beaglebone blue
8 years 2 months ago #116417 by fafa
beaglebone blue was created by fafa
hello
is beaglebone blue compatible with LinuxCNC
fafa
8 years 2 months ago #116434 by andypugh
Replied by andypugh on topic beaglebone blue
It's probably easier to use Machinekit if you want to use a Beaglebone.
(That's a fork of LinuxCNC, but now rather different)
8 years 2 months ago #116650 by fafa
Replied by fafa on topic beaglebone blue cnc
thank for the reply
the idea is use the QEI and the DC motor drive with Linux cnc
in Beagle bone blue
but how do i begin
fafa
8 years 2 months ago #116651 by PCW
Replied by PCW on topic beaglebone blue cnc
You will need encoder counting hardware support or PRU support to do this.
Machinekit supports the beaglebones PRU, PWM, and encoder hardware so this should be fairly easy with Machinekit, but not with LinuxCNC as it does not currently support the hardware encoder counter, the PWM generators or the PRU.
I would ask here:
groups.google.com/forum/#!forum/machinekit
The following user(s) said Thank You: fafa
8 years 2 months ago #116654 by fafa
very good new very very thank you
so Linux cnc is out
then i have to begin with Machinkit
what do you recomand
thank you
fafa
8 years 2 months ago #116780 by andypugh
Replied by andypugh on topic beaglebone blue cnc
fafa wrote: very good new very very thank you
so Linux cnc is out
Machinekit is based on LinuxCNC and (for a user) looks very similar.
Time to create page: 0.368 seconds
