Mesa FPGA choice for 6 axis stepper.
  • Grotius
  • Grotius's Avatar Topic Author
  • Platinum Member
  • Platinum Member
06 Aug 2018 18:33 #115683 by Grotius
Mesa FPGA choice for 6 axis stepper. was created by Grotius
I was searching on the Mesanet and found a few FPGA boards.
Wich one is usable for making a 6 axis step/dir configuration with ethernet connection?
Thanks !
06 Aug 2018 19:30 #115685 by Todd Zuercher
Replied by Todd Zuercher on topic Mesa FPGA choice for 6 axis stepper.
Really, the answer is all of the Either net connected boards can support more than 6 step-gens. But none of them have 6 ready to use step/dir outputs like a 7i76. One of the best solutions would be to use either a 7i76e (or 7i96) plus a 7i78 for a total of 9 available step/dir outputs. Another option would be a 7i93 plus a 7i47. However any of the FPGA cards are capable of more than 6 step-gens by them selves, if you are willing to risk using some of the FPGA pins bear or with some other breakout board(s).
  • Grotius
  • Platinum Member
  • Platinum Member
06 Aug 2018 19:44 - 06 Aug 2018 19:53 #115686 by Grotius
Replied by Grotius on topic Mesa FPGA choice for 6 axis stepper.
Hi Todd,
My order wiil be 2 separate boards.
1. One ethernet board ready, and easy to go,
But for this ethernet board i need the thcad add on board, and also din rail mounted cable plug in's.
2. One ethernet fpga board with the possibility for 6 axis stepper with a few i/o.
But there are more then 4 fpga boards, and the description on the Mesenet website is limited. So i can't really see what the difference is. The Mesa numbers are quite confusing. If they have numbers related to board function it's better to understand for newbies.
Last edit: 06 Aug 2018 19:53 by Grotius.
06 Aug 2018 20:45 - 06 Aug 2018 20:45 #115688 by PCW
Replied by PCW on topic Mesa FPGA choice for 6 axis stepper.
If you are going to use use LinuxCNC master I would use a 7I96 and a 7I78
or a 7I96 and a generic Ebay 5 Axis BOB
A 7I76/7I76E makes more sense if you can use the 48 digital I/O points but those would likely go unused on a plasma machine.
Last edit: 06 Aug 2018 20:45 by PCW.
  • Grotius
  • Platinum Member
  • Platinum Member
06 Aug 2018 20:52 - 06 Aug 2018 21:00 #115690 by Grotius
Hi Pcw,
You know me, I want best of the best from Mesa. Extra I/O is welcome, no problem.
I use almost master. I have master and 3 run in place versions with option's to run when i am in the mood.
When you hear about Debian 9... you know it's the best.
Can you configure for me one system for Ethernet control, max 6 stepper, multi i/o, with voltage divider input board from Mesa,
if possible all the din rail option's for this configuration. If you can give me the numbers i can check them this week before ordering.
In the same order, the second purchage is the FPGA board. Wich one is suited for 6 axis stepper with multi i/o.
If there are limeted configuration examples, i see no problem. If there is one stepper example with limited i/o example i can figure it out.
I hope you can help me pcw.
Last edit: 06 Aug 2018 21:00 by Grotius.
06 Aug 2018 21:27 #115693 by tommylight
Replied by tommylight on topic Mesa FPGA choice for 6 axis stepper.
I am using a firmware for 6i25 that does 10 stepgens and 2 encoders, a 5i25 with a config for 8stepgens, 2 PWM with directin and enable pins, 2 encoders. All wired directly to Mesa DB25 ports, just for testing for now.
Mesa should have the same configs for 7i92 so that is quite usable but no I/O pins left.
It would be nice to have 6 stepgens and an encoder on one connector and a PWM or two on the second connector together with some hal configurable I/O pins. That would be soooooo nice ! Thank you PCW.
Disclaimer:
That is for experimental purposes, so not very important for now, just have two 6i25, one 5i25 and one 7i92 wired and thinking what i could do with them. I also have two 7i77 and i know what to do with them so that leaves me with two FPGA boars to play with, and a 7i74, and two 7i84, and two 7i73 and one THCAD....ah never mind, to much things to do, not enough time.
  • Grotius
  • Platinum Member
  • Platinum Member
06 Aug 2018 21:47 #115696 by Grotius
@Tommy,
First i have to try Mesa. I want to try it once. It cost's me learning money now. But maybe it's good.
08 Aug 2018 10:18 #115797 by rodw
Replied by rodw on topic Mesa FPGA choice for 6 axis stepper.
While PCW says a plasma machine does not use much IO, I have managed to use all of the inputs on my 7i76e on my plasma table. Also, make sure that you have MPG inputs. (At least 1). I have a very cool wireless pendant that wires into the mesa hardware natively that would be good as a value added additional cost option for a commercial plasma table. Even on a 1200 x 1200 table, I would be lost without a pendant.
The 7i96 has a RS485 port on board which would be great for talking to Hypertherm plasmas but the 7i76e should be able to do this on its 4 wire RS422 port.
So unless PCW has another option with a MPG input, maybe its a 7i76e/7i76 or a 7i96/7i76
If you start doing a downdraft table 25 metres long, you'll need heaps of outputs to trigger downdraft zones so I think for an experimental build, Grotius should get as many IO pins as he can get. One of my suppliers has a 90 metre long table......
