] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[22648.157599] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50541093c00
[22648.157600] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[22648.157601] ffff97c77ece9a00 ffff97c77401de80 ffff97c77401de80 ffffb50541093c40
[22648.157602] Call Trace:
[22648.157607] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[22648.157609] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[22648.157611] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[22648.157614] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[22648.157615] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[22648.157617] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[22648.157619] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[22648.157637] [<ffffffffc0485ec9>] ? usb_hcd_unmap_urb_for_dma+0x89/0x160 [usbcore]
[22648.157644] [<ffffffffc0485ff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[22648.157650] [<ffffffffc0486175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[22648.157652] [<ffffffff93282366>] ? __tasklet_action.isra.16+0x56/0x110
[22648.157654] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[22648.157656] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[22648.157657] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[22648.157658] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[22648.157659] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[22648.157661] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[22648.157662] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[22648.157663] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[22648.157665] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[22648.157666] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[22648.157668] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[22664.937853] BUG: scheduling while atomic: irq/17-ehci_hcd/149/0x00000002
[22664.937889] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[22664.937895] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[22664.937901] Preemption disabled at:
[22664.937901] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[22664.937904] CPU: 1 PID: 149 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[22664.937904] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[22664.937908] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50541093be8
[22664.937910] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[22664.937911] ffff97c77ece9a00 ffff97c77401de80 ffff97c77401de80 ffffb50541093c28
[22664.937912] Call Trace:
[22664.937918] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[22664.937919] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[22664.937922] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[22664.937924] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[22664.937926] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[22664.937927] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[22664.937929] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[22664.937950] [<ffffffffc0485e1e>] ? usb_hcd_unmap_urb_setup_for_dma+0x9e/0xc0 [usbcore]
[22664.937956] [<ffffffffc0485e56>] ? usb_hcd_unmap_urb_for_dma+0x16/0x160 [usbcore]
[22664.937963] [<ffffffffc0485ff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[22664.937969] [<ffffffffc0486175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[22664.937972] [<ffffffff93282366>] ? __tasklet_action.isra.16+0x56/0x110
[22664.937973] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[22664.937975] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[22664.937977] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[22664.937978] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[22664.937979] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[22664.937980] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[22664.937981] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[22664.937982] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[22664.937985] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[22664.937986] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[22664.937988] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[22673.330010] BUG: scheduling while atomic: irq/17-ehci_hcd/149/0x00000002
[22673.330049] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[22673.330055] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[22673.330061] Preemption disabled at:
[22673.330061] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[22673.330064] CPU: 1 PID: 149 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[22673.330065] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[22673.330068] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50541093be8
[22673.330070] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[22673.330072] ffff97c77ece9a00 ffff97c77401de80 ffff97c77401de80 ffffb50541093c28
[22673.330072] Call Trace:
[22673.330078] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[22673.330080] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[22673.330083] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[22673.330086] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[22673.330088] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[22673.330089] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[22673.330091] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[22673.330112] [<ffffffffc0485e1e>] ? usb_hcd_unmap_urb_setup_for_dma+0x9e/0xc0 [usbcore]
[22673.330120] [<ffffffffc0485e56>] ? usb_hcd_unmap_urb_for_dma+0x16/0x160 [usbcore]
[22673.330128] [<ffffffffc0485ff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[22673.330136] [<ffffffffc0486175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[22673.330139] [<ffffffff93282366>] ? __tasklet_action.isra.16+0x56/0x110
[22673.330141] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[22673.330144] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[22673.330146] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[22673.330147] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[22673.330149] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[22673.330150] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[22673.330152] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[22673.330153] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[22673.330156] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[22673.330158] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[22673.330160] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[22675.122055] BUG: scheduling while atomic: irq/17-ehci_hcd/149/0x00000002
[22675.122093] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[22675.122100] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[22675.122107] Preemption disabled at:
[22675.122107] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[22675.122111] CPU: 1 PID: 149 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[22675.122112] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[22675.122115] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50541093c00
[22675.122117] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[22675.122118] ffff97c77ece9a00 ffff97c77401de80 ffff97c77401de80 ffffb50541093c40
[22675.122119] Call Trace:
[22675.122125] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[22675.122126] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[22675.122129] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[22675.122132] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[22675.122134] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[22675.122135] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[22675.122137] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[22675.122160] [<ffffffffc0485ec9>] ? usb_hcd_unmap_urb_for_dma+0x89/0x160 [usbcore]
[22675.122167] [<ffffffffc0485ff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[22675.122174] [<ffffffffc0486175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[22675.122177] [<ffffffff93282366>] ? __tasklet_action.isra.16+0x56/0x110
[22675.122178] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[22675.122181] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[22675.122182] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[22675.122183] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[22675.122184] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[22675.122185] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[22675.122187] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[22675.122188] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[22675.122190] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[22675.122191] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[22675.122193] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[22678.010078] BUG: scheduling while atomic: irq/17-ehci_hcd/149/0x00000002
[22678.010113] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[22678.010120] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[22678.010126] Preemption disabled at:
[22678.010126] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[22678.010129] CPU: 1 PID: 149 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[22678.010130] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[22678.010133] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50541093be8
[22678.010134] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[22678.010136] ffff97c77ece9a00 ffff97c77401de80 ffff97c77401de80 ffffb50541093c28
[22678.010136] Call Trace:
[22678.010142] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[22678.010143] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[22678.010146] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[22678.010149] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[22678.010150] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[22678.010151] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[22678.010153] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[22678.010172] [<ffffffffc0485e1e>] ? usb_hcd_unmap_urb_setup_for_dma+0x9e/0xc0 [usbcore]
[22678.010179] [<ffffffffc0485e56>] ? usb_hcd_unmap_urb_for_dma+0x16/0x160 [usbcore]
[22678.010186] [<ffffffffc0485ff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[22678.010192] [<ffffffffc0486175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[22678.010194] [<ffffffff93282366>] ? __tasklet_action.isra.16+0x56/0x110
[22678.010196] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[22678.010198] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[22678.010199] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[22678.010200] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[22678.010202] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[22678.010203] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[22678.010204] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[22678.010205] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[22678.010207] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[22678.010209] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[22678.010210] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[22682.666163] BUG: scheduling while atomic: irq/17-ehci_hcd/149/0x00000002
[22682.666195] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[22682.666200] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[22682.666206] Preemption disabled at:
[22682.666206] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[22682.666208] CPU: 1 PID: 149 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[22682.666209] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[22682.666212] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50541093be8
[22682.666213] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[22682.666214] ffff97c77ece9a00 ffff97c77401de80 ffff97c77401de80 ffffb50541093c28
[22682.666215] Call Trace:
[22682.666220] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[22682.666222] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[22682.666224] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[22682.666226] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[22682.666228] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[22682.666229] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[22682.666231] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[22682.666247] [<ffffffffc0485e1e>] ? usb_hcd_unmap_urb_setup_for_dma+0x9e/0xc0 [usbcore]
[22682.666253] [<ffffffffc0485e56>] ? usb_hcd_unmap_urb_for_dma+0x16/0x160 [usbcore]
[22682.666259] [<ffffffffc0485ff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[22682.666265] [<ffffffffc0486175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[22682.666267] [<ffffffff93282366>] ? __tasklet_action.isra.16+0x56/0x110
[22682.666268] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[22682.666270] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[22682.666271] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[22682.666272] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[22682.666273] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[22682.666275] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[22682.666276] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[22682.666277] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[22682.666279] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[22682.666280] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[22682.666281] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[22686.342241] BUG: scheduling while atomic: irq/17-ehci_hcd/149/0x00000002
[22686.342289] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[22686.342297] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[22686.342305] Preemption disabled at:
[22686.342305] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[22686.342309] CPU: 1 PID: 149 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[22686.342309] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[22686.342313] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50541093c00
[22686.342315] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[22686.342316] ffff97c77ece9a00 ffff97c77401de80 ffff97c77401de80 ffffb50541093c40
[22686.342317] Call Trace:
[22686.342326] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[22686.342327] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[22686.342330] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[22686.342333] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[22686.342334] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[22686.342336] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[22686.342338] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[22686.342366] [<ffffffffc0485ec9>] ? usb_hcd_unmap_urb_for_dma+0x89/0x160 [usbcore]
[22686.342373] [<ffffffffc0485ff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[22686.342380] [<ffffffffc0486175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[22686.342384] [<ffffffff93282366>] ? __tasklet_action.isra.16+0x56/0x110
[22686.342385] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[22686.342388] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[22686.342390] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[22686.342391] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[22686.342392] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[22686.342393] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[22686.342395] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[22686.342396] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[22686.342399] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[22686.342401] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[22686.342402] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[22689.130303] BUG: scheduling while atomic: irq/17-ehci_hcd/149/0x00000002
[22689.130381] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[22689.130393] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[22689.130405] Preemption disabled at:
[22689.130405] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[22689.130411] CPU: 1 PID: 149 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[22689.130411] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[22689.130417] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50541093be8
[22689.130420] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[22689.130422] ffff97c77ece9a00 ffff97c77401de80 ffff97c77401de80 ffffb50541093c28
[22689.130423] Call Trace:
[22689.130436] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[22689.130437] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[22689.130444] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[22689.130449] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[22689.130450] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[22689.130452] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[22689.130454] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[22689.130513] [<ffffffffc0485e1e>] ? usb_hcd_unmap_urb_setup_for_dma+0x9e/0xc0 [usbcore]
[22689.130522] [<ffffffffc0485e56>] ? usb_hcd_unmap_urb_for_dma+0x16/0x160 [usbcore]
[22689.130531] [<ffffffffc0485ff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[22689.130540] [<ffffffffc0486175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[22689.130545] [<ffffffff93282366>] ? __tasklet_action.isra.16+0x56/0x110
[22689.130547] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[22689.130552] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[22689.130553] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[22689.130555] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[22689.130556] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[22689.130559] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[22689.130560] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[22689.130562] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[22689.130565] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[22689.130567] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[22689.130570] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[22716.266766] BUG: scheduling while atomic: irq/17-ehci_hcd/149/0x00000002
[22716.266801] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[22716.266808] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[22716.266814] Preemption disabled at:
[22716.266814] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[22716.266817] CPU: 1 PID: 149 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[22716.266818] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[22716.266821] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50541093be8
[22716.266823] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[22716.266824] ffff97c77ece9a00 ffff97c77401de80 ffff97c77401de80 ffffb50541093c28
[22716.266825] Call Trace:
[22716.266830] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[22716.266832] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[22716.266834] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[22716.266837] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[22716.266838] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[22716.266840] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[22716.266841] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[22716.266857] [<ffffffffc0485e1e>] ? usb_hcd_unmap_urb_setup_for_dma+0x9e/0xc0 [usbcore]
[22716.266864] [<ffffffffc0485e56>] ? usb_hcd_unmap_urb_for_dma+0x16/0x160 [usbcore]
