Can linuxcnc work without using the GUI?
04 Sep 2018 05:03 #117042 by myz
I want to know, can linuxcnc work without using the GUI?
04 Sep 2018 09:09 #117045 by mungkie
Replied by mungkie on topic Can linuxcnc work without using the GUI?
yes
07 Sep 2018 15:23 #117189 by andypugh
Replied by andypugh on topic Can linuxcnc work without using the GUI?
Yes, but it can be awkward to make anything happen.
If you change DISPLAY from "Axis" to "halui" you can do it very simply.
But you will note that it isn't easy to do very much.
(everything can be done from the command line, but it's awkward)
07 Sep 2018 17:47 #117202 by cmorley
Replied by cmorley on topic Can linuxcnc work without using the GUI?
there is also linuxcncrsh
linuxcnc.org/docs/2.7/html/man/man1/linuxcncrsh.1.html
Chris M
Time to create page: 0.093 seconds
