WSC_6 retrofit Tool Changer turret
18 Sep 2018 12:20 #117709 by dextaca
WSC_6 retrofit Tool Changer turret was created by dextaca
Gents last part of the puzzle.
have a turret to fix. Have Index frw, Index Rew index Pin Out and 3000 pulse encoder on the main shaft of the turret .
Any pointers on how or where should I start to get this thing going.. Forgot it's 10 position.
Peter
18 Sep 2018 12:48 #117713 by andypugh
Replied by andypugh on topic WSC_6 retrofit Tool Changer turret
Can you explain the index pins?
A 3000 pulse encoder might suggest that the turret would be easiest to control as an Axis.
Many toolchangers can be controlled by the "carousel" component, but that rather expects a per-tool position feedback, not 3000 counts.
18 Sep 2018 12:58 #117715 by dextaca
Replied by dextaca on topic WSC_6 retrofit Tool Changer turret
hi Andy nice to hear from you.. yes the Index Pin out lifts the whole turret from the lock pins and is ready to be rotated ccw or cw.. That's where the index frw or rev are..Here is a youtube of the changes
i have another question for you if you don;t mind.. trying to set up spindle feedback with 3000p/r encoder and motenc card... not too much luck in there.. any ideas?
Thank you
19 Sep 2018 13:35 #117746 by andypugh
Is the encoder the only feedback, or are there extra outputs to indicate absolute position?
Thank you
I have never used a Motenc card. But what pins do you see in HAL when the driver is loaded?
It looks like there should be specific encoder outputs, do you see these count?
linuxcnc.org/docs/2.7/html/drivers/motenc.html
19 Sep 2018 13:59 #117747 by dextaca
Hi Andy
the system is up and running , finally got the spinkdle sync as well.. The index change, not really sure even where to start.. any pointers.. Motenc drivers are loading fine.. not bad for a card.. (
19 Sep 2018 14:51 #117748 by andypugh
Can you list the pins (including direction) that are associated with the tool changer?
20 Sep 2018 22:15 #117831 by dextaca
tell you the truth didn;t get that far.. will try to get something over the weekend and will post is ASAP.
24 Sep 2018 12:51 #117913 by dextaca
Andy , over the weekend went over the different setups and realised that I'm going into the deep end of the pool without flippers. think the carrousel basic is way to go. Wondering if you could point me to some sources / docs . One thing is certain is that the index turret will need to be homed everytime Linuxcnc starts.. The original equipment had battery backup and dedicated card jsut for the toolchanger.
24 Sep 2018 13:10 - 24 Sep 2018 13:12 #117916 by andypugh
There is an example config here:
github.com/LinuxCNC/linuxcnc/tree/master...smach/VMC_toolchange
It is for a mill, but the logic is very similar.
toolchange_index.hal contains the code that loads and connects the carousel HAL component to some G-code IO pins (motion.digital-in / out)
For some reason that I have forgotten this config sends the required tool position out of a G-code analogue output rather than using the iocontrol.0.tool-prep-pocket pins.
The github.com/LinuxCNC/linuxcnc/blob/master...toolchange.ngcactual tool change sequence is handled in G-code. It checks inputs and sets outputs to ensure that things happen in the right sequence.
github.com/LinuxCNC/linuxcnc/blob/master...mc_index.ini#L21This line in the INI file remaps the M6 tool-change command to call the G-code sequence.
To make the remap work you need the toplevel.py and remap.py files. You can use those exactly as-is.
You will have this config on your LinuxCNC installation. It has a Vismach model of the machine, so you can play around with it.
sim->axis->Vismach->VMC_Toolchange in the config picker. It won't attempt to control hardware, you can use it safely on your real machine, or on any other machine.
Last edit: 24 Sep 2018 13:12 by andypugh.
Time to create page: 0.103 seconds