[22716.266871] [<ffffffffc0485ff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[22716.266878] [<ffffffffc0486175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[22716.266880] [<ffffffff93282366>] ? __tasklet_action.isra.16+0x56/0x110
[22716.266882] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[22716.266884] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[22716.266886] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[22716.266887] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[22716.266888] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[22716.266889] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[22716.266891] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[22716.266892] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[22716.266894] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[22716.266896] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[22716.266897] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[22716.338766] BUG: scheduling while atomic: irq/17-ehci_hcd/149/0x00000002
[22716.338801] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[22716.338807] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[22716.338813] Preemption disabled at:
[22716.338813] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[22716.338816] CPU: 1 PID: 149 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[22716.338817] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[22716.338820] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50541093c00
[22716.338822] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[22716.338823] ffff97c77ece9a00 ffff97c77401de80 ffff97c77401de80 ffffb50541093c40
[22716.338824] Call Trace:
[22716.338830] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[22716.338831] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[22716.338834] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[22716.338837] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[22716.338838] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[22716.338840] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[22716.338842] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[22716.338860] [<ffffffffc0485ec9>] ? usb_hcd_unmap_urb_for_dma+0x89/0x160 [usbcore]
[22716.338867] [<ffffffffc0485ff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[22716.338873] [<ffffffffc0486175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[22716.338875] [<ffffffff93282366>] ? __tasklet_action.isra.16+0x56/0x110
[22716.338877] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[22716.338879] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[22716.338880] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[22716.338881] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[22716.338882] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[22716.338884] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[22716.338885] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[22716.338886] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[22716.338888] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[22716.338890] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[22716.338891] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[22724.802903] BUG: scheduling while atomic: irq/17-ehci_hcd/149/0x00000002
[22724.802938] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[22724.802944] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[22724.802950] Preemption disabled at:
[22724.802950] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[22724.802953] CPU: 1 PID: 149 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[22724.802954] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[22724.802957] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50541093c00
[22724.802958] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[22724.802960] ffff97c77ece9a00 ffff97c77401de80 ffff97c77401de80 ffffb50541093c40
[22724.802960] Call Trace:
[22724.802965] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[22724.802967] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[22724.802970] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[22724.802973] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[22724.802974] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[22724.802976] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[22724.802977] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[22724.802999] [<ffffffffc0485ec9>] ? usb_hcd_unmap_urb_for_dma+0x89/0x160 [usbcore]
[22724.803006] [<ffffffffc0485ff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[22724.803012] [<ffffffffc0486175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[22724.803015] [<ffffffff93282366>] ? __tasklet_action.isra.16+0x56/0x110
[22724.803016] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[22724.803018] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[22724.803019] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[22724.803021] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[22724.803022] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[22724.803023] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[22724.803024] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[22724.803025] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[22724.803028] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[22724.803029] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[22724.803031] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[22751.847391] BUG: scheduling while atomic: irq/17-ehci_hcd/149/0x00000002
[22751.847449] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[22751.847459] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[22751.847468] Preemption disabled at:
[22751.847468] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[22751.847474] CPU: 1 PID: 149 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[22751.847475] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[22751.847481] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50541093c00
[22751.847484] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[22751.847487] ffff97c77ece9a00 ffff97c77401de80 ffff97c77401de80 ffffb50541093c40
[22751.847488] Call Trace:
[22751.847497] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[22751.847500] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[22751.847505] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[22751.847509] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[22751.847512] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[22751.847516] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[22751.847519] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[22751.847543] [<ffffffffc0485ec9>] ? usb_hcd_unmap_urb_for_dma+0x89/0x160 [usbcore]
[22751.847558] [<ffffffffc0485ff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[22751.847573] [<ffffffffc0486175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[22751.847578] [<ffffffff93282366>] ? __tasklet_action.isra.16+0x56/0x110
[22751.847581] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[22751.847585] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[22751.847588] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[22751.847590] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[22751.847593] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[22751.847596] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[22751.847598] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[22751.847601] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[22751.847605] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[22751.847608] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[22751.847611] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[22783.588007] BUG: scheduling while atomic: irq/17-ehci_hcd/149/0x00000002
[22783.588058] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[22783.588067] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[22783.588074] Preemption disabled at:
[22783.588074] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[22783.588078] CPU: 1 PID: 149 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[22783.588079] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[22783.588084] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50541093be8
[22783.588087] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[22783.588089] ffff97c77ece9a00 ffff97c77401de80 ffff97c77401de80 ffffb50541093c28
[22783.588089] Call Trace:
[22783.588096] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[22783.588099] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[22783.588103] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[22783.588106] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[22783.588109] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[22783.588112] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[22783.588115] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[22783.588139] [<ffffffffc0485e1e>] ? usb_hcd_unmap_urb_setup_for_dma+0x9e/0xc0 [usbcore]
[22783.588152] [<ffffffffc0485e56>] ? usb_hcd_unmap_urb_for_dma+0x16/0x160 [usbcore]
[22783.588163] [<ffffffffc0485ff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[22783.588175] [<ffffffffc0486175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[22783.588179] [<ffffffff93282366>] ? __tasklet_action.isra.16+0x56/0x110
[22783.588182] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[22783.588185] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[22783.588187] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[22783.588189] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[22783.588191] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[22783.588194] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[22783.588196] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[22783.588198] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[22783.588201] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[22783.588204] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[22783.588206] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[22796.836143] BUG: scheduling while atomic: irq/17-ehci_hcd/149/0x00000002
[22796.836177] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[22796.836183] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[22796.836188] Preemption disabled at:
[22796.836189] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[22796.836191] CPU: 1 PID: 149 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[22796.836192] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[22796.836195] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50541093be8
[22796.836196] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[22796.836198] ffff97c77ece9a00 ffff97c77401de80 ffff97c77401de80 ffffb50541093c28
[22796.836198] Call Trace:
[22796.836204] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[22796.836205] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[22796.836208] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[22796.836211] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[22796.836212] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[22796.836214] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[22796.836216] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[22796.836232] [<ffffffffc0485e1e>] ? usb_hcd_unmap_urb_setup_for_dma+0x9e/0xc0 [usbcore]
[22796.836239] [<ffffffffc0485e56>] ? usb_hcd_unmap_urb_for_dma+0x16/0x160 [usbcore]
[22796.836246] [<ffffffffc0485ff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[22796.836253] [<ffffffffc0486175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[22796.836255] [<ffffffff93282366>] ? __tasklet_action.isra.16+0x56/0x110
[22796.836257] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[22796.836259] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[22796.836260] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[22796.836262] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[22796.836263] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[22796.836264] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[22796.836265] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[22796.836267] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[22796.836269] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[22796.836270] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[22796.836272] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[22917.590244] BUG: scheduling while atomic: irq/17-ehci_hcd/149/0x00000002
[22917.590302] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[22917.590311] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[22917.590320] Preemption disabled at:
[22917.590320] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[22917.590325] CPU: 1 PID: 149 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[22917.590326] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[22917.590332] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50541093be8
[22917.590335] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[22917.590338] ffff97c77ece9a00 ffff97c77401de80 ffff97c77401de80 ffffb50541093c28
[22917.590339] Call Trace:
[22917.590347] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[22917.590351] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[22917.590355] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[22917.590360] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[22917.590363] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[22917.590366] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[22917.590370] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[22917.590394] [<ffffffffc0485e1e>] ? usb_hcd_unmap_urb_setup_for_dma+0x9e/0xc0 [usbcore]
[22917.590409] [<ffffffffc0485e56>] ? usb_hcd_unmap_urb_for_dma+0x16/0x160 [usbcore]
[22917.590424] [<ffffffffc0485ff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[22917.590440] [<ffffffffc0486175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[22917.590444] [<ffffffff93282366>] ? __tasklet_action.isra.16+0x56/0x110
[22917.590447] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[22917.590451] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[22917.590453] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[22917.590456] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[22917.590458] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[22917.590461] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[22917.590464] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[22917.590467] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[22917.590471] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[22917.590474] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[22917.590477] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[23133.861884] BUG: scheduling while atomic: irq/27-enp3s0/534/0x00000002
[23133.861929] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[23133.861937] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[23133.861944] Preemption disabled at:
[23133.861945] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[23133.861948] CPU: 1 PID: 534 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[23133.861949] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[23133.861954] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50542e0bb90
[23133.861957] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[23133.861959] ffff97c77ece9a00 ffff97c778960000 ffff97c778960000 ffffb50542e0bbd0
[23133.861960] Call Trace:
[23133.861968] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[23133.861970] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[23133.861974] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[23133.861977] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[23133.861980] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[23133.861982] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[23133.861985] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[23133.861993] [<ffffffffc06b2541>] ? rtl8169_poll+0x421/0x660 [r8169]
[23133.861997] [<ffffffff9371eea1>] ? net_rx_action+0x311/0x490
[23133.862001] [<ffffffff932277e3>] ? __switch_to+0x343/0x7d0
[23133.862005] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[23133.862008] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[23133.862010] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[23133.862012] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[23133.862014] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[23133.862016] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[23133.862018] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[23133.862020] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[23133.862022] [<ffffffff93281637>] ? do_group_exit+0x47/0xc0
[23133.862025] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[23133.862028] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[23133.862030] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[23133.909903] BUG: scheduling while atomic: irq/27-enp3s0/534/0x00000002
[23133.909937] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[23133.909944] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[23133.909948] Preemption disabled at:
[23133.909948] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[23133.909951] CPU: 1 PID: 534 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[23133.909952] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[23133.909956] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50542e0bb90
[23133.909958] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[23133.909961] ffff97c77ece9a00 ffff97c778960000 ffff97c778960000 ffffb50542e0bbd0
[23133.909961] Call Trace:
[23133.909966] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[23133.909968] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[23133.909972] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[23133.909975] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[23133.909978] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[23133.909981] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[23133.909984] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[23133.909991] [<ffffffffc06b2541>] ? rtl8169_poll+0x421/0x660 [r8169]
[23133.909995] [<ffffffff9371eea1>] ? net_rx_action+0x311/0x490
[23133.909999] [<ffffffff932277e3>] ? __switch_to+0x343/0x7d0
[23133.910002] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[23133.910005] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[23133.910007] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[23133.910009] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[23133.910011] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[23133.910014] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[23133.910016] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[23133.910018] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[23133.910020] [<ffffffff93281637>] ? do_group_exit+0x47/0xc0
[23133.910022] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[23133.910025] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[23133.910027] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[23133.957892] BUG: scheduling while atomic: irq/27-enp3s0/534/0x00000002
[23133.957925] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[23133.957931] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[23133.957935] Preemption disabled at:
[23133.957935] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[23133.957938] CPU: 1 PID: 534 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[23133.957939] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[23133.957942] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50542e0bb90
