- LinuxCNC
- General LinuxCNC Questions
- Need opinion on how, and if I can make a EDM machine with linux CNC :)
- OT-CNC
- Thank you received: 75
11 Aug 2019 15:26 #141917
by OT-CNC
Replied by OT-CNC on topic Need opinion on how, and if I can make a EDM machine with linux CNC :)
I assume you are referring to Ben Flemings book?
I built that pulse edm years ago but never got the flushing setup correctly. So it's been collecting dust in a far corner of the shop. I have been meaning to pick up on it.
I think that power supply is the wrong type if you are trying to make a wire edm but I'm no ee and could be wrong.
You probably have come across this:
I'd like to get something like that built using linuxcnc for both sinker and wire someday.
The power supply if I recall correctly that he's using in the video is $$$
- thetomorrowman
11 Aug 2019 15:38 #141918
by thetomorrowman
Replied by thetomorrowman on topic Need opinion on how, and if I can make a EDM machine with linux CNC :)
Cool, yeah the Fleming book for a pulse EDM.
Really quite fancy something like it but a bit of research to do first.
Check out Baxedm on YouTube, he's got a great machine and website but a bit too hi end for me- looks good though
- OT-CNC
11 Aug 2019 20:56 #141931
by OT-CNC
Yeah baxedm is the same arc generator I looked into earlier. He wants almost 3K euros for it. Too much for me.
- Mike_Eitel
- Thank you received: 183
12 Aug 2019 05:09 #141945
by Mike_Eitel
Replied by Mike_Eitel on topic Need opinion on how, and if I can make a EDM machine with linux CNC :)
Not my experience but a question.
The new master 2.9 can do reverse run.
Would it be possible to use the arc voltage to "switch" to go back...
- Thank you received: 4652
12 Aug 2019 09:41 #141957
Replied by andypugh on topic Need opinion on how, and if I can make a EDM machine with linux CNC :)
There was extensive discussion about EDM on the mailing list a few years ago. It might be worth searching the mailing list archives:
sourceforge.net/p/emc/mailman/search/?q=EDM
The following user(s) said Thank You: thetomorrowman
13 Aug 2019 21:47 #142081
EDM was the main reason to introduce the feature,
- LinuxCNC
Time to create page: 0.090 seconds
