Power failure with consequence
- MTPhilipp
31 Aug 2018 15:17 #116914
by MTPhilipp
Power failure with consequence was created by MTPhilipp
Hey, guys,
I am new to the forum and the Linux CNC world. I have only been working with the Linux CNC system for a few weeks. Before, I used Mach3.
Now I have a big problem, today the RCD was triggered, in the middle of the workpiece.
After the restart of the computer, Linux CNC did not let open any more. The error message appears as in the appendix.
What can I do?
Thank you for your help
Philipp
What can I do?
Philipp
- Thank you received: 5321
31 Aug 2018 17:22 - 31 Aug 2018 17:23 #116920
Replied by PCW on topic Power failure with consequence
The cause of the troubles seems to be this error reported by LinuxCNC:
PARPORT: ERROR: linux parport 0 not found
and this reported by Linux:
lp: driver loaded but no devices found
Not sure why this would change but you might try checking your BIOS's
parallel port setup options or try using the parallel port base address in LinuxCNCs hal/ini file
instead of Linux PP 0 (that is use 0x378 instead of 0 in the parport command line)
Last edit: 31 Aug 2018 17:23 by PCW. Reason: TripeOs
- MTPhilipp
31 Aug 2018 18:01 #116922
by MTPhilipp
Replied by MTPhilipp on topic Power failure with consequence Problem solved
The parallel port on the PC motherboard did not survive the power failure.
A new PCI parallel port card has solved the problem.
Philipp
Philipp
- Thank you received: 4652
06 Sep 2018 12:08 #117147
That's very unfortunate, you wouldn't normally expect that to happen.
Glad you got it fixed.
Replied by andypugh on topic Power failure with consequence Problem solved
Time to create page: 0.705 seconds