[23133.957945] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[23133.957948] ffff97c77ece9a00 ffff97c778960000 ffff97c778960000 ffffb50542e0bbd0
[23133.957948] Call Trace:
[23133.957952] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[23133.957954] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[23133.957958] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[23133.957960] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[23133.957963] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[23133.957966] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[23133.957968] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[23133.957974] [<ffffffffc06b2541>] ? rtl8169_poll+0x421/0x660 [r8169]
[23133.957977] [<ffffffff9371eea1>] ? net_rx_action+0x311/0x490
[23133.957981] [<ffffffff932277e3>] ? __switch_to+0x343/0x7d0
[23133.957984] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[23133.957987] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[23133.957989] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[23133.957991] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[23133.957993] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[23133.957995] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[23133.957998] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[23133.958000] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[23133.958002] [<ffffffff93281637>] ? do_group_exit+0x47/0xc0
[23133.958004] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[23133.958007] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[23133.958009] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[23134.021912] BUG: scheduling while atomic: irq/27-enp3s0/534/0x00000002
[23134.021960] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[23134.021968] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[23134.021974] Preemption disabled at:
[23134.021975] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[23134.021979] CPU: 1 PID: 534 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[23134.021980] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[23134.021985] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50542e0bb90
[23134.021987] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[23134.021990] ffff97c77ece9a00 ffff97c778960000 ffff97c778960000 ffffb50542e0bbd0
[23134.021990] Call Trace:
[23134.021997] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[23134.022000] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[23134.022004] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[23134.022008] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[23134.022010] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[23134.022013] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[23134.022016] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[23134.022024] [<ffffffffc06b2541>] ? rtl8169_poll+0x421/0x660 [r8169]
[23134.022028] [<ffffffff9371eea1>] ? net_rx_action+0x311/0x490
[23134.022032] [<ffffffff932277e3>] ? __switch_to+0x343/0x7d0
[23134.022035] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[23134.022038] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[23134.022041] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[23134.022043] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[23134.022045] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[23134.022047] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[23134.022049] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[23134.022051] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[23134.022053] [<ffffffff93281637>] ? do_group_exit+0x47/0xc0
[23134.022056] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[23134.022059] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[23134.022061] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[23134.037917] BUG: scheduling while atomic: irq/27-enp3s0/534/0x00000002
[23134.037961] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[23134.037968] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[23134.037975] Preemption disabled at:
[23134.037975] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[23134.037979] CPU: 1 PID: 534 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[23134.037980] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[23134.037985] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50542e0bb90
[23134.037988] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[23134.037990] ffff97c77ece9a00 ffff97c778960000 ffff97c778960000 ffffb50542e0bbd0
[23134.037991] Call Trace:
[23134.037998] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[23134.038000] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[23134.038003] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[23134.038007] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[23134.038009] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[23134.038012] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[23134.038015] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[23134.038023] [<ffffffffc06b2541>] ? rtl8169_poll+0x421/0x660 [r8169]
[23134.038026] [<ffffffff9371eea1>] ? net_rx_action+0x311/0x490
[23134.038030] [<ffffffff932277e3>] ? __switch_to+0x343/0x7d0
[23134.038034] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[23134.038037] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[23134.038039] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[23134.038041] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[23134.038043] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[23134.038045] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[23134.038048] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[23134.038050] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[23134.038051] [<ffffffff93281637>] ? do_group_exit+0x47/0xc0
[23134.038055] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[23134.038057] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[23134.038059] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[23134.053890] BUG: scheduling while atomic: irq/27-enp3s0/534/0x00000002
[23134.053933] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[23134.053940] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[23134.053947] Preemption disabled at:
[23134.053947] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[23134.053951] CPU: 1 PID: 534 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[23134.053952] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[23134.053957] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50542e0bb90
[23134.053959] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[23134.053961] ffff97c77ece9a00 ffff97c778960000 ffff97c778960000 ffffb50542e0bbd0
[23134.053962] Call Trace:
[23134.053969] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[23134.053972] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[23134.053975] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[23134.053979] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[23134.053981] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[23134.053984] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[23134.053986] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[23134.053995] [<ffffffffc06b2541>] ? rtl8169_poll+0x421/0x660 [r8169]
[23134.053999] [<ffffffff9371eea1>] ? net_rx_action+0x311/0x490
[23134.054003] [<ffffffff932277e3>] ? __switch_to+0x343/0x7d0
[23134.054007] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[23134.054010] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[23134.054013] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[23134.054015] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[23134.054017] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[23134.054019] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[23134.054021] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[23134.054023] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[23134.054025] [<ffffffff93281637>] ? do_group_exit+0x47/0xc0
[23134.054028] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[23134.054031] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[23134.054033] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[23134.085924] BUG: scheduling while atomic: irq/27-enp3s0/534/0x00000002
[23134.085969] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[23134.085977] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[23134.085984] Preemption disabled at:
[23134.085984] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[23134.085988] CPU: 1 PID: 534 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[23134.085989] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[23134.085993] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50542e0bb90
[23134.085995] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[23134.085998] ffff97c77ece9a00 ffff97c778960000 ffff97c778960000 ffffb50542e0bbd0
[23134.085998] Call Trace:
[23134.086005] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[23134.086008] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[23134.086011] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[23134.086014] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[23134.086017] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[23134.086020] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[23134.086022] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[23134.086030] [<ffffffffc06b2541>] ? rtl8169_poll+0x421/0x660 [r8169]
[23134.086034] [<ffffffff9371eea1>] ? net_rx_action+0x311/0x490
[23134.086038] [<ffffffff932277e3>] ? __switch_to+0x343/0x7d0
[23134.086041] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[23134.086044] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[23134.086046] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[23134.086049] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[23134.086051] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[23134.086053] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[23134.086055] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[23134.086057] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[23134.086059] [<ffffffff93281637>] ? do_group_exit+0x47/0xc0
[23134.086062] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[23134.086065] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[23134.086067] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[23134.101898] BUG: scheduling while atomic: irq/27-enp3s0/534/0x00000002
[23134.101946] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[23134.101954] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[23134.101961] Preemption disabled at:
[23134.101961] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[23134.101965] CPU: 1 PID: 534 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[23134.101966] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[23134.101971] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50542e0bb90
[23134.101974] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[23134.101976] ffff97c77ece9a00 ffff97c778960000 ffff97c778960000 ffffb50542e0bbd0
[23134.101977] Call Trace:
[23134.101984] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[23134.101986] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[23134.101990] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[23134.101993] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[23134.101996] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[23134.101998] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[23134.102001] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[23134.102009] [<ffffffffc06b2541>] ? rtl8169_poll+0x421/0x660 [r8169]
[23134.102012] [<ffffffff9371eea1>] ? net_rx_action+0x311/0x490
[23134.102016] [<ffffffff932277e3>] ? __switch_to+0x343/0x7d0
[23134.102019] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[23134.102022] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[23134.102024] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[23134.102027] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[23134.102028] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[23134.102031] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[23134.102033] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[23134.102035] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[23134.102037] [<ffffffff93281637>] ? do_group_exit+0x47/0xc0
[23134.102040] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[23134.102043] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[23134.102045] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[23134.181889] BUG: scheduling while atomic: irq/27-enp3s0/534/0x00000002
[23134.181934] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[23134.181942] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[23134.181949] Preemption disabled at:
[23134.181949] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[23134.181953] CPU: 1 PID: 534 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[23134.181954] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[23134.181959] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50542e0bb90
[23134.181962] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[23134.181964] ffff97c77ece9a00 ffff97c778960000 ffff97c778960000 ffffb50542e0bbd0
[23134.181965] Call Trace:
[23134.181972] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[23134.181974] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[23134.181978] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[23134.181982] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[23134.181985] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[23134.181987] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[23134.181990] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[23134.181999] [<ffffffffc06b2541>] ? rtl8169_poll+0x421/0x660 [r8169]
[23134.182003] [<ffffffff9371eea1>] ? net_rx_action+0x311/0x490
[23134.182008] [<ffffffff932277e3>] ? __switch_to+0x343/0x7d0
[23134.182012] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[23134.182016] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[23134.182018] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[23134.182020] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[23134.182022] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[23134.182025] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[23134.182027] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[23134.182029] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[23134.182031] [<ffffffff93281637>] ? do_group_exit+0x47/0xc0
[23134.182034] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[23134.182037] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[23134.182039] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[23134.293904] BUG: scheduling while atomic: irq/27-enp3s0/534/0x00000002
[23134.293950] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[23134.293958] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[23134.293965] Preemption disabled at:
[23134.293965] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[23134.293969] CPU: 1 PID: 534 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[23134.293970] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[23134.293975] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50542e0bb90
[23134.293978] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[23134.293980] ffff97c77ece9a00 ffff97c778960000 ffff97c778960000 ffffb50542e0bbd0
[23134.293981] Call Trace:
[23134.293988] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[23134.293991] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[23134.293994] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[23134.293998] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[23134.294001] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[23134.294004] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[23134.294006] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[23134.294014] [<ffffffffc06b2541>] ? rtl8169_poll+0x421/0x660 [r8169]
[23134.294018] [<ffffffff9371eea1>] ? net_rx_action+0x311/0x490
[23134.294022] [<ffffffff932277e3>] ? __switch_to+0x343/0x7d0
[23134.294026] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[23134.294029] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[23134.294031] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[23134.294033] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[23134.294035] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[23134.294037] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[23134.294039] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[23134.294041] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[23134.294043] [<ffffffff93281637>] ? do_group_exit+0x47/0xc0
[23134.294046] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[23134.294049] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[23134.294051] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[23134.309891] BUG: scheduling while atomic: irq/27-enp3s0/534/0x00000002
[23134.309921] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[23134.309926] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[23134.309930] Preemption disabled at:
[23134.309930] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[23134.309933] CPU: 1 PID: 534 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[23134.309934] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[23134.309937] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50542e0bb90
[23134.309940] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[23134.309942] ffff97c77ece9a00 ffff97c778960000 ffff97c778960000 ffffb50542e0bbd0
[23134.309943] Call Trace:
[23134.309947] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[23134.309949] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[23134.309952] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[23134.309955] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[23134.309958] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[23134.309961] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[23134.309965] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[23134.309971] [<ffffffffc06b2541>] ? rtl8169_poll+0x421/0x660 [r8169]
[23134.309974] [<ffffffff9371eea1>] ? net_rx_action+0x311/0x490
[23134.309978] [<ffffffff932277e3>] ? __switch_to+0x343/0x7d0
[23134.309980] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[23134.309983] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[23134.309986] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[23134.309988] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[23134.309990] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[23134.309992] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[23134.309994] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[23134.309996] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[23134.309998] [<ffffffff93281637>] ? do_group_exit+0x47/0xc0
[23134.310000] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[23134.310003] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[23134.310005] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[23134.325900] BUG: scheduling while atomic: irq/27-enp3s0/534/0x00000002
[23134.325929] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[23134.325934] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[23134.325937] Preemption disabled at:
