- Thank you received: 75
Documentation. Section 4. Z axis point 6 states:
"Select Touch Off and pick Tool Table and set the position to 0.0."
What is meant here and which window? I cannot figure it out.
Below point 7 then:
"If you have a 0.125" wide parting tool and you touch the left side off but want the right to be Z0, then enter 0.125" in the touch off window"
OT-CNC wrote: The touch off button is next to the home button. For the selected axis you can enter a value that gets stored in the tool table.
This is where you can enter your 1.5mm difference.
