Lathe Spindle encoder with cheap (max. 50$) LPT Breakeout board
8 years 5 months ago #110863 by denhen89
You are right and i was thinking the same to reduce it in the .ini. Still. thanks for taht Andy.
Now i am still wondering how the calculation of the spindle encoder sampling rate works. Could you help me out with that. Even is someone would say (as PCW think i did ont he example with my latency of 5000-7000) that i should have an sampling rate of 50-60 Khz, i would still like to understand that, just to learn it :)
Thanks in advance.
8 years 5 months ago #110865 by andypugh
denhen89 wrote: Now i am still wondering how the calculation of the spindle encoder sampling rate works.
You already did the calculation, you just chose not to believe the answer.
1000000000 / 31250 = 32kHz
If you use a 10,000 base thread then you get 100kHz
8 years 5 months ago #110866 by denhen89
Thank you very much ! :)
Now i know that i can also try it with an cheaper board, because it should theoretically work pretty good with the spindle "software encoder".
Andy, it would be great if you could answer me 2 questions:
1. I saw on your youtube videos that you are using 2 mpg handwheels on your lathe. Do you use them much? If so, more just for positioning or also for cutting ?
2. If i would also want to add 2 mpgs, how does it then work with the encoder sampling rate? 100 KHz no mater how many software encoder i use or does the sampling rate gets lower the more software encoder i use?
Thanks in advance!
8 years 5 months ago #110867 by andypugh
denhen89 wrote: 1. I saw on your youtube videos that you are using 2 mpg handwheels on your lathe. Do you use them much? If so, more just for positioning or also for cutting ?
I actually have 4 mpgs on the lathe, one for feed override, one for spindle override and the X and Z ones on the saddle.
I use them a lot. Both for positioning before starting a cycle and for touching-off, and also for some machining (mainly for parting rather than other ops)
Every encoder is sampled every rev, so they all work at the same speed irrespective of how many there are.
Though I should point out that my lathe has a big collection of Mesa cards. There is even a 7i73 in the saddle just to handle the MPGs and the limit switches (so that the only wire from the saddle to the main controller is a single CAT5)
8 years 5 months ago #110868 by denhen89
Oh yes i remember, there was 4 handwheels on your lathe!
Hm, so maybe i will when everything is working well also install at least 2 mpgs.
But now i have to ask again just to make sure i understand it correctly: Even i will use a software encoder, i could also use the mpg handwheels and with the "very good" latency i have and the good encoder sampling rate, the mpg handwheels will work fine, no matter how many i would have installed? I am also asking because someone from youtube told me they might not work properly if i will turn them quickly, like that some steps could be missed.
You very eperienced with cnc/linuxcnc and all those things, so for sure you have good reasons to use that kind of setup, but i am trying to safe a bit money, because i just finnished the cnc router and due to the much fun i have doing those things i also started the Lathe project. So, spending a lot of money in the best hardware doesnt make any sense as long as i dont make any money with it, but of course i still want to build an nice lathe :)
8 years 5 months ago - 8 years 5 months ago #110869 by andypugh
denhen89 wrote: But now i have to ask again just to make sure i understand it correctly: Even i will use a software encoder, i could also use the mpg handwheels and with the "very good" latency i have and the good encoder sampling rate, the mpg handwheels will work fine, no matter how many i would have installed?
Yes. All the input pins are read at the same time regardless of how many are actually active / used.[/quote]
You mentioned linear slides. I am not sure that's a good idea. I think most CNC lathes still use normal ways. I think they are stiffer.
Last edit: 8 years 5 months ago by andypugh.
Time to create page: 0.087 seconds
