Homing to sides of workpiece with real tool How? Lathe
  • verticalperformance
  • verticalperformance's Avatar
  • Senior Member
  • Senior Member
25 Dec 2018 01:00 #122852 by verticalperformance
Replied by verticalperformance on topic Homing to sides of workpiece with real tool How? Lathe
Two things I can think of. Tool length offsets are coming into play somehow. Do a T0 M6 first to make sure that the tool table is not affecting the touch off is some way. Then repeat your test , ensuring that you do a touch off on Z, not a tool touch off (sorry can't remember exactly wording). See if you get the same result as before (is dial gauge dose not report z=0). If so, perhaps the Z-axis scale is incorrect, or Linux CNC thinks it is moving 5inch, but the hardware is actually moving more/less than 5 inch?
25 Dec 2018 09:09 #122864 by andypugh
I touched off at a point for Z and entered -7.33. It was verified with the dial gauge.
I then went to 0 with g01 z0.
dial gauge read -0,120.
What did the DRO say after the touch-off and the move?
Did you touch-off the tool or the coordinate system?
Is your machine set up for touch-off to workpiece or touch-off to fixture?
25 Dec 2018 20:21 #122888 by berntd
Hello
Thanjs again for the great help.
"Touch off" I have not used tool touch recently off as that also makes no sense.
The screen DRO is set for relative. I am not sure what that means and relative to what. I can't find a description in the manual.
I think after the move, it reads 0.000 for Z. I need to re-test it again as I now already forgot the finer details.
29 Dec 2018 14:41 - 29 Dec 2018 14:42 #123077 by andypugh
"Relative" means G54 etc coordinates. "Machine" or "Absolute" means the actual physical axis position. Or at least it does if you have home sensors and correctly set-up axis limits.
If you can home anywhere then neither necessarily means anything.
Last edit: 29 Dec 2018 14:42 by andypugh.
29 Dec 2018 18:58 #123110 by tecno
berndt
Why not take the easy way out and install home switches?
Time to create page: 0.652 seconds
