Revesing spindle servo direction
- JohnnyCNC
- Thank you received: 115
11 Aug 2018 03:19 #115875
by JohnnyCNC
Revesing spindle servo direction was created by JohnnyCNC
I am almost done with my spindle motor conversion. I have a DYN4 1.8kw servo and I need to reverse the direction when M3 & M4 are issued. Right now M3 runs the spindle in reverse and M4 is forward. I thought there was a way using a negative value somewhere that would do it but I have been able to find it. I have tried making some of these config setting negative but did not achieve the desired result.
OUTPUT_MIN_LIMIT
OUTPUT_MAX_LIMIT
OUTPUT_SCALE
ENCODER_SCALE
I have a 5i25+7i76+7i83 using -5/+5 to control the DYN4 speed and direction.
OUTPUT_MIN_LIMIT
OUTPUT_MAX_LIMIT
OUTPUT_SCALE
ENCODER_SCALE
- Thank you received: 5321
11 Aug 2018 14:06 #115887
Replied by PCW on topic Revesing spindle servo direction
Can you post your current hal and ini files?
- JohnnyCNC
11 Aug 2018 15:05 #115889
by JohnnyCNC
Replied by JohnnyCNC on topic Revesing spindle servo direction
After some more searching I remembered that I saw that on Pncconf there was a "invert motor direction" check box. I created a dummy profile and that lead me to this:
MAX_OUTPUT = 3000.0
OUTPUT_MIN_LIMIT = -3000
OUTPUT_MAX_LIMIT = 3000
OUTPUT_SCALE = -3000
ENCODER_SCALE = 1
Which appeared to work but after one forward, stop, reverse test the drive appears to be dead. I have voltage going to the power and control inputs but the motor won't run. The tuning software will also not connect.
MAX_OUTPUT = 3000.0
ENCODER_SCALE = 1
- Thank you received: 4652
16 Aug 2018 11:00 #116121
Replied by andypugh on topic Revesing spindle servo direction
Did you solve this? It may be that the drive needs a braking resistor to handle spindle reversal.
Though it sounds like you might have found this out the hard way.
- JohnnyCNC
16 Aug 2018 11:56 #116128
by JohnnyCNC
Sort of. Tech support is sending a new drive. They never mentioned or asked about the braking resistor. This is what the manual says about it. I did see an overvolt alarm one time during previous testing.
Regenerative Resistor
The DIPM power module unit built into the DYN4 servo drive is designed with a very efficient bus voltage attenuation control circuit. It is much more efficient than conventional servo drives when handling servo motor regenerative energy. Generally, external regenerative resistors are not needed. If the servo drive often throws “Over Voltage“ alarm, contact DMM representative for custom regenerative energy sizing procedures.
I will asked them about the resistor before proceeding with the new drive. I am also going to ask them for recommended parameter settings when used as a spindle more. I have no need for the spindle to stop on a dime and be at requested speed in a millisecond. I was to have must softer starts and stops.
Should my OUTPUT_SCALE be set to -3000 or -6000?
Thank You
Thank You
16 Aug 2018 12:10 #116129
What is your spindle speed at a commanded 10V?
Use that number.
Use that number.
- JohnnyCNC
16 Aug 2018 12:43 #116134
by JohnnyCNC
Right now I'm testing just the motor on the bench. The motor's max RPM is 3000 and it does that at 5 volts. So is that where the 6000 came from? I think that came out of Pncconf.
For bench testing I set it up as if my spindle RPM would be 0 - 3000. After I install the motor with the belt drive 1:1.8 The spindle RPM will be 0 to 5400.
16 Aug 2018 13:21 #116146
Use -5400 then, so you don't need to remember to change it.