[23134.325937] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[23134.325940] CPU: 1 PID: 534 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[23134.325941] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[23134.325944] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50542e0bb90
[23134.325947] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[23134.325950] ffff97c77ece9a00 ffff97c778960000 ffff97c778960000 ffffb50542e0bbd0
[23134.325950] Call Trace:
[23134.325954] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[23134.325956] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[23134.325959] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[23134.325962] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[23134.325964] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[23134.325967] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[23134.325970] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[23134.325975] [<ffffffffc06b2541>] ? rtl8169_poll+0x421/0x660 [r8169]
[23134.325978] [<ffffffff9371eea1>] ? net_rx_action+0x311/0x490
[23134.325982] [<ffffffff932277e3>] ? __switch_to+0x343/0x7d0
[23134.325984] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[23134.325987] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[23134.325989] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[23134.325991] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[23134.325993] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[23134.325995] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[23134.325998] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[23134.326000] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[23134.326002] [<ffffffff93281637>] ? do_group_exit+0x47/0xc0
[23134.326004] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[23134.326007] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[23134.326009] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[23134.341924] BUG: scheduling while atomic: irq/27-enp3s0/534/0x00000002
[23134.341968] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[23134.341979] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[23134.341986] Preemption disabled at:
[23134.341986] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[23134.341990] CPU: 1 PID: 534 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[23134.341991] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[23134.341995] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50542e0bb90
[23134.341998] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[23134.342000] ffff97c77ece9a00 ffff97c778960000 ffff97c778960000 ffffb50542e0bbd0
[23134.342001] Call Trace:
[23134.342007] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[23134.342010] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[23134.342013] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[23134.342017] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[23134.342019] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[23134.342022] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[23134.342025] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[23134.342033] [<ffffffffc06b2541>] ? rtl8169_poll+0x421/0x660 [r8169]
[23134.342036] [<ffffffff9371eea1>] ? net_rx_action+0x311/0x490
[23134.342041] [<ffffffff932277e3>] ? __switch_to+0x343/0x7d0
[23134.342044] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[23134.342047] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[23134.342050] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[23134.342052] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[23134.342054] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[23134.342056] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[23134.342058] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[23134.342060] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[23134.342062] [<ffffffff93281637>] ? do_group_exit+0x47/0xc0
[23134.342065] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[23134.342068] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[23134.342070] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[23134.389900] BUG: scheduling while atomic: irq/27-enp3s0/534/0x00000002
[23134.389945] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[23134.389953] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[23134.389959] Preemption disabled at:
[23134.389960] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[23134.389963] CPU: 1 PID: 534 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[23134.389964] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[23134.389969] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50542e0bb90
[23134.389972] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[23134.389975] ffff97c77ece9a00 ffff97c778960000 ffff97c778960000 ffffb50542e0bbd0
[23134.389975] Call Trace:
[23134.389982] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[23134.389985] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[23134.389988] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[23134.389992] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[23134.389994] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[23134.389997] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[23134.389999] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[23134.390008] [<ffffffffc06b2541>] ? rtl8169_poll+0x421/0x660 [r8169]
[23134.390012] [<ffffffff9371eea1>] ? net_rx_action+0x311/0x490
[23134.390016] [<ffffffff932277e3>] ? __switch_to+0x343/0x7d0
[23134.390019] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[23134.390023] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[23134.390025] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[23134.390027] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[23134.390029] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[23134.390031] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[23134.390034] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[23134.390036] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[23134.390038] [<ffffffff93281637>] ? do_group_exit+0x47/0xc0
[23134.390041] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[23134.390043] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[23134.390046] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[23134.405923] BUG: scheduling while atomic: irq/27-enp3s0/534/0x00000002
[23134.405966] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[23134.405974] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[23134.405980] Preemption disabled at:
[23134.405981] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[23134.405984] CPU: 1 PID: 534 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[23134.405985] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[23134.405990] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50542e0bb90
[23134.405993] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[23134.405995] ffff97c77ece9a00 ffff97c778960000 ffff97c778960000 ffffb50542e0bbd0
[23134.405995] Call Trace:
[23134.406003] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[23134.406005] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[23134.406009] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[23134.406012] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[23134.406015] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[23134.406017] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[23134.406020] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[23134.406028] [<ffffffffc06b2541>] ? rtl8169_poll+0x421/0x660 [r8169]
[23134.406032] [<ffffffff9371eea1>] ? net_rx_action+0x311/0x490
[23134.406036] [<ffffffff932277e3>] ? __switch_to+0x343/0x7d0
[23134.406039] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[23134.406042] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[23134.406045] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[23134.406047] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[23134.406049] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[23134.406051] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[23134.406053] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[23134.406055] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[23134.406057] [<ffffffff93281637>] ? do_group_exit+0x47/0xc0
[23134.406059] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[23134.406062] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[23134.406064] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[23134.677901] BUG: scheduling while atomic: irq/27-enp3s0/534/0x00000002
[23134.677947] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[23134.677955] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[23134.677962] Preemption disabled at:
[23134.677962] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[23134.677966] CPU: 1 PID: 534 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[23134.677967] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[23134.677972] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50542e0bb90
[23134.677975] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[23134.677978] ffff97c77ece9a00 ffff97c778960000 ffff97c778960000 ffffb50542e0bbd0
[23134.677978] Call Trace:
[23134.677985] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[23134.677988] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[23134.677992] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[23134.677996] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[23134.677998] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[23134.678001] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[23134.678003] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[23134.678012] [<ffffffffc06b2541>] ? rtl8169_poll+0x421/0x660 [r8169]
[23134.678017] [<ffffffff9371eea1>] ? net_rx_action+0x311/0x490
[23134.678022] [<ffffffff932277e3>] ? __switch_to+0x343/0x7d0
[23134.678025] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[23134.678030] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[23134.678032] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[23134.678034] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[23134.678036] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[23134.678039] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[23134.678042] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[23134.678044] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[23134.678047] [<ffffffff93281637>] ? do_group_exit+0x47/0xc0
[23134.678050] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[23134.678053] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[23134.678055] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[23134.693894] BUG: scheduling while atomic: irq/27-enp3s0/534/0x00000002
[23134.693931] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[23134.693938] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[23134.693942] Preemption disabled at:
[23134.693942] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[23134.693945] CPU: 1 PID: 534 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[23134.693946] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[23134.693950] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50542e0bb90
[23134.693953] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[23134.693955] ffff97c77ece9a00 ffff97c778960000 ffff97c778960000 ffffb50542e0bbd0
[23134.693956] Call Trace:
[23134.693961] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[23134.693964] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[23134.693967] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[23134.693971] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[23134.693973] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[23134.693976] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[23134.693979] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[23134.693986] [<ffffffffc06b2541>] ? rtl8169_poll+0x421/0x660 [r8169]
[23134.693990] [<ffffffff9371eea1>] ? net_rx_action+0x311/0x490
[23134.693994] [<ffffffff932277e3>] ? __switch_to+0x343/0x7d0
[23134.693997] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[23134.694000] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[23134.694003] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[23134.694005] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[23134.694007] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[23134.694010] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[23134.694012] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[23134.694015] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[23134.694017] [<ffffffff93281637>] ? do_group_exit+0x47/0xc0
[23134.694020] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[23134.694022] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[23134.694025] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[23134.741910] BUG: scheduling while atomic: irq/27-enp3s0/534/0x00000002
[23134.741944] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[23134.741950] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[23134.741954] Preemption disabled at:
[23134.741954] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[23134.741957] CPU: 1 PID: 534 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[23134.741958] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[23134.741962] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50542e0bb90
[23134.741965] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[23134.741967] ffff97c77ece9a00 ffff97c778960000 ffff97c778960000 ffffb50542e0bbd0
[23134.741968] Call Trace:
[23134.741972] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[23134.741975] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[23134.741978] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[23134.741981] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[23134.741984] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[23134.741987] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[23134.741989] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[23134.741996] [<ffffffffc06b2541>] ? rtl8169_poll+0x421/0x660 [r8169]
[23134.741999] [<ffffffff9371eea1>] ? net_rx_action+0x311/0x490
[23134.742003] [<ffffffff932277e3>] ? __switch_to+0x343/0x7d0
[23134.742005] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[23134.742008] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[23134.742010] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[23134.742012] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[23134.742014] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[23134.742017] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[23134.742019] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[23134.742021] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[23134.742023] [<ffffffff93281637>] ? do_group_exit+0x47/0xc0
[23134.742025] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[23134.742028] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[23134.742030] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
[23134.821915] BUG: scheduling while atomic: irq/27-enp3s0/534/0x00000002
[23134.821949] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 hid_logitech_dj cfg80211 crc_ccitt rfkill hid_multitouch joydev hid_generic edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw k10temp fam15h_power shpchp snd_hda_codec_hdmi sp5100_tco amdkfd snd_hda_intel radeon snd_hda_codec snd_hda_core snd_hwdep ttm drm_kms_helper snd_pcm snd_timer sg usbhid hid drm evdev snd i2c_algo_bit soundcore video wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[23134.821955] psmouse ohci_hcd ehci_pci ehci_hcd pata_atiixp ahci r8169 mii libahci usbcore i2c_piix4 usb_common libata scsi_mod
[23134.821959] Preemption disabled at:
[23134.821959] [<ffffffff93673908>] __unmap_single.isra.22+0x98/0x1c0
[23134.821962] CPU: 1 PID: 534 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[23134.821963] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[23134.821966] 0000000000000000 ffffffff9354006b ffffffff93673908 ffffb50542e0bb90
[23134.821969] ffffffff932a49c3 0000000000000000 ffffffff93825c1b 00ff97c779ae2f40
[23134.821971] ffff97c77ece9a00 ffff97c778960000 ffff97c778960000 ffffb50542e0bbd0
[23134.821971] Call Trace:
[23134.821976] [<ffffffff9354006b>] ? dump_stack+0x5c/0x81
[23134.821979] [<ffffffff93673908>] ? __unmap_single.isra.22+0x98/0x1c0
[23134.821982] [<ffffffff932a49c3>] ? __schedule_bug+0x73/0xc0
[23134.821985] [<ffffffff93825c1b>] ? __schedule+0x4fb/0x5b0
[23134.821987] [<ffffffff93825d13>] ? schedule+0x43/0xc0
[23134.821990] [<ffffffff938279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[23134.821993] [<ffffffff93673926>] ? __unmap_single.isra.22+0xb6/0x1c0
[23134.821999] [<ffffffffc06b2541>] ? rtl8169_poll+0x421/0x660 [r8169]
[23134.822002] [<ffffffff9371eea1>] ? net_rx_action+0x311/0x490
[23134.822006] [<ffffffff932277e3>] ? __switch_to+0x343/0x7d0
[23134.822009] [<ffffffff932828b7>] ? do_current_softirqs+0x207/0x3b0
[23134.822012] [<ffffffff932de8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[23134.822014] [<ffffffff93282ab7>] ? __local_bh_enable+0x57/0x70
[23134.822016] [<ffffffff932de93c>] ? irq_forced_thread_fn+0x4c/0x70
[23134.822018] [<ffffffff932dec99>] ? irq_thread+0x129/0x1e0
[23134.822020] [<ffffffff93825997>] ? __schedule+0x277/0x5b0
[23134.822022] [<ffffffff932deab0>] ? wake_threads_waitq+0x30/0x30
[23134.822024] [<ffffffff932deb70>] ? irq_thread_dtor+0xc0/0xc0
[23134.822026] [<ffffffff93281637>] ? do_group_exit+0x47/0xc0
[23134.822029] [<ffffffff9329d967>] ? kthread+0xd7/0xf0
[23134.822032] [<ffffffff9329d890>] ? kthread_park+0x60/0x60
[23134.822033] [<ffffffff9382a5d1>] ? ret_from_fork+0x41/0x50
Last edit: 13 May 2018 00:09 by Lcvette.
  • ozzyrob
  • ozzyrob's Avatar
  • Visitor
  • Visitor
13 May 2018 01:03 - 13 May 2018 01:22 #110625 by ozzyrob
What processor & what kernel boot options are you using ?
Taking a stab the issue seems to be (not linuxcnc itself)
Going by the first one it could be an issue with the ehci_hcd driver (maybe to do with meltdown and such patch ?). And maybe other drivers.
You may have luck compiling another kernel version. A a plain vanilla kernel of the same version (ie: without the debian patches) and the appropriate rt patch.
Last edit: 13 May 2018 01:22 by ozzyrob.
  • Lcvette
  • Lcvette's Avatar Topic Author
  • Platinum Member
  • Platinum Member
13 May 2018 01:29 #110626 by Lcvette
Going by the first one it could be an issue with the ehci_hcd driver. And maybe other drivers.
Hmmm.. those boot option questions are way over my head.. I'm running the linuxcnc stretch download, my computer is an AMD A6-7400K FM2+ 3.5ghz, 120gb ssd, ecs A58F2P-M4V 1.0 mother board, 4gb ram.
I loaded it via USB thing drive? And changed the boot option to look for the USB first?
I can get you any information you want just not sure how to go about getting it, I'm very new to Linux.
Thanks,
Chris
  • ozzyrob
  • ozzyrob's Avatar
  • Visitor
  • Visitor
13 May 2018 02:50 #110631 by ozzyrob
I had a couple of goes of booting the edition live and running a parallel port config.....no mesa hwd yet......couldn't get the same issues.
Tho my MB is a Asus M2N68-AM Plus, Athlon 64X2 5200+, 4GB ram and a Radeon HD 5450/6350 card.
With a RTAI install I get latencies of around 8k -9k on the base & servo thread, watching youtube, running a couple of glxgears and watching 1 HD & 1 SD video with VLC over a smb share each. I'm liking the old AMD boards & Radeon combo. A Kingston 120GB SSD really made a world of difference. No need to use isolcpus.
