Hi Chris:
Thank You for your prompt reply!
Have not used the forum before, first time.
No, it does not appear to output gcode. I really don't know. I don't have a way to test it, nor to "snoop" the output of the program application.
However, there is a gcode interface, and with help from the OEM, was able to use the interface, able to communicate with the control board, but not able to make it move.
It is called Techno CPM GCODE Interface (version 2.53 and is copyrighted 2003).
It was on the Win XP computer with the program.
I do have the ISEL programming guide for our machine which is called a CPM machine.
It looks like a proprietary programming language. Some of the other machines in this group use pascal and DOS.
I do have the application program which is relatively small at 1.5megs, and can email it to you as a .txt file.
My email is: lensmanufacturing@gmail.com
Also, I could mail you a copy of the application program, if you like.
Been working on it since January 2018, and my repairs for changing capacitors, voltage regulators, now integrated circuits is last on the list. More.
