Touch probe et plate sur la meme entrée
- Philippe
20 Jul 2018 06:16 #114564
by Philippe
Touch probe et plate sur la meme entrée was created by Philippe
Bonjour a tous,
je désire mettre une touch probe sur ma CNC, j'ai deja une plate probe pour la mesure automatique de la hauteur de l'outil,
quelqu'un c’est -il comment faire car sur ma carte beak borad je n'ai qu'une seule entrée , ainsi que le le paramétrage du HAL.
merci de votre retour.
- JohnnyCNC
- Thank you received: 115
20 Jul 2018 11:11 #114581
by JohnnyCNC
Replied by JohnnyCNC on topic Touch probe et plate sur la meme entrée
"Hello everyone,
I want to put a touch probe on my CNC, I already have a flat probe for the automatic measurement of the height of the tool,
someone is it how to do because on my card board beak I have only one entry, and the setting of the HAL."
I'll get you the HAL settings that I used when I get home tonight unless someone provides the info sooner.
Here is a link for the hardware side of what I made.
forum.linuxcnc.org/27-driver-boards/3114...late-short-to-ground
- JohnnyCNC
20 Jul 2018 23:56 #114621
by JohnnyCNC
I'm not sure I fully understood your question. If you are trying add a 3D touch probe I can't help with that but if you are trying to get the probe you have to measure tool length then here is the info I have. I am not the original author. I found it on a forum, probably here. I am using Mesa cards and you will have to change the hardware pin names to those appropriate for your machine.
Good Luck
HAL Entries
#limits debounce to stop false triggers
loadrt debounce cfg=2 #change to the number you want
setp debounce.0.delay 100 #this sets the delay 100 iterations of the servo-thread
addf debounce.0 servo-thread
net deb-probe-in debounce.0.0.in <= hm2_5i25.0.7i76.0.0.input-05-not
net probe-in debounce.0.0.out
net probe-in => motion.probe-input
net run-touch-btn <= hm2_5i25.0.7i76.0.0.input-06 => halui.mdi-command-04
# ---probe signal---
Entry in: custom-postgui.hal
net remote-oTouchPlateProbeButton halui.mdi-command-03 <= pyvcp.oTouchPlateProbeButton
ini file entries
[HALUI]
MDI_COMMAND=G28
MDI_COMMAND=M7
MDI_COMMAND=M9
MDI_COMMAND=o100 call <-- This line is for button on the screen (Command 03)
MDI_COMMAND=o100 call <--- This one is for the physical button on t he touch plate (Command 04)
MDI_COMMAND=...
MDI_COMMAND=...
MDI_COMMAND=...
MDI_COMMAND=G10 L20 P1 X0
MDI_COMMAND=G10 L20 P1 Y0
MDI_COMMAND=G10 L20 P1 Z0
MDI_COMMAND=G0 X0
MDI_COMMAND=G0 Y0
MDI_COMMAND=G0 Z0
Entry in the pyvcp-panel.xml file
This will put a button o n t he screen in Axis
<button>
<halpin>"oTouchPlateProbeButton"</halpin>
<text>"Touch Off Z"</text>
<font>('fixed',10)</font>
</button>
100.ncg file
Put the following in a file named 100.ncg and place the file in your ncg_files directory
<pre>
o100 sub
G20
( Set current Z position to 0 so that we will always be moving down )
G10 L20 P0 Z0
( Probe to Z-.5 at F2 [Uses machine units, I work in inch, this is meant to be slow!] )
G38.2 Z-.25 f2
( Set Z0 at point where probe triggers with offset of +1.007 [this is the thickness of my touch plate. You must adjust this for your plate / setup] )
(G10 L20 = Set Coordinate System // P - coordinate system 0-9 0 = Not active)
G10 L20 P1 Z1.007
( Rapid up to Z.5 above the material )
(G10 L20 P1)
(Use machine coordinates)
G90
G53 G0
(Incremental mode)
G91
(Rapid Z up 1 inches)
G0 Z1
o100 endsub
</pre>
Good Luck
HAL Entries
ini file entries
[HALUI]
MDI_COMMAND=G28
MDI_COMMAND=M7
MDI_COMMAND=M9
MDI_COMMAND=...
MDI_COMMAND=...
MDI_COMMAND=...
MDI_COMMAND=G0 X0
MDI_COMMAND=G0 Y0
MDI_COMMAND=G0 Z0
<button>
</button>
100.ncg file
<pre>
o100 sub
G20
G10 L20 P0 Z0
G38.2 Z-.25 f2
G10 L20 P1 Z1.007
(G10 L20 P1)
G90
G53 G0
(Incremental mode)
G91
G0 Z1
o100 endsub
</pre>
- Philippe
24 Jul 2018 07:15 #114731
by Philippe
Replied by Philippe on topic Touch probe et plate sur la meme entrée
Thanks to your answer,
Yes I want to add 3D touch probe with a touch to measure the tools on the same input if is possible because on my breakbord there is just one input for the probe and in linuxcxnc configuration.
- Thank you received: 4654
27 Jul 2018 17:06 #114962
Replied by andypugh on topic Touch probe et plate sur la meme entrée
Oui, c'est possible.
Wire the probes in series into the same input (assuming that they are both normally-closed and open on contact)
Time to create page: 0.727 seconds
