Seems linuxcnc has bug with speed
  • aleksamc
  • aleksamc's Avatar Topic Author
  • Platinum Member
  • Platinum Member
11 Aug 2018 12:33 #115882 by aleksamc
Seems linuxcnc has bug with speed was created by aleksamc
I saw this problem in the past but never write about it.
I have axis Z, that is much slower then other X and Y axes. Z has max speed only 22mm/s. Other axes are much faster.
Everything works fine at first time. But after some time of milling process, I see that axis Z become very fast. It stalls simultaneously at that
time and lost coordinates. I can move Z axis in this new regime and look how it behaves. It moves very fast and when I use G0 movement it similary stalls.
If I turn off/ turn on axis it works fine, but also for some time.
I use G1 movement up but in that time it doesn't work.
I have 2.17.12 linuxcnc version. Today i upgrade it and will look if I solve my problem.
What it could be? Could be problem in the stepper drive?
  • Moderator
  • Moderator
11 Aug 2018 13:26 #115885 by tommylight
Replied by tommylight on topic Seems linuxcnc has bug with speed
Most probably missing
setp stepgen.2.maxvel [JOINT_2]MAX_VELOCITY
If using steppers or similar limit for servo.
11 Aug 2018 16:04 #115894 by PCW
Replied by PCW on topic Seems linuxcnc has bug with speed
It does sound like a setup issue if some kind, can you post your hal and ini files that exhibit this problem?
Its very unlikely to be LinuxCNC version related
  • aleksamc
  • Platinum Member
  • Platinum Member
12 Aug 2018 12:34 #115956 by aleksamc
Replied by aleksamc on topic Seems linuxcnc has bug with speed
Yes, you are right. I've added that lines to custom file.
Even without setp stepgen, after upgrading software I finished my detail without problems. As I said earlier, at first time all goes fine but after few minutes, axis Z become very fast. I hope this problem will never return.
File Name: custom.hal
File Size:0 KB
File Name: BX-3020.ini
File Size:2 KB
File Name: BX-3020.hal
File Size:3 KB
Time to create page: 0.222 seconds
