Parameter number out of range
- Grotius
- Thank you received: 2349
30 Sep 2018 16:55 - 30 Sep 2018 17:15 #118239
by Grotius
Replied by Grotius on topic Parameter number out of range
Hi Mr CS Kilian,
In line 128 :
Z10.
Just remove the dot .
Line 110 same issue. So check your code good !!
It looks like you use H codes outside of G43 :
G43 H1 (set tool offsets using the values from tool 1 in the tool table)
Good luck !!
In line 128 :
Z10.
Good luck !!
Last edit: 30 Sep 2018 17:15 by Grotius.
- MaHa
- Thank you received: 241
30 Sep 2018 21:47 - 01 Oct 2018 07:27 #118244
by MaHa
Replied by MaHa on topic Parameter number out of range
I made your routine running, didn't test the grooves. But that's the easy part for you. I kicked out G41 cutter compensation, used #5410, diameter of current active tool. Now diameter registered in the tooltable is used: T2 and T3 . #<_fingerbit_dia_mm>=20
#<_ball_end_dia_mm>=12 are commented. I made some changes in your code, so you need to test, if the coordinates are ok. At least it is running now, ready for you to finish.
Edit
It was a bit late yesterday, following changes needed in the file:
(The entry for tooldiameter must match in the tooltable and the parameter)
uncomment:
replace #5410 by #<_ball_end_dia_mm>:
#<_groove_start_right_x>=#<_right_mm_to_basin_centre>+[#<_sink_hole_mm_lr>-[2*#<_required_oh_mm>/2]-[#<_ball_end_dia_mm>/2]]
#<_groove_move_right_x>=[#<_grooves_length_mm>+[#<_ball_end_dia_mm>/2]]
#<_groove_start_left_x>=#<_right_mm_to_basin_centre>-[#<_sink_hole_mm_lr>-[2*#<_required_oh_mm>/2]+[#<_ball_end_dia_mm>/2]]
#<_groove_move_left_x>=[-#<_grooves_length_mm>-[#<_ball_end_dia_mm>/2]]
Edit
uncomment:
Last edit: 01 Oct 2018 07:27 by MaHa.
- curtkilian@gmail.com
01 Oct 2018 14:50 #118287
by curtkilian@gmail.com
Replied by curtkilian@gmail.com on topic Parameter number out of range
Thanks for you effort to assist!
Please confirm that the program which you have attached is the one that you got running? I have copied it as is and opened the file but got error message "Radius to end of arc differs from radius to start....." near line 82.
As you said, if I can get the routine to tun I will be able to finish it and check coordinates.
01 Oct 2018 14:52 #118288
meant to say "get the routine to RUN...."
- Thank you received: 7488
01 Oct 2018 19:44 #118314
That will happen if you have a radius that does not have a start point, or use to big of a tool diameter for the radius to be cut, or you have some type of tool compensation active.
Replied by tommylight on topic Parameter number out of range
02 Oct 2018 09:00 #118336
Thanks, I will check that out.
03 Oct 2018 15:53 #118414
Thanks for the G code changes. After a bit of tweaking the simulation follows the paths perfectly on the XY axis.
Only 2 small problems:
1. I have commented out the M0 pauses but it still pauses between some of the G90 and G91 instructions? Unless I click twice on the "Execute next line "T" arrow button, then it continues to the next instruction without pausing.
See code below:
G91 G1 Y#<_left_bf_move> (Incremental Mode)
(M0 Temporary Position Check)
G90 G3 X[#<_left_rad_x>] Y[#<_front_rad_y>-#<_cut_radius>+[#<_fingerbit_dia_mm>/2]] I[#<_cut_radius>-[#<_fingerbit_dia_mm>/2]] J0
G91 G1 X#<_front_lr_move> (Incremental Mode)
G90 G3 X[#<_right_rad_x>+#<_cut_radius>-[#<_fingerbit_dia_mm>/2]] Y[#<_front_rad_y>] I0. J[#<_cut_radius>-[#<_fingerbit_dia_mm>/2]]
G91 G1 Y#<_right_fb_move> (Incremental Mode)
G90 G3 X[#<_right_rad_x>] Y[#<_back_rad_y>+#<_cut_radius>-[#<_fingerbit_dia_mm>/2]] I-[#<_cut_radius>-[#<_fingerbit_dia_mm>/2]] J0.
G91 G1 X-#<_back_final_move> (Incremental Mode)
This also happens between the milling of each groove? see code below:
#<_i>=1
o<cutgrooveone_r> sub
#<_i>=[#<_i>+1]
G0 Z3.
G1 Z#<_groove_start_z> F60. (Start Depth)
G91 X#<_groove_move_right_x> Z0.
G90 G54 G0 Z5.
o115 IF [#<_i> LE #<_qty_of_right_grooves>]
G91 X[-#<_groove_move_right_x>] Y#<_grooves_spacing_right_y>
o115 ENDIF
o<cutgrooveone_r> endsub
2. When a tool change is done, machine first moves back to HOME before moving to the work start position?
G53 G0 Z0. Y#<_tool_change_position_y>
(DRILL START HOLE)
T1 M6 (msg, Fit Core drill with 20mm dia and 118mm Height. M6 Tool Change Pause. Then start cycle)
G0 X#<_right_mm_to_basin_centre> Y#<_start_point_y>
See code below:
#<_i>=1
#<_i>=[#<_i>+1]
G0 Z3.
G90 G54 G0 Z5.
o115 ENDIF
(DRILL START HOLE)
- MaHa
03 Oct 2018 18:01 #118418
by MaHa
Overview of the changes done so far.
Change in the most recent file #<_tool_change_position_y>=-500, if required, and take a look at Toolchange_position in your .ini file, or use G30 G30.1.
The following user(s) said Thank You: curtkilian@gmail.com
05 Oct 2018 04:55 #118455
Thanks! this is now resolved .
Time to create page: 0.246 seconds
