LinuxCNC Terminated With an Error!
- cryates2
22 Aug 2018 13:11 #116453
by cryates2
LinuxCNC Terminated With an Error! was created by cryates2
This machine is at my school and worked at the end of last year, however when I try to start the program now it crashes like this.
It's a Probotix Nebula if it matters
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.0
Machine configuration directory is '/home/probotix/linuxcnc/configs/Probotix_2015'
Machine configuration file is 'Nebula_2015.ini'
INIFILE=/home/probotix/linuxcnc/configs/Probotix_2015/Nebula_2015.ini
PARAMETER_FILE=emc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Killing task linuxcncsvr, PID=1987
Cleanup done
Debug file information:
inifile: warning: File contains DOS-style line endings.
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
Unrecognized line skipped: POC FMS LEN DIAM COMMENT
Probotix.hal:4: Warning: File contains DOS-style line endings.
No input devices could be opened. This usually indicates a misconfigured
system. Please read the section 'PERMISSIONS AND UDEV' in the hal_input
manpage
Probotix.hal:15: hal_input exited without becoming ready
1987
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 271.896606] I-pipe: Domain RTAI registered.
[ 271.896618] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 271.896624] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 271.896726] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 271.896731] PIPELINE layers:
[ 271.896736] f971ce20 9ac15d93 RTAI 200
[ 271.896741] c085cb20 0 Linux 100
[ 271.939191] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 271.939720] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 271.939731] RTAI[sched]: hard timer type/freq = APIC/8312450(Hz); default timing: periodic; linear timed lists.
[ 271.939739] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1862094000 hz.
[ 271.939744] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 271.939858] RTAI[usi]: enabled.
[ 272.004202] RTAI[math]: loaded.
[ 272.122226] config string '0x378 0xd050'
[ 272.853533] RTAI[math]: unloaded.
[ 272.877026] SCHED releases registered named ALIEN RTGLBH
[ 272.940152] RTAI[malloc]: unloaded.
[ 273.039160] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 273.043080] I-pipe: Domain RTAI unregistered.
[ 273.043213] RTAI[hal]: unmounted.
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.5.0
TASK=milltask
HALUI=halui
DISPLAY=axis
Cleanup done
manpage
1987
- Thank you received: 5321
22 Aug 2018 14:14 #116454
Replied by PCW on topic LinuxCNC Terminated With an Error!
Looks like someone edited/damaged the hal/ini files on a Windows machine
I would fix the DOS line endings first or revert to a working backup hal/ini file set if you have it.
Time to create page: 0.268 seconds
