difference between 2.7 and 2.8pre with mpg
- Clive S
- Thank you received: 486
10 Sep 2018 10:21 #117285
by Clive S
difference between 2.7 and 2.8pre with mpg was created by Clive S
The code below works in Lcnc V. 2.7.14 but I can't seem to get it working in 2.8pre.
I see in halmeter all the relevant pins changing state. ie encoder.2---- counts, phase-A, velocity etc.. but it does not jog with the mpg in Z
I have noticed that the pin axis.z.pos-cmd changes with the keyboard jog key but not with the mpg. What I am missing?
# MPG stuff here
#### load ilowpass for mpg smoothing ###
loadrt ilowpass names=ilowpass.mpgX,ilowpass.mpgY,ilowpass.mpgZ
addf ilowpass.mpgZ servo-thread
setp ilowpass.mpgZ.scale 1
setp ilowpass.mpgZ.gain 0.1
setp axis.2.jog-vel-mode 1
#set axis to the required increment ( 0.01)
net jog-inc-z axis.2.jog-scale
sets jog-inc-z 0.01
#encoder Z
net mpg-za encoder.2.phase-A <= hm2_7i92.0.gpio.032.in
net mpg-zb encoder.2.phase-B <= hm2_7i92.0.gpio.033.in
# send mpg-encoder counts to required axis
# Z encoder
net pend-counts-z axis.2.jog-counts
net pend-counts-z ilowpass.mpgZ.in
net encoder-count-z ilowpass.mpgZ.out
net pend-counts-z encoder.2.counts
# MPG stuff here
sets jog-inc-z 0.01
#encoder Z
# Z encoder
- Thank you received: 5321
10 Sep 2018 13:26 #117288
Replied by PCW on topic difference between 2.7 and 2.8pre with mpg
One missing thing is axis.z.jog-enable
also at least according to my motion man page:
should be
net pend-counts-z axis.Z.jog-counts
Also the low pass filter is bypassed, not sure if that's just for debugging
should be
- Clive S
10 Sep 2018 16:05 #117295
by Clive S
#encoder Z
net mpg-za encoder.2.phase-A <= hm2_7i92.0.gpio.025.in
net mpg-zb encoder.2.phase-B <= hm2_7i92.0.gpio.026.in
# Z encoder
#net encoder-count-z ilowpass.mpgZ.out
net pend-z ilowpass.mpgZ.out
net pend-z axis.z.jog-counts
setp axis.z.jog-enable true
I see all the above pins and signals change in halmeter but not reflected in the DRO Z (no movement)
I can't see where I am going wrong. I have cut the ilowpass out for now
Replied by Clive S on topic difference between 2.7 and 2.8pre with mpg
Thanks for the help yet again Peter:One missing thing is axis.z.jog-enable
should be
#encoder Z
# Z encoder
10 Sep 2018 16:30 #117297
Has the system been homed when you are trying to jog?
- Clive S
10 Sep 2018 16:49 #117299
by Clive S
Thanks that was it. What fooled me was that it would jog with the keyboard so I expected it to do the same with the mpg.
Now I just need to sort the ilowpass out.
10 Sep 2018 17:06 #117300
Yes 2.8 is in joint mode before homing (the GUI must know this so jogs via the joint pins with the KB)
- Clive S
10 Sep 2018 17:55 #117304
by Clive S
Yes I should have known. If you have the time could you look over the ilowpass for me.
- Thank you received: 4652
11 Sep 2018 14:40 #117337
Replied by andypugh on topic difference between 2.7 and 2.8pre with mpg
In 2.8 you probably want to connect the mpg to both
axis.L.jog-counts
_and_
joint.N.jog-counts
axis.L.jog-counts
_and_
joint.N.jog-counts
- Clive S
11 Sep 2018 15:26 #117347
by Clive S
# x encoder
net pend-counts-x encoder.0.counts
net pend-counts-x ilowpass.mpgX.in
net pend-x ilowpass.mpgX.out
net pend-x axis.x.jog-counts
net pend-x joint.x.jog-counts
setp axis.x.jog-enable true
It appears to work as is on the bench . Do you mean like this:-In 2.8 you probably want to connect the mpg to both
axis.L.jog-counts
_and_
joint.N.jog-counts
# x encoder
12 Sep 2018 13:13 #117393
You need both if you want to be able to jog before homing.
Time to create page: 0.158 seconds
