Thread milling.
- marsheng
02 Jun 2018 23:31 #111487
by marsheng
Thread milling. was created by marsheng
If I want to thread mill, does the spindle shaft need to run an encoder or will a single prox on the shaft be enough to synchronize the z with the x and y travels ?
My spindle max is 6000 RPM.
Running Mesa boards (when I get it running !!!)
- BigJohnT
- Thank you received: 994
03 Jun 2018 14:07 #111505
by BigJohnT
Replied by BigJohnT on topic Thread milling.
Thread milling is just G code, no spindle sync is needed. For rigid tapping you need an encoder on the spindle.
JT
JT
Time to create page: 0.066 seconds
