General LinuxCnc Program Questions
- BrassCat
15 Jul 2018 00:06 #114191
by BrassCat
General LinuxCnc Program Questions was created by BrassCat
Hello the forum. I am new to the group, registered quite a while ago, but just now posting.
It was maybe a year ago I found at the local metal scape yard a gantry style engraving machine, maybe 11x14 bed size. Very solid build, probably US made, maybe 20 years old? All the electronics had be stripped out! That is probably a good thing. Most all of the structure is castings. Considering using linuxcnc to run it through a single board x86 quad with enough GPIO pins.
Seems a lot of the computer used for Linux are x86 style with 2 or more cores. Is linuxcnc written to make use of the multiple cores? I am sure it has multiple threads, but not certain if it can use multiple cores concurrently.
How much ram does a typical installation require.
Questions about motion limits but will start another thread.
Stan
Stan
- Thank you received: 2175
15 Jul 2018 00:50 #114195
Replied by cmorley on topic General LinuxCnc Program Questions
The computer choice goes mostly down to good latency with enough cpu power left over to run the non-realtime programs - which really means the CNC screen response.
There are recommended motherboards, but if you have some old computers laying around you might as well just test them.
Chris M
Chris M
- BrassCat
17 Jul 2018 03:39 #114348
by BrassCat
Replied by BrassCat on topic General LinuxCnc Program Questions
Hello Chris, thanks for the response.
Time to create page: 1.011 seconds