I have another AMD board & CPU coming off ebay shortly....same kind of vintage I'll see how that goes.
  • Lcvette
  • Platinum Member
  • Platinum Member
13 May 2018 03:29 - 13 May 2018 03:31 #110634 by Lcvette
For some reason this just is happening in this config, I have successfully loaded another config with out some of the complexities this one has which are some remaps for an ATC etc and some custom buttons etc.
So I'm not sure if maybe it's because this is needing something different it doesn't have on the system or what.
My latencies are atrocious with the Peempt-RT kernel, they were 102k, 190k
I'm currently shopping for a better CPU, MoBo online to cure that issue. But would still like to work through all the software issues.
I have the Kingston 120gb SSD you said you turned something off with it?
Last edit: 13 May 2018 03:31 by Lcvette.
  • Lcvette
  • Platinum Member
  • Platinum Member
13 May 2018 04:50 #110644 by Lcvette
update, cmorley gave me a player.py file to shutup an error message caused by a newer version of python-gst unable run a older file version, and this allowed gmoccapy to load somewhat however the screen was dead, meaning nothing worked and had to be temrinated manually for unresponsiveness. it did however give a new set of debug errors as seen below!
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.11
Machine configuration directory is '/home/chris/linuxcnc/configs/VMC2'
Machine configuration file is 'VMC2.ini'
INIFILE=/home/chris/linuxcnc/configs/VMC2/VMC2.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=gmoccapy
Starting LinuxCNC...
Found file(REL): ./VMC2.hal
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: Hardware address: 00:60:1b:13:03:d6
hm2_eth: discovered 7I92
hm2/hm2_7i92.0: Smart Serial Firmware Version 43
Board hm2_7i92.0.7i77.0.0 Hardware Mode 0 = standard
Board hm2_7i92.0.7i77.0.0 Software Mode 0 = input_output
Board hm2_7i92.0.7i77.0.0 Software Mode 1 = io_analog
Board hm2_7i92.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage
Board hm2_7i92.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage
Board hm2_7i92.0.7i77.0.1 Hardware Mode 0 = standard
Board hm2_7i92.0.7i77.0.1 Software Mode 0 = analogout_enables
Board hm2_7i92.0.7i76.0.3 Hardware Mode 0 = standard
Board hm2_7i92.0.7i76.0.3 Software Mode 0 = io_spin
Board hm2_7i92.0.7i76.0.3 Software Mode 1 = io_ana_spin
Board hm2_7i92.0.7i76.0.3 Software Mode 2 = io_enc_ana_spin_fv
hm2/hm2_7i92.0: 34 I/O Pins used:
hm2/hm2_7i92.0: IO Pin 000 (P2-01): IOPort
hm2/hm2_7i92.0: IO Pin 001 (P2-14): IOPort
hm2/hm2_7i92.0: IO Pin 002 (P2-02): IOPort
hm2/hm2_7i92.0: IO Pin 003 (P2-15): Smart Serial Interface #0, pin TxData1 (Output)
hm2/hm2_7i92.0: IO Pin 004 (P2-03): Smart Serial Interface #0, pin RxData1 (Input)
hm2/hm2_7i92.0: IO Pin 005 (P2-16): Smart Serial Interface #0, pin TxData0 (Output)
hm2/hm2_7i92.0: IO Pin 006 (P2-04): Smart Serial Interface #0, pin RxData0 (Input)
hm2/hm2_7i92.0: IO Pin 007 (P2-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
hm2/hm2_7i92.0: IO Pin 008 (P2-05): Muxed Encoder #0, pin Muxed A (Input)
hm2/hm2_7i92.0: IO Pin 009 (P2-06): Muxed Encoder #0, pin Muxed B (Input)
hm2/hm2_7i92.0: IO Pin 010 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
hm2/hm2_7i92.0: IO Pin 011 (P2-08): Muxed Encoder #1, pin Muxed A (Input)
hm2/hm2_7i92.0: IO Pin 012 (P2-09): Muxed Encoder #1, pin Muxed B (Input)
hm2/hm2_7i92.0: IO Pin 013 (P2-10): Muxed Encoder #1, pin Muxed Index (Input)
hm2/hm2_7i92.0: IO Pin 014 (P2-11): Muxed Encoder #2, pin Muxed A (Input)
hm2/hm2_7i92.0: IO Pin 015 (P2-12): Muxed Encoder #2, pin Muxed B (Input)
hm2/hm2_7i92.0: IO Pin 016 (P2-13): Muxed Encoder #2, pin Muxed Index (Input)
hm2/hm2_7i92.0: IO Pin 017 (P1-01): StepGen #0, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 018 (P1-14): StepGen #0, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 019 (P1-02): StepGen #1, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 020 (P1-15): StepGen #1, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 021 (P1-03): StepGen #2, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 022 (P1-16): StepGen #2, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 023 (P1-04): StepGen #3, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 024 (P1-17): StepGen #3, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 025 (P1-05): StepGen #4, pin Direction (Output)
hm2/hm2_7i92.0: IO Pin 026 (P1-06): StepGen #4, pin Step (Output)
hm2/hm2_7i92.0: IO Pin 027 (P1-07): Smart Serial Interface #0, pin TxData3 (Output)
hm2/hm2_7i92.0: IO Pin 028 (P1-08): Smart Serial Interface #0, pin RxData3 (Input)
hm2/hm2_7i92.0: IO Pin 029 (P1-09): IOPort
hm2/hm2_7i92.0: IO Pin 030 (P1-10): IOPort
hm2/hm2_7i92.0: IO Pin 031 (P1-11): IOPort
hm2/hm2_7i92.0: IO Pin 032 (P1-12): IOPort
hm2/hm2_7i92.0: IO Pin 033 (P1-13): IOPort
hm2/hm2_7i92.0: registered
Found file(REL): ./custom.hal
Starting DISPLAY program: gmoccapy
emc/task/emctask.cc 389: interp_error: File not open
File not open
emc/task/emctaskmain.cc 3017: can't initialize interpreter
**** probe_screen GETINIINFO ****
Preference file path: gmoccapy_preferences
No option 'chk_set_zero' in section: 'DEFAULT'
No option 'chk_auto_rott' in section: 'DEFAULT'
No option 'ps_searchvel' in section: 'DEFAULT'
No option 'ps_probevel' in section: 'DEFAULT'
No option 'ps_z_clearance' in section: 'DEFAULT'
No option 'ps_probe_max' in section: 'DEFAULT'
No option 'ps_probe_latch' in section: 'DEFAULT'
No option 'ps_probe_diam' in section: 'DEFAULT'
No option 'ps_xy_clearance' in section: 'DEFAULT'
No option 'ps_edge_lenght' in section: 'DEFAULT'
No option 'ps_offs_x' in section: 'DEFAULT'
No option 'ps_offs_y' in section: 'DEFAULT'
No option 'ps_offs_z' in section: 'DEFAULT'
No option 'ps_offs_angle' in section: 'DEFAULT'
Killing task linuxcncsvr, PID=2661
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
Debug file information:
Note: Using POSIX realtime
/home/chris/linuxcnc/configs/VMC2/VMC2.ini:121: executing 'import sys
sys.path.append("/home/chris/linuxcnc/configs/VMC2/python")'
PythonPlugin: Python '2.7.13 (default, Nov 24 2017, 17:33:09)
[GCC 6.3.0 20170516]'
NGC file not found: ngc=toolchange - 55:REMAP = M6 modalgroup=6 prolog=change_prolog ngc=toolchange epilog=change_epilog
is_callable(__delete__) = FALSE
/usr/lib/python2.7/dist-packages/gladevcp/hal_mdihistory.py:89: GtkWarning: IA__gtk_tree_path_append_index: assertion 'index >= 0' failed
self.tv.scroll_to_cell(path)
/usr/lib/python2.7/dist-packages/gladevcp/hal_mdihistory.py:89: GtkWarning: IA__gtk_tree_view_scroll_to_cell: assertion 'tree_view->priv->tree != NULL' failed
/usr/lib/python2.7/dist-packages/gladevcp/hal_mdihistory.py:90: GtkWarning: IA__gtk_tree_path_append_index: assertion 'index >= 0' failed
self.tv.set_cursor(path)
/usr/lib/python2.7/dist-packages/gladevcp/hal_mdihistory.py:90: GtkWarning: IA__gtk_tree_row_reference_new_proxy: assertion 'path->depth > 0' failed
/usr/bin/gmoccapy:237: GtkWarning: Invalid icon size 48
self.widgets.window1.show()
/usr/bin/gladevcp:185: GtkWarning: GtkSpinButton: setting an adjustment with non-zero page size is deprecated
builder.add_from_file(xmlname)
(gmoccapy:2718): GtkSourceView-CRITICAL **: gtk_source_language_manager_set_search_path: assertion 'lm->priv->ids == NULL' failed
/usr/bin/linuxcnc: line 857: 2718 Killed $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
2661
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 1746.038014] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1746.038016] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1746.038019] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1746.038020] Call Trace:
[ 1746.038024] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1746.038027] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1746.038030] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1746.038034] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1746.038037] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1746.038039] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1746.038042] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1746.038049] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1746.038052] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1746.038056] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1746.038059] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1746.038062] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1746.038064] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1746.038066] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1746.038068] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1746.038070] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1746.038073] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1746.038074] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1746.038076] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1746.038079] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1746.038082] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1746.038084] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1748.373833] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1748.373871] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1748.373878] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1748.373883] Preemption disabled at:
[ 1748.373883] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1748.373886] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1748.373887] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1748.373891] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1748.373893] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1748.373894] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1748.373895] Call Trace:
[ 1748.373901] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1748.373903] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1748.373906] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1748.373908] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1748.373910] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1748.373912] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1748.373914] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1748.373921] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1748.373924] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1748.373928] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1748.373930] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1748.373933] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1748.373935] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1748.373936] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1748.373938] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1748.373939] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1748.373941] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1748.373942] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1748.373944] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1748.373946] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1748.373948] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1748.373950] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1749.157768] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1749.157813] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1749.157821] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1749.157828] Preemption disabled at:
[ 1749.157828] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1749.157832] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1749.157833] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1749.157838] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1749.157841] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1749.157843] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1749.157843] Call Trace:
[ 1749.157850] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1749.157853] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1749.157857] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1749.157861] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1749.157863] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1749.157866] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1749.157869] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1749.157877] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1749.157880] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1749.157885] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1749.157888] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1749.157891] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1749.157893] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1749.157895] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1749.157897] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1749.157900] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1749.157902] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1749.157904] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1749.157906] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1749.157909] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1749.157912] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1749.157914] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1759.127956] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1759.128001] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1759.128009] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1759.128016] Preemption disabled at:
[ 1759.128016] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1759.128020] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1759.128021] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1759.128026] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1759.128029] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f41
[ 1759.128031] ffff9bf17ece9a00 0000000000000001 ffff9bf178910fc0 ffffbd3641183bd0
[ 1759.128032] Call Trace:
[ 1759.128039] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1759.128041] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1759.128045] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1759.128049] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1759.128052] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1759.128054] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1759.128057] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1759.128066] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1759.128070] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1759.128074] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1759.128078] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1759.128081] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1759.128083] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1759.128085] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1759.128087] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1759.128090] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1759.128092] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1759.128094] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1759.128097] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1759.128100] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1759.128103] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1759.128105] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1764.036885] BUG: scheduling while atomic: irq/17-ehci_hcd/128/0x00000002
[ 1764.036930] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1764.036938] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1764.036945] Preemption disabled at:
[ 1764.036946] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1764.036950] CPU: 1 PID: 128 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1764.036951] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1764.036955] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641133be8
[ 1764.036958] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1764.036960] ffff9bf17ece9a00 ffff9bf17420cec0 ffff9bf17420cec0 ffffbd3641133c28
[ 1764.036961] Call Trace:
[ 1764.036968] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1764.036971] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1764.036975] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1764.036978] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1764.036981] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1764.036983] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1764.036986] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1764.037008] [<ffffffffc043ae1e>] ? usb_hcd_unmap_urb_setup_for_dma+0x9e/0xc0 [usbcore]
[ 1764.037020] [<ffffffffc043ae56>] ? usb_hcd_unmap_urb_for_dma+0x16/0x160 [usbcore]
[ 1764.037031] [<ffffffffc043aff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[ 1764.037043] [<ffffffffc043b175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[ 1764.037046] [<ffffffffbce82366>] ? __tasklet_action.isra.16+0x56/0x110
[ 1764.037049] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1764.037052] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1764.037054] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1764.037056] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1764.037058] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1764.037060] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1764.037062] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1764.037064] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1764.037067] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1764.037070] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1764.037072] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1764.372861] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1764.372905] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1764.372913] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1764.372920] Preemption disabled at:
[ 1764.372920] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1764.372924] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1764.372925] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1764.372929] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1764.372932] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1764.372934] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1764.372935] Call Trace:
[ 1764.372941] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1764.372943] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1764.372947] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1764.372950] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1764.372953] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1764.372955] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1764.372958] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1764.372966] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1764.372970] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1764.372974] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1764.372977] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1764.372980] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1764.372983] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1764.372985] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1764.372986] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1764.372989] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1764.372991] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1764.372993] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1764.372995] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1764.372998] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1764.373001] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1764.373003] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1764.468854] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1764.468898] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1764.468906] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1764.468913] Preemption disabled at:
[ 1764.468913] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1764.468917] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1764.468918] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1764.468923] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1764.468925] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1764.468927] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1764.468928] Call Trace:
[ 1764.468935] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1764.468937] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1764.468941] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1764.468945] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1764.468947] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1764.468950] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1764.468953] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1764.468960] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1764.468964] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1764.468968] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1764.468971] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1764.468974] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1764.468976] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1764.468979] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1764.468980] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1764.468983] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1764.468985] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1764.468987] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1764.468989] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1764.468992] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1764.468994] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1764.468996] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1764.469036] BUG: scheduling while atomic: irq/17-ehci_hcd/128/0x00000002
[ 1764.469064] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1764.469069] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1764.469072] Preemption disabled at:
[ 1764.469072] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1764.469074] CPU: 1 PID: 128 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1764.469075] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1764.469078] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641133be8
[ 1764.469081] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 0000000000000000
[ 1764.469084] ffff9bf17ece9a00 ffff9bf17420cec0 ffff9bf17420cec0 ffffbd3641133c28
[ 1764.469084] Call Trace:
[ 1764.469087] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1764.469089] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1764.469092] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1764.469095] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1764.469097] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1764.469100] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1764.469103] [<ffffffffbcfe6ba0>] ? dma_pool_free+0x20/0xc0
[ 1764.469106] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1764.469125] [<ffffffffc043ae1e>] ? usb_hcd_unmap_urb_setup_for_dma+0x9e/0xc0 [usbcore]
[ 1764.469137] [<ffffffffc043ae56>] ? usb_hcd_unmap_urb_for_dma+0x16/0x160 [usbcore]
[ 1764.469148] [<ffffffffc043aff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[ 1764.469160] [<ffffffffc043b175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[ 1764.469163] [<ffffffffbce82366>] ? __tasklet_action.isra.16+0x56/0x110
[ 1764.469165] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1764.469168] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1764.469170] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1764.469172] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1764.469174] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1764.469176] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1764.469178] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1764.469180] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1764.469182] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1764.469185] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1764.469187] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1765.604790] BUG: scheduling while atomic: irq/17-ehci_hcd/128/0x00000002
[ 1765.604835] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1765.604843] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1765.604850] Preemption disabled at:
[ 1765.604850] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1765.604854] CPU: 1 PID: 128 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1765.604855] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1765.604860] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641133be8
[ 1765.604862] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1765.604864] ffff9bf17ece9a00 ffff9bf17420cec0 ffff9bf17420cec0 ffffbd3641133c28
