- LinuxCNC
- General LinuxCNC Questions
- Need opinion on how, and if I can make a EDM machine with linux CNC :)
- aliaj00
15 Aug 2018 19:38 - 15 Aug 2018 19:38 #116094
by aliaj00
Need opinion on how, and if I can make a EDM machine with linux CNC :) was created by aliaj00
Hi Guys,
i am Tim, and i am looking if it is possible to make a EDM machine with linuxcnc and what hardware software i might need to create such a machine.
My initial assumptions:
300 x 300 X 300 mm working area
budget for hardware <700$, i have some nema 17 and PC and extra hardware pieces.
i initially want to make precise holes, but wire EDM is what i am looking into.
i dont need this for money, i have this as a hobby
regards,
Tim
regards,
Tim
Last edit: 15 Aug 2018 19:38 by aliaj00.
- Thank you received: 1472
15 Aug 2018 20:41 #116096
Replied by Todd Zuercher on topic Need opinion on how, and if I can make a EDM machine with linux CNC :)
All I can say is that it has been done. As to how well i works or costs involved I don't know.
Search the forum and the mailing list archives for more information.
(when searching the forum be sure to set the date rage to any time, the default is 1 year old and newer.)
- tecno
- Thank you received: 127
15 Aug 2018 20:50 #116098
by tecno
Replied by tecno on topic Need opinion on how, and if I can make a EDM machine with linux CNC :)
Sorry not with that small budget.
- Thank you received: 7468
15 Aug 2018 21:15 #116100
Replied by tommylight on topic Need opinion on how, and if I can make a EDM machine with linux CNC :)
It can be done even with that little money, but requires resourcefulness in many aspects of it, like cheap rails and carriages (easy), sourcing motors (easy), drives (not so easy, but can be done very cheap), wire guides and spools ( easy but lots of patience), and most importantly the power supply ( not easy, anyway you look at it).
All in all, yes it is possible and it can be done, it was done several times just search for diy wire edm, it can be done for that kind of money and get decent results.
- tecno
15 Aug 2018 21:33 #116101
by tecno
For less than 700USD, no way. But what do I know just building one and that kind of money does not cut the cake for 300x300x300 WEDM.
Better to look for a used WEDM and do overhaul on that.
- aliaj00
15 Aug 2018 22:00 #116104
by aliaj00
Replied by aliaj00 on topic Need opinion on how, and if I can make a EDM machine with linux CNC :)
HI Guys,
thanks a lot for your help. i already have a prusa i3 3d printer and plenty of nema17 and drivers rails etc. i am not planing on doing heavy stuff not more then a few kilograms max. the part i am worry about is the software part and the IO controller. as per the power supply i have background in electronics so i will figure something out. i am not thinking of doing a lot of Amps as its a hobby in the 6 ~ 10A most. but i really like the small nice cuts of the EDM
. 300 X 300 is debatable as i don't know how big the electronics and other stuff might be or positioned. the space i have is 500 X 500 so i set initial expectations to 300 X 300.
So if i might ask, what IO controller do you guys suggest? and software config.
regards,
Tim
regards,
Tim
- Thank you received: 4652
16 Aug 2018 13:16 #116144
You might as well start with the parallel port, a WEDM doesn't need to move fast.
Once you have the machine moving with a normal LinuxCNC install then you probably want to try compiling and running the "reverse run" branch, as that can reverse out of the cut on a reciprocal path.
Replied by andypugh on topic Need opinion on how, and if I can make a EDM machine with linux CNC :)
- aliaj00
16 Aug 2018 13:50 #116149
by aliaj00
i don't have a PC with parallel port
. but will look to get and old one.
thanks for he help
regards,
Tim
thanks for he help
regards,
Tim
16 Aug 2018 13:54 #116150
It probably doesn't make sense to buy a PC with a parport if you do not already have one. It isn't the best choice by any means, just a cheap and easy one if you already have it.
What slots does your current PC have? (USB can't be used with LinuxCNC)
- aliaj00
16 Aug 2018 14:02 - 23 Aug 2018 19:27 #116154
by aliaj00
I just ordered the The Build a Pulse EDM Machine book. it will be an interesting journey.
regards,
Tim
regards,
Tim
Last edit: 23 Aug 2018 19:27 by aliaj00.
- LinuxCNC
