homing internal driver AC servo?
- thang
- Thank you received: 11
20 Jul 2018 07:47 #114565
by thang
homing internal driver AC servo? was created by thang
I'm using a HC-KFS13 motor with MR-J2S-10A driver, i want to control this motor by step/dir pulse system. as i see i can setup home position for driver but dont know how to return home for motor, there is only one signal "INP" to know when motor is in home position.I suppose i should use this signal like a home button, right?
If anyone has experience about Mitsubishi AC servo can help me?
Here is the driver's manual:
dl.mitsubishielectric.com/dl/fa/document...030006/sh030006j.pdf
- Thank you received: 4654
23 Jul 2018 14:44 #114708
Replied by andypugh on topic homing internal driver AC servo?
In a step-dir LinuxCNC system you don't need (or want) to home the drive.
- thang
25 Jul 2018 02:15 #114787
by thang
Replied by thang on topic homing internal driver AC servo?
actuatly i want to use absolute encoder of Mitsubishi driver. The home return is describe in section 15.7.3 but i dont really understand it.
If it possible i would like to use abs encoder and homing inside driver and then i can use a simple controller instead of linuxcnc also SSCII protocol
- dm17ry
- Thank you received: 89
25 Jul 2018 23:39 #114847
by dm17ry
Replied by dm17ry on topic homing internal driver AC servo?
no experience with MR-J2S-A drives, but as far as i understand all the "15.7.3 Home position setting" operations are really doing is writing current motor position counters (which are named "LS" - full rev count and "1X" - with 1-rev pos on picture 15.1.1) into parameter EEPROM as "LS0" and "1X0". after that when the controller requests absolute position data (15.7.1) the drive returns current motor position subtracted with home position (LS-LS0, 1X-1X0).
so if you want to use absolute position you'll need to use that cumbersome protocol 15.7.1 to request the motor position and pass it to linuxcnc
The following user(s) said Thank You: thang
30 Jul 2018 00:02 #115096
_If_ you can get the absolute position in to HAL then LinuxCNC can work with it.
See HOME_ABSOLUTE_ENCODER
linuxcnc.org/docs/devel/html/config/ini-...t__lt_num_gt_section
Time to create page: 0.467 seconds
