I'm finding it hard to believe that no one has figured out how to add more than 2 relays.. I am searching everywhere and all I can find is amateurs teaching other amateurs how to cut corners and use spindle and coolant mist. It doesn't take a genius to figure out that you may need those for an actual spindle and mist system. I personally would be embarrassed to do a TUT on how to cut corners especially if there where already 50 other vids.
Personal suggestion: Linuxcnc should come loaded with commands and drop-downs for up to 80 relays for stage effects, sound, and lighting professionals. I my self would like several for: spindle, mist, vac table, dust vac, laser, auto tool-change, material loader, material unload-er, abort, home, running/diag lights, camera, motor power supplies, bob shutdown, self shutdown. that's already 14
