Gremlin screen add right mouse click to add g-code options
  • Grotius
  • Grotius's Avatar Topic Author
  • Platinum Member
  • Platinum Member
27 Jul 2018 19:56 #114984 by Grotius
Hi i would like to add some functions to the gremlin screen.
Does someone know about previous try out's or developments?
I would like to increase the tool contrast to light and darker mode.
I would like to select a g-code line at the gremlin screen that then can be edited in the loaded gcode for adding plasma bevel lines.
28 Jul 2018 23:03 #115035 by cmorley
hal_gremlin emits a GStat message when a line is clicked. It returns the line number.
If you connected to this message then you could possibly do what you wish.
hal_sourceview uses it to highlight a clicked line.
colors can be changed by using the signature (in hal_gremlin.py):
self.colors = (0.0, 0.0, 0.75) # blue
the color variables are set in glcanon.py:
colors = {
        'traverse': (0.30, 0.50, 0.50),
        'traverse_alpha': 1/3.,
        'traverse_xy': (0.30, 0.50, 0.50),
        'traverse_alpha_xy': 1/3.,
        'traverse_uv': (0.30, 0.50, 0.50),
        'traverse_alpha_uv': 1/3.,
        'backplotprobing_alpha': 0.75,
        'backplotprobing': (0.63, 0.13, 0.94),
        'backplottraverse': (0.30, 0.50, 0.50),
        'label_ok': (1.00, 0.51, 0.53),
        'backplotjog_alpha': 0.75,
        'tool_diffuse': (0.60, 0.60, 0.60),
        'backplotfeed': (0.75, 0.25, 0.25),
        'back': (0.00, 0.00, 0.00),
        'lathetool_alpha': 0.10,
        'axis_x': (0.20, 1.00, 0.20),
        'cone': (1.00, 1.00, 1.00),
        'cone_xy': (0.00, 1.00, 0.00),
        'cone_uv': (0.00, 0.00, 1.00),
        'axis_z': (0.20, 0.20, 1.00),
        'label_limit': (1.00, 0.21, 0.23),
        'backplotjog': (1.00, 1.00, 0.00),
        'selected': (0.00, 1.00, 1.00),
        'lathetool': (0.80, 0.80, 0.80),
        'dwell': (1.00, 0.50, 0.50),
        'overlay_foreground': (1.00, 1.00, 1.00),
        'overlay_background': (0.00, 0.00, 0.00),
        'straight_feed': (1.00, 1.00, 1.00),
        'straight_feed_alpha': 1/3.,
        'straight_feed_xy': (0.20, 1.00, 0.20),
        'straight_feed_alpha_xy': 1/3.,
        'straight_feed_uv': (0.20, 0.20, 1.00),
        'straight_feed_alpha_uv': 1/3.,
        'small_origin': (0.00, 1.00, 1.00),
        'backplottoolchange_alpha': 0.25,
        'backplottraverse_alpha': 0.25,
        'overlay_alpha': 0.75,
        'tool_ambient': (0.40, 0.40, 0.40),
        'tool_alpha': 0.20,
        'backplottoolchange': (1.00, 0.65, 0.00),
        'backplotarc': (0.75, 0.25, 0.50),
        'm1xx': (0.50, 0.50, 1.00),
        'backplotfeed_alpha': 0.75,
        'backplotarc_alpha': 0.75,
        'arc_feed': (1.00, 1.00, 1.00),
        'arc_feed_alpha': .5,
        'arc_feed_xy': (0.20, 1.00, 0.20),
        'arc_feed_alpha_xy': 1/3.,
        'arc_feed_uv': (0.20, 0.20, 1.00),
        'arc_feed_alpha_uv': 1/3.,
        'axis_y': (1.00, 0.20, 0.20),
        'grid': (0.15, 0.15, 0.15),
Time to create page: 0.631 seconds