[ 1765.604865] Call Trace:
[ 1765.604873] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1765.604875] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1765.604879] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1765.604882] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1765.604885] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1765.604888] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1765.604890] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1765.604914] [<ffffffffc043ae1e>] ? usb_hcd_unmap_urb_setup_for_dma+0x9e/0xc0 [usbcore]
[ 1765.604926] [<ffffffffc043ae56>] ? usb_hcd_unmap_urb_for_dma+0x16/0x160 [usbcore]
[ 1765.604938] [<ffffffffc043aff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[ 1765.604950] [<ffffffffc043b175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[ 1765.604953] [<ffffffffbce82366>] ? __tasklet_action.isra.16+0x56/0x110
[ 1765.604956] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1765.604960] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1765.604962] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1765.604964] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1765.604966] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1765.604968] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1765.604970] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1765.604972] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1765.604976] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1765.604979] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1765.604981] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1776.212165] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1776.212210] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1776.212218] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1776.212225] Preemption disabled at:
[ 1776.212225] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1776.212229] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1776.212230] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1776.212234] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1776.212237] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1776.212239] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1776.212240] Call Trace:
[ 1776.212246] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1776.212249] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1776.212252] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1776.212256] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1776.212258] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1776.212261] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1776.212264] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1776.212272] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1776.212276] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1776.212280] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1776.212284] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1776.212288] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1776.212290] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1776.212292] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1776.212294] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1776.212296] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1776.212298] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1776.212300] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1776.212302] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1776.212305] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1776.212308] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1776.212310] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1779.827945] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1779.827990] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1779.827998] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1779.828005] Preemption disabled at:
[ 1779.828005] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1779.828009] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1779.828010] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1779.828015] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1779.828017] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1779.828020] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1779.828020] Call Trace:
[ 1779.828027] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1779.828030] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1779.828033] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1779.828037] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1779.828039] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1779.828042] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1779.828045] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1779.828054] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1779.828057] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1779.828061] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1779.828064] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1779.828068] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1779.828070] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1779.828072] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1779.828074] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1779.828076] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1779.828078] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1779.828080] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1779.828082] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1779.828085] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1779.828088] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1779.828090] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1781.139876] BUG: scheduling while atomic: irq/17-ehci_hcd/128/0x00000002
[ 1781.139921] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1781.139929] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1781.139937] Preemption disabled at:
[ 1781.139937] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1781.139941] CPU: 1 PID: 128 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1781.139942] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1781.139947] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641133c00
[ 1781.139950] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1781.139952] ffff9bf17ece9a00 ffff9bf17420cec0 ffff9bf17420cec0 ffffbd3641133c40
[ 1781.139953] Call Trace:
[ 1781.139960] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1781.139963] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1781.139967] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1781.139971] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1781.139973] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1781.139976] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1781.139979] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1781.140004] [<ffffffffc043aec9>] ? usb_hcd_unmap_urb_for_dma+0x89/0x160 [usbcore]
[ 1781.140015] [<ffffffffc043aff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[ 1781.140027] [<ffffffffc043b175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[ 1781.140031] [<ffffffffbce82366>] ? __tasklet_action.isra.16+0x56/0x110
[ 1781.140033] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1781.140037] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1781.140039] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1781.140041] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1781.140043] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1781.140045] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1781.140048] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1781.140050] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1781.140053] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1781.140056] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1781.140058] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1781.315860] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1781.315902] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1781.315910] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1781.315917] Preemption disabled at:
[ 1781.315917] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1781.315921] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1781.315921] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1781.315926] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1781.315928] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1781.315931] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1781.315931] Call Trace:
[ 1781.315938] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1781.315941] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1781.315945] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1781.315948] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1781.315951] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1781.315954] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1781.315957] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1781.315965] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1781.315968] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1781.315972] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1781.315975] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1781.315979] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1781.315981] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1781.315983] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1781.315985] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1781.315987] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1781.315989] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1781.315991] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1781.315993] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1781.315996] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1781.315999] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1781.316001] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1783.011770] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1783.011817] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1783.011826] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1783.011833] Preemption disabled at:
[ 1783.011833] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1783.011837] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1783.011838] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1783.011843] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1783.011845] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1783.011848] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1783.011848] Call Trace:
[ 1783.011855] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1783.011858] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1783.011862] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1783.011865] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1783.011868] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1783.011871] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1783.011874] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1783.011882] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1783.011887] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1783.011891] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1783.011895] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1783.011899] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1783.011902] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1783.011904] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1783.011907] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1783.011909] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1783.011912] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1783.011914] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1783.011916] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1783.011919] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1783.011922] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1783.011924] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1783.107759] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1783.107796] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1783.107803] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1783.107809] Preemption disabled at:
[ 1783.107809] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1783.107812] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1783.107813] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1783.107816] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1783.107818] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1783.107820] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1783.107821] Call Trace:
[ 1783.107826] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1783.107828] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1783.107831] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1783.107834] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1783.107836] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1783.107838] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1783.107840] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1783.107846] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1783.107849] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1783.107852] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1783.107855] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1783.107857] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1783.107859] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1783.107860] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1783.107862] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1783.107863] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1783.107865] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1783.107866] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1783.107868] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1783.107870] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1783.107872] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1783.107874] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1783.219742] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1783.219780] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1783.219786] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1783.219792] Preemption disabled at:
[ 1783.219792] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1783.219796] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1783.219796] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1783.219800] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1783.219802] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1783.219804] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1783.219804] Call Trace:
[ 1783.219810] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1783.219812] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1783.219815] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1783.219818] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1783.219820] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1783.219822] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1783.219824] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1783.219830] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1783.219833] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1783.219836] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1783.219839] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1783.219841] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1783.219842] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1783.219844] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1783.219845] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1783.219847] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1783.219849] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1783.219850] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1783.219851] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1783.219854] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1783.219856] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1783.219858] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1783.507721] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1783.507765] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1783.507773] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1783.507781] Preemption disabled at:
[ 1783.507781] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1783.507785] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1783.507786] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1783.507791] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1783.507793] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1783.507795] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1783.507796] Call Trace:
[ 1783.507803] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1783.507805] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1783.507809] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1783.507812] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1783.507815] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1783.507817] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1783.507820] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1783.507829] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1783.507832] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1783.507836] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1783.507839] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1783.507843] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1783.507845] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1783.507847] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1783.507849] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1783.507852] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1783.507854] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1783.507856] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1783.507858] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1783.507861] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1783.507864] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1783.507866] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1783.747731] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1783.747779] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1783.747787] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1783.747795] Preemption disabled at:
[ 1783.747795] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1783.747799] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1783.747800] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1783.747804] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1783.747808] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1783.747810] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1783.747810] Call Trace:
[ 1783.747818] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1783.747820] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1783.747824] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1783.747828] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1783.747831] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1783.747833] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1783.747836] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1783.747845] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1783.747848] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1783.747853] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1783.747856] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1783.747859] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1783.747862] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1783.747864] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1783.747865] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1783.747868] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1783.747870] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1783.747872] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1783.747874] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1783.747877] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1783.747880] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1783.747883] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1783.843720] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1783.843759] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1783.843766] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1783.843772] Preemption disabled at:
[ 1783.843772] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1783.843775] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1783.843776] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1783.843779] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1783.843781] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1783.843783] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1783.843783] Call Trace:
[ 1783.843790] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1783.843792] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1783.843795] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1783.843798] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1783.843799] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1783.843801] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1783.843803] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1783.843810] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1783.843813] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1783.843816] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1783.843819] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1783.843821] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1783.843822] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1783.843824] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1783.843825] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1783.843826] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1783.843828] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1783.843829] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1783.843830] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1783.843832] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1783.843834] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1783.843836] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1783.891708] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1783.891744] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1783.891750] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1783.891756] Preemption disabled at:
[ 1783.891756] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1783.891758] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1783.891759] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1783.891762] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1783.891764] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1783.891765] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1783.891765] Call Trace:
[ 1783.891771] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1783.891773] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1783.891775] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1783.891778] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1783.891779] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1783.891781] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1783.891782] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1783.891788] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1783.891791] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1783.891794] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1783.891797] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1783.891799] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1783.891800] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1783.891802] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1783.891803] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1783.891804] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1783.891805] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1783.891806] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1783.891807] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1783.891809] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1783.891811] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1783.891812] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1783.923705] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1783.923741] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1783.923747] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1783.923753] Preemption disabled at:
