- Thank you received: 75
I try again. Now I see cross hair G43 on the screen but now everything have moved with it, including the 0,0 point and when I do the
G00 X0 Z0
The tool goes to 1.5mm from the cross hair G54 zero and the tool centre shows yet again OUTSIDE the shown 0,0 and all the machine path have moved too so I have nothing really achieved.
Either I still do not understand this or it is not working as expected?
I think you are still confusing homing with part zero or work offset (G54). Homing is done so the machine knows where it's 0,0 is when you 1st power up. I assume you don't have home switches on your machine? If so I would add them and configure your ini to reflect the overall travel so linuxcnc knows the soft limits of travel. This way when you power up, the machine always homes to the same place and establishes it's reference. It sound to me you always have a different home when referencing to your stock? You need a repeatable reference which are home switches.I use a feeler gauge to keep the tool 0.1mm away from the workpiece. I thus home the X and Z axis respectively.
OT-CNC wrote: I'm sorry you are still having trouble with this. If your part zero is the front of the stock, you should be able to face it then enter Z0 for that loaded tool in G54. Your program also has to reflect G54 with Z0 from the faced stock. Your program should have a positive Z retract position to start so you don't crash into the stock. I always do a dry run either with Z0 away from the part or remove the material from the chuck to prove out the program. Sometime I run it in plastic first if I'm not 100% confident. What are you using to generate the G code?
