- LinuxCNC
- General LinuxCNC Questions
- 2.8 pre - external offsets and negative adaptive speed working, check this !!
- Grotius
- Thank you received: 2349
13 May 2018 20:25 - 13 May 2018 20:30 #110701
by Grotius
reprository : github.com/michelwijnja/external_offsets.git
to install :
git clone github.com/michelwijnja/external_offsets.git linuxcnc_external_adaptive
cd debian => configure -r
cd src => ./autogen.sh + ./configure
make -j2 + sudo make setuid
cd scripts => . ./rip-environment + linuxcnc
To enable adaptive-feed, type in mdi : m52 P1
To play with negative adaptive feed, type in halshow command line : setp motion.adaptive-feed -1
2.8 pre - external offsets and negative adaptive speed working, check this !! was created by Grotius
to install :
Last edit: 13 May 2018 20:30 by Grotius.
- grijalvap
- Thank you received: 63
01 Jun 2018 01:18 #111369
by grijalvap
Replied by grijalvap on topic 2.8 pre - external offsets and negative adaptive speed working, check this !!
what is adaptive sped?
- Thank you received: 2175
01 Jun 2018 01:32 #111370
Replied by cmorley on topic 2.8 pre - external offsets and negative adaptive speed working, check this !!
_negative_ adaptive speed allows the gcode program to run backwards with some limitations.
Chris M
Chris M
The following user(s) said Thank You: grijalvap
- LinuxCNC
Time to create page: 0.123 seconds