[ 1783.923753] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1783.923756] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1783.923757] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1783.923760] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1783.923761] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1783.923763] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1783.923763] Call Trace:
[ 1783.923769] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1783.923770] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1783.923773] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1783.923776] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1783.923777] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1783.923779] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1783.923780] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1783.923786] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1783.923789] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1783.923791] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1783.923794] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1783.923796] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1783.923798] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1783.923799] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1783.923800] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1783.923801] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1783.923802] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1783.923804] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1783.923805] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1783.923807] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1783.923809] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1783.923810] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1783.987703] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1783.987743] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1783.987749] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1783.987755] Preemption disabled at:
[ 1783.987756] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1783.987759] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1783.987760] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1783.987763] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1783.987765] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1783.987767] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1783.987767] Call Trace:
[ 1783.987773] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1783.987775] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1783.987778] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1783.987780] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1783.987782] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1783.987784] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1783.987785] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1783.987792] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1783.987795] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1783.987799] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1783.987802] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1783.987804] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1783.987806] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1783.987807] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1783.987809] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1783.987810] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1783.987812] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1783.987813] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1783.987814] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1783.987817] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1783.987819] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1783.987820] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1785.875585] BUG: scheduling while atomic: irq/17-ehci_hcd/128/0x00000002
[ 1785.875630] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1785.875637] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1785.875644] Preemption disabled at:
[ 1785.875645] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1785.875649] CPU: 1 PID: 128 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1785.875650] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1785.875655] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641133be8
[ 1785.875657] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1785.875660] ffff9bf17ece9a00 ffff9bf17420cec0 ffff9bf17420cec0 ffffbd3641133c28
[ 1785.875661] Call Trace:
[ 1785.875667] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1785.875669] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1785.875673] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1785.875677] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1785.875679] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1785.875682] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1785.875685] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1785.875706] [<ffffffffc043ae1e>] ? usb_hcd_unmap_urb_setup_for_dma+0x9e/0xc0 [usbcore]
[ 1785.875717] [<ffffffffc043ae56>] ? usb_hcd_unmap_urb_for_dma+0x16/0x160 [usbcore]
[ 1785.875729] [<ffffffffc043aff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[ 1785.875741] [<ffffffffc043b175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[ 1785.875744] [<ffffffffbce82366>] ? __tasklet_action.isra.16+0x56/0x110
[ 1785.875747] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1785.875750] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1785.875753] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1785.875755] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1785.875757] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1785.875759] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1785.875761] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1785.875763] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1785.875767] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1785.875769] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1785.875772] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1786.851550] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1786.851596] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1786.851604] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1786.851611] Preemption disabled at:
[ 1786.851611] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1786.851615] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1786.851616] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1786.851621] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1786.851624] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1786.851626] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1786.851627] Call Trace:
[ 1786.851634] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1786.851637] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1786.851640] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1786.851644] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1786.851647] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1786.851650] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1786.851653] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1786.851661] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1786.851665] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1786.851670] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1786.851673] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1786.851677] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1786.851679] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1786.851681] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1786.851683] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1786.851685] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1786.851688] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1786.851690] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1786.851692] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1786.851696] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1786.851699] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1786.851702] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1793.555146] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1793.555192] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1793.555200] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1793.555209] Preemption disabled at:
[ 1793.555209] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1793.555213] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1793.555215] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1793.555220] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1793.555224] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1793.555226] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1793.555227] Call Trace:
[ 1793.555236] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1793.555238] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1793.555243] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1793.555247] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1793.555250] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1793.555253] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1793.555256] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1793.555265] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1793.555270] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1793.555274] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1793.555278] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1793.555281] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1793.555283] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1793.555285] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1793.555287] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1793.555290] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1793.555292] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1793.555294] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1793.555296] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1793.555299] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1793.555302] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1793.555304] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1795.283023] BUG: scheduling while atomic: irq/17-ehci_hcd/128/0x00000002
[ 1795.283070] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1795.283079] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1795.283086] Preemption disabled at:
[ 1795.283086] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1795.283090] CPU: 1 PID: 128 Comm: irq/17-ehci_hcd Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1795.283091] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1795.283096] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641133c00
[ 1795.283098] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1795.283100] ffff9bf17ece9a00 ffff9bf17420cec0 ffff9bf17420cec0 ffffbd3641133c40
[ 1795.283101] Call Trace:
[ 1795.283108] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1795.283111] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1795.283115] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1795.283119] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1795.283121] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1795.283124] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1795.283127] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1795.283150] [<ffffffffc043aec9>] ? usb_hcd_unmap_urb_for_dma+0x89/0x160 [usbcore]
[ 1795.283162] [<ffffffffc043aff6>] ? __usb_hcd_giveback_urb+0x36/0x120 [usbcore]
[ 1795.283174] [<ffffffffc043b175>] ? usb_giveback_urb_bh+0x95/0xf0 [usbcore]
[ 1795.283177] [<ffffffffbce82366>] ? __tasklet_action.isra.16+0x56/0x110
[ 1795.283179] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1795.283183] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1795.283185] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1795.283187] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1795.283189] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1795.283191] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1795.283193] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1795.283195] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1795.283198] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1795.283201] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1795.283203] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1797.682890] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1797.682941] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1797.682950] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1797.682956] Preemption disabled at:
[ 1797.682956] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1797.682960] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1797.682960] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1797.682965] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1797.682966] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1797.682968] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1797.682969] Call Trace:
[ 1797.682977] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1797.682978] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1797.682983] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1797.682986] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1797.682988] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1797.682990] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1797.682992] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1797.683002] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1797.683006] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1797.683010] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1797.683013] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1797.683017] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1797.683019] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1797.683021] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1797.683022] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1797.683024] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1797.683025] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1797.683027] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1797.683028] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1797.683033] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1797.683035] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1797.683037] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1797.970865] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1797.970910] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1797.970918] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1797.970925] Preemption disabled at:
[ 1797.970925] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1797.970929] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1797.970930] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1797.970934] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1797.970937] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1797.970939] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1797.970940] Call Trace:
[ 1797.970947] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1797.970950] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1797.970953] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1797.970957] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1797.970959] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1797.970962] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1797.970964] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1797.970973] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1797.970976] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1797.970981] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1797.970984] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1797.970987] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1797.970989] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1797.970991] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1797.970993] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1797.970995] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1797.970997] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1797.970999] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1797.971001] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1797.971004] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1797.971007] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1797.971009] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1799.810770] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1799.810816] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1799.810824] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1799.810832] Preemption disabled at:
[ 1799.810832] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1799.810837] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1799.810838] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1799.810842] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1799.810845] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1799.810847] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1799.810848] Call Trace:
[ 1799.810855] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1799.810857] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1799.810861] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1799.810864] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1799.810867] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1799.810869] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1799.810872] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1799.810881] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1799.810885] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1799.810889] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1799.810893] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1799.810896] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1799.810898] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1799.810900] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1799.810902] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1799.810904] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1799.810906] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1799.810908] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1799.810910] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1799.810913] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1799.810916] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1799.810918] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1799.874762] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1799.874799] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1799.874804] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1799.874810] Preemption disabled at:
[ 1799.874810] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1799.874813] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1799.874813] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1799.874817] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1799.874818] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1799.874820] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1799.874820] Call Trace:
[ 1799.874826] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1799.874827] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1799.874830] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1799.874833] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1799.874834] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1799.874836] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1799.874837] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1799.874844] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1799.874846] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1799.874849] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1799.874852] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1799.874854] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1799.874856] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1799.874857] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1799.874858] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1799.874859] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1799.874860] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1799.874862] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1799.874863] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1799.874865] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1799.874867] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1799.874869] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1799.954748] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1799.954780] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1799.954786] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1799.954792] Preemption disabled at:
[ 1799.954792] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1799.954795] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1799.954795] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1799.954798] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1799.954800] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1799.954801] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1799.954801] Call Trace:
[ 1799.954806] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1799.954808] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1799.954810] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1799.954812] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1799.954814] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1799.954815] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1799.954817] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1799.954822] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1799.954825] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1799.954828] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1799.954830] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1799.954832] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1799.954833] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1799.954834] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1799.954835] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1799.954836] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1799.954838] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1799.954839] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1799.954840] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1799.954842] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1799.954843] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1799.954845] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1799.970756] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1799.970791] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1799.970798] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1799.970803] Preemption disabled at:
[ 1799.970804] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1799.970807] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1799.970807] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1799.970811] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1799.970813] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1799.970814] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1799.970815] Call Trace:
[ 1799.970821] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1799.970822] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1799.970825] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1799.970828] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1799.970829] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1799.970831] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1799.970833] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1799.970840] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1799.970843] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1799.970846] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1799.970849] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1799.970851] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1799.970853] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1799.970854] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1799.970856] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1799.970857] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1799.970858] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1799.970860] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1799.970861] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1799.970863] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1799.970865] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1799.970867] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1800.034753] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1800.034794] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1800.034802] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1800.034808] Preemption disabled at:
