- Thank you received: 27
That are good news! ThanksYes. All the input pins are read at the same time regardless of how many are actually active / used
Yes, you are right. It will not anymore be that stiff as the normal ways, but i talked with someone here from Poland and he has done it . He has first convert the same machine to cnc on the original ways after they got grinded, but then because of time and costs he decided to rebuild it on linear rails which he has laying around. That are only 25mm rails, but he said even they are not that stiff he is very satisfied. There are a lot of pictures in Polish cnc forum and just after he finished the lathe on linear rails, he took the next (same lathe) and did exactly the same. I think if it would be that bad, then he wouldnt do it again.You mentioned linear slides. I am not sure that's a good idea. I think most CNC lathes still use normal ways. I think they are stiffer.
verticalperformance wrote: Does CNC Threading fine within the limitations of the machine itself - primarily not enough torque at low speeds, which limits both the diameter and pitch of the thread being cut.
verticalperformance wrote: Yes, except my spindle encoder gets in the way of the hand crank as they are both mounted on the spindle extension past the pulley
rodw wrote: The spindle nut has grooves in it for a C spanner so I was going to start by painting each groove. One Day....
