MESA 7I76E
- monit111
18 Jun 2018 16:57 #112552
by monit111
MESA 7I76E was created by monit111
Hi all
i got my new 7I76E and tried to connect it to an ac servo with 10000 increments per 360 degree.
i have come across a number of issues when setting up
1 im not sure how to go about installing the firmware on card or were to find it?
2 linux cnc only showed me 4 axis not 5 do I need to be worried?
would appreciate any help with this
thank you
thank you
- Thank you received: 5321
18 Jun 2018 17:26 #112554
Replied by PCW on topic MESA 7I76E
1 You do not need to install firmware unless you have a specific daughtercard you need to be supported
2. The number of axis is dependent on LinuxCNC setup/kinematics. The 7I76E supports 5 Axis in hardware but a 5 axis hal/ini file must be used and I'm pretty sure this must be created by hand (pncconf wont make 5 axis configs)
The following user(s) said Thank You: monit111
- monit111
19 Jun 2018 10:25 #112572
by monit111
Replied by monit111 on topic MESA 7I76E
thanks
by any chance you would not know how I can setup and wire an ac servo to this board?
it has 2 step 2 direction also has ground but I don't understand the 5V out I don't think the driver I have uses 5V in?
again thanks
again thanks
- tecno
- Thank you received: 127
19 Jun 2018 11:04 - 19 Jun 2018 11:05 #112574
by tecno
Replied by tecno on topic MESA 7I76E
This will get you going
Last edit: 19 Jun 2018 11:05 by tecno.
- JohnnyCNC
- Thank you received: 115
19 Jun 2018 22:22 #112599
by JohnnyCNC
Replied by JohnnyCNC on topic MESA 7I76E
I don't know why but click on the picture of the piece of paper and not the button with the "I" on it and it opens for me.
- monit111
21 Jun 2018 16:29 #112730
by monit111
thanks
you would not know why I cant seem to ping the board at all?
I cant seem to setup the motors to it.
all wiring is perfect but still can not control servo.
- tecno
21 Jun 2018 16:37 #112731
by tecno
You have to set your IP to 10.10.10.11 as the 7i76e is 10.10.10.10
Then you can ping
Then you can ping
- monit111
21 Jun 2018 16:46 #112732
by monit111
have done that already and it refusing to establish a connection
its says 7i76e can not be found.
when using mesa flash commands.
- tecno
21 Jun 2018 16:50 #112733
by tecno
Have you applied field power as in manual?
What does the LED's show, have a look in manual for error messages from leds.
21 Jun 2018 17:17 - 21 Jun 2018 17:18 #112734
1. What IP address is selected on the 7I76E, and did you power cycle the 7I76e after changing the IP address option?
2. What does the command "ip a" print?
3. Do you have link LEDs on? (yellow and green on 7I76E Ethernet Jack)
4. What Mesaflash command did you try?
Last edit: 21 Jun 2018 17:18 by PCW.