[ 1800.034808] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1800.034812] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1800.034812] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1800.034816] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1800.034818] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1800.034820] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1800.034820] Call Trace:
[ 1800.034826] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1800.034828] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1800.034831] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1800.034834] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1800.034836] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1800.034838] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1800.034841] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1800.034848] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1800.034852] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1800.034856] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1800.034859] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1800.034862] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1800.034863] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1800.034865] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1800.034867] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1800.034868] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1800.034870] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1800.034872] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1800.034874] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1800.034877] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1800.034879] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1800.034881] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1800.242729] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1800.242774] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1800.242782] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1800.242789] Preemption disabled at:
[ 1800.242789] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1800.242794] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1800.242794] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1800.242799] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1800.242802] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1800.242804] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1800.242805] Call Trace:
[ 1800.242812] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1800.242814] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1800.242818] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1800.242822] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1800.242825] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1800.242827] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1800.242830] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1800.242839] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1800.242842] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1800.242846] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1800.242850] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1800.242853] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1800.242855] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1800.242858] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1800.242860] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1800.242862] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1800.242864] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1800.242866] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1800.242868] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1800.242871] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1800.242874] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1800.242876] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1800.594722] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1800.594770] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1800.594778] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1800.594785] Preemption disabled at:
[ 1800.594785] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1800.594789] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1800.594790] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1800.594796] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1800.594799] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1800.594801] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1800.594802] Call Trace:
[ 1800.594809] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1800.594812] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1800.594816] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1800.594819] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1800.594823] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1800.594826] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1800.594829] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1800.594838] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1800.594842] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1800.594847] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1800.594850] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1800.594855] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1800.594857] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1800.594859] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1800.594862] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1800.594864] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1800.594866] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1800.594868] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1800.594871] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1800.594874] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1800.594877] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1800.594879] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1800.626721] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1800.626769] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1800.626777] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1800.626785] Preemption disabled at:
[ 1800.626785] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1800.626789] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1800.626790] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1800.626795] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1800.626798] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1800.626800] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1800.626801] Call Trace:
[ 1800.626809] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1800.626811] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1800.626815] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1800.626818] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1800.626821] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1800.626824] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1800.626827] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1800.626836] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1800.626840] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1800.626844] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1800.626848] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1800.626852] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1800.626855] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1800.626857] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1800.626859] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1800.626861] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1800.626864] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1800.626866] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1800.626868] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1800.626872] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1800.626875] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1800.626877] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1800.642707] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1800.642747] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1800.642754] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1800.642761] Preemption disabled at:
[ 1800.642761] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1800.642764] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1800.642765] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1800.642769] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1800.642771] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1800.642773] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1800.642774] Call Trace:
[ 1800.642780] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1800.642781] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1800.642784] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1800.642787] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1800.642789] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1800.642791] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1800.642793] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1800.642800] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1800.642804] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1800.642807] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1800.642810] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1800.642813] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1800.642814] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1800.642816] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1800.642817] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1800.642819] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1800.642821] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1800.642822] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1800.642824] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1800.642826] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1800.642829] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1800.642830] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1801.138678] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1801.138723] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1801.138731] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1801.138738] Preemption disabled at:
[ 1801.138738] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1801.138742] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1801.138743] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1801.138748] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1801.138750] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1801.138752] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1801.138753] Call Trace:
[ 1801.138760] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1801.138762] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1801.138766] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1801.138769] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1801.138772] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1801.138775] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1801.138778] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1801.138785] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1801.138789] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1801.138793] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1801.138796] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1801.138800] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1801.138802] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1801.138804] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1801.138806] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1801.138808] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1801.138810] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1801.138812] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1801.138814] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1801.138817] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1801.138820] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1801.138823] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1801.730659] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1801.730705] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1801.730713] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1801.730721] Preemption disabled at:
[ 1801.730721] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1801.730725] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1801.730726] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1801.730731] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1801.730733] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1801.730735] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1801.730736] Call Trace:
[ 1801.730743] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1801.730746] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1801.730749] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1801.730752] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1801.730755] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1801.730758] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1801.730760] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1801.730768] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1801.730772] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1801.730776] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1801.730779] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1801.730783] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1801.730785] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1801.730787] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1801.730789] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1801.730791] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1801.730793] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1801.730795] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1801.730797] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1801.730800] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1801.730803] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1801.730805] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1801.890632] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1801.890677] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1801.890685] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1801.890693] Preemption disabled at:
[ 1801.890693] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1801.890697] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1801.890698] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1801.890703] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1801.890706] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1801.890708] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1801.890708] Call Trace:
[ 1801.890715] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1801.890718] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1801.890721] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1801.890725] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1801.890727] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1801.890730] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1801.890733] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1801.890741] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1801.890745] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1801.890748] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1801.890751] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1801.890755] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1801.890757] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1801.890759] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1801.890761] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1801.890763] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1801.890765] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1801.890767] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1801.890769] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1801.890772] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1801.890775] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1801.890777] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1803.714543] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1803.714579] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1803.714586] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1803.714593] Preemption disabled at:
[ 1803.714593] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1803.714596] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1803.714597] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1803.714601] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1803.714602] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1803.714603] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1803.714604] Call Trace:
[ 1803.714609] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1803.714611] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1803.714613] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1803.714617] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1803.714618] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1803.714620] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1803.714621] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1803.714628] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1803.714631] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1803.714634] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1803.714637] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1803.714639] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1803.714641] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1803.714642] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1803.714643] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1803.714645] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1803.714646] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1803.714647] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1803.714648] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1803.714650] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1803.714652] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1803.714654] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
[ 1803.778526] BUG: scheduling while atomic: irq/27-enp3s0/458/0x00000002
[ 1803.778563] Modules linked in: ipt_REJECT nf_reject_ipv4 xt_tcpudp iptable_filter ctr ccm arc4 hid_logitech_hidpp rt2800usb rt2x00usb rt2800lib rt2x00lib mac80211 cfg80211 crc_ccitt hid_logitech_dj rfkill hid_multitouch joydev edac_mce_amd edac_core kvm_amd kvm irqbypass crct10dif_pclmul crc32_pclmul ghash_clmulni_intel pcspkr serio_raw fam15h_power k10temp shpchp hid_generic evdev sg sp5100_tco amdkfd snd_hda_codec_hdmi radeon snd_hda_intel snd_hda_codec snd_hda_core snd_hwdep ttm snd_pcm drm_kms_helper snd_timer video drm snd soundcore i2c_algo_bit wmi button acpi_cpufreq parport_pc ppdev lp parport ip_tables x_tables autofs4 usbhid hid ext4 crc16 jbd2 crc32c_generic fscrypto ecb mbcache sd_mod ata_generic ohci_pci crc32c_intel aesni_intel aes_x86_64 glue_helper lrw gf128mul ablk_helper cryptd
[ 1803.778569] pata_atiixp ahci libahci psmouse ohci_hcd ehci_pci ehci_hcd r8169 libata mii usbcore i2c_piix4 usb_common scsi_mod
[ 1803.778576] Preemption disabled at:
[ 1803.778576] [<ffffffffbd273908>] __unmap_single.isra.22+0x98/0x1c0
[ 1803.778579] CPU: 1 PID: 458 Comm: irq/27-enp3s0 Tainted: G W 4.9.0-5-rt-amd64 #1 Debian 4.9.65-3+deb9u2
[ 1803.778580] Hardware name: ECS A58F2P-M4/A58F2P-M4, BIOS 1.0 01/13/2015
[ 1803.778583] 0000000000000000 ffffffffbd14006b ffffffffbd273908 ffffbd3641183b90
[ 1803.778585] ffffffffbcea49c3 0000000000000000 ffffffffbd425c1b 00ff9bf179ae2f40
[ 1803.778587] ffff9bf17ece9a00 ffff9bf178910fc0 ffff9bf178910fc0 ffffbd3641183bd0
[ 1803.778587] Call Trace:
[ 1803.778594] [<ffffffffbd14006b>] ? dump_stack+0x5c/0x81
[ 1803.778596] [<ffffffffbd273908>] ? __unmap_single.isra.22+0x98/0x1c0
[ 1803.778599] [<ffffffffbcea49c3>] ? __schedule_bug+0x73/0xc0
[ 1803.778602] [<ffffffffbd425c1b>] ? __schedule+0x4fb/0x5b0
[ 1803.778604] [<ffffffffbd425d13>] ? schedule+0x43/0xc0
[ 1803.778606] [<ffffffffbd4279ef>] ? rt_spin_lock_slowlock+0x1ef/0x340
[ 1803.778607] [<ffffffffbd273926>] ? __unmap_single.isra.22+0xb6/0x1c0
[ 1803.778615] [<ffffffffc06c0541>] ? rtl8169_poll+0x421/0x660 [r8169]
[ 1803.778619] [<ffffffffbd31eea1>] ? net_rx_action+0x311/0x490
[ 1803.778622] [<ffffffffbce277e3>] ? __switch_to+0x343/0x7d0
[ 1803.778624] [<ffffffffbce828b7>] ? do_current_softirqs+0x207/0x3b0
[ 1803.778627] [<ffffffffbcede8f0>] ? irq_finalize_oneshot.part.37+0xd0/0xd0
[ 1803.778628] [<ffffffffbce82ab7>] ? __local_bh_enable+0x57/0x70
[ 1803.778630] [<ffffffffbcede93c>] ? irq_forced_thread_fn+0x4c/0x70
[ 1803.778631] [<ffffffffbcedec99>] ? irq_thread+0x129/0x1e0
[ 1803.778632] [<ffffffffbd425997>] ? __schedule+0x277/0x5b0
[ 1803.778634] [<ffffffffbcedeab0>] ? wake_threads_waitq+0x30/0x30
[ 1803.778635] [<ffffffffbcedeb70>] ? irq_thread_dtor+0xc0/0xc0
[ 1803.778637] [<ffffffffbce81637>] ? do_group_exit+0x47/0xc0
[ 1803.778639] [<ffffffffbce9d967>] ? kthread+0xd7/0xf0
[ 1803.778641] [<ffffffffbce9d890>] ? kthread_park+0x60/0x60
[ 1803.778643] [<ffffffffbd42a5d1>] ? ret_from_fork+0x41/0x50
  • ozzyrob
  • ozzyrob's Avatar
  • Visitor
  • Visitor
13 May 2018 05:02 #110646 by ozzyrob
With this combo Asus M2N68-AM Plus, Athlon 64X2 5200+, 4GB ram and a Radeon HD 5450/6350 card booting from Stretch Preempt-RT from usb and adding isolcpus=1 I'm getting max jitter:
Servo thread (1ms) of 5742ns
Base thread (25us) of 16522ns
Without that option I can't run a servo & base thread latency test without getting the realtime error.
My sytsem gets a kernel panic with the -4 option (ie the first 2 boot options) but is fine with the -5 (second 2 boot options).
When you boot your system press TAB on the option you want to boot then add isolcpus=
Depending on the number of cores will depend on what comes after the equals sign.
This wiki page:
wiki.linuxcnc.org/cgi-bin/wiki.pl?The_Is..._Parameter_And_GRUB2
explains it
I'm liking some of these older AMD MB and Radeon combos.
If you want to run a latency test with just the servo thread try in a terminal:
latency-test 1000000 1000000
Can't explain why one config works and the other doesn't. I guess it would have to be a process of elimination to see where the culprit is. But from what I can gather preempt disabled is a code issue in a driver, which would seem to be the failure to launch.
  • Lcvette
  • Lcvette's Avatar Topic Author
  • Platinum Member
  • Platinum Member
13 May 2018 06:05 #110653 by Lcvette
This wiki page:
explains it
i just read that article and its very interesting, i looked up my processor and it is very dissapointing..lol it is a dual core 3.5ghz but is very slow apparantly even compared to an intel core i3. stablecomputer.com/amd-a6-7400k-apu-review/
i am not sure even where to begin to go in and do the settings to try the isolcpus= option.. it appeared to be for rtai or a different version of preempt-rt, i am so new to linuxcnc and linux that it needs to be pretty much almost copy and paste type settings or instructions for me to be able to keep up...lol
  • ozzyrob
  • ozzyrob's Avatar
  • Visitor
  • Visitor
13 May 2018 07:33 #110657 by ozzyrob
Mine's even a lower spec cpu, dual core @ 2.7Ghz, than yours lol. No I'm not starting a "mines worse than yours" bragging contest lol....
Ok...
When you boot from the USB stick you get the boot option menu.
On the option you what to boot press the TAB key instead of pressing RETURN to boot.
At the bottom of the screen it will have some lines of text, After the last word, "persistence" or "nopersistence" depending on your choice, just type the text:
isolcpus=1
remember to insert a space between the last word and isolcpus=1
then press RETURN to boot.
  • Lcvette
  • Platinum Member
  • Platinum Member
13 May 2018 07:35 #110658 by Lcvette
ah, i don't boot from a usb stick.. maybe thats why i was not understanding
Time to create page: 0.240 seconds
