MPG count going mad
- Thank you received: 5326
11 Jul 2018 17:25 - 11 Jul 2018 17:35 #114016
Replied by PCW on topic MPG count going mad
The FPGA SSLBP code is the same (but is the same for all sserial devices and the code doesn't know anything about types, just data sizes)
I would expect after some usage that the rawcounts and position to be at some arbitrary larger number
so how they get to +-127 is perhaps a bit odd since the8 bit --> 32 bit extension logic could not get there easily
regardless of the raw sserial data (assuming it started at some big number)
Last edit: 11 Jul 2018 17:35 by PCW.
12 Jul 2018 13:04 #114055
Replied by andypugh on topic MPG count going mad
The sserial data from the MPG is an 8-bit signed value (s far as I recall)
It gets extended to 64 bit by this code here:
github.com/LinuxCNC/linuxcnc/blob/master...mot2/sserial.c#L2040
I am starting to wonder if pin->accum is being used uninitialised. (and if that matters)
12 Jul 2018 14:10 #114060
If you do see this behaviour occasionally perhaps you could add a "enable_raw"
token to the hostmot2 config string so the actual sserial registers could be checked
this would determine if the error is in the FPGA/SSerial remote or higher up
- OT-CNC
- Thank you received: 75
25 Jul 2018 17:14 #114816
by OT-CNC
Replied by OT-CNC on topic MPG count going mad
Okay so this problem returned yesterday. I took a quick video. Seems to be more random this time. First half of vid is with smaller units and second half with faster travel, larger increments selected. Next time what should I load or do that may be of better help?
TIA
TIA
25 Jul 2018 19:06 #114827
What are the signal levels on the MPG lines in both states?
- OT-CNC
25 Jul 2018 20:55 #114836
by OT-CNC
Sorry, which signal levels from the MPG are you inquiring about?
On the X axis I was switching between:
setp mux4.0.in2 0.0000010
setp mux4.0.in3 0.0000100
low pass scale is at:
setp ilowpass.0.scale 1000
setp ilowpass.0.gain 0.02
25 Jul 2018 20:57 #114837
The quadrature pins on the 7I77 since this could possibly be a noise issue
- OT-CNC
26 Jul 2018 02:41 #114851
by OT-CNC
Okay I will look at them the next time this happens again although I don't think it's noise. I restarted linuxcnc and the problem went away just like the 1st time. It was reversing in a similar fashion as before. Just not repeatedly at the 127 count. It's not the clearest video as I possibly was reversing the handwheel to get it to trigger at a specific number. Sorry for not pointing that out.
So far this has been noticed only on start up when I'm moving the X away from the home position. It's never happened randomly or after running the machine for a while. I also payed attention to not move the cord on the MPG to rule out a broken wire.
02 Aug 2018 22:09 #115456
I logged the counts while turning the MPG slowly clockwise.
www.filedropper.com/7i73
And it appears that the pattern is exactly what you get if you gray-decode something that is actually straight binary.
codepad.org/djo4SJse
So it seems that either the 7i73 is wrongly claiming to be graycode, or a driver bug is wrongly deciding to treat it as graycode.
02 Aug 2018 22:31 #115461
And it won't be the 7i73 claiming to be graycode because smart-serial knows nothing of graycode.
What I think is happening is that I am failing to set the graycode and no-wrap flags to zero in smart-serial. Those flags exist for absolute encoders, which re-use the same code for their runtime-confgurable pins.
Time to create page: 0.959 seconds
