UBM1 mill with LinuxCNC
28 Sep 2018 16:23 #118126 by mane
UBM1 mill with LinuxCNC was created by mane
I´m new on LinuxCNC forum and want to retrofit my UBM1 mill. The mill is already CNC.
Machine has to be programmed directly on the machine, which is not very easy to handle.
The stepper motors sounds a bit loud, keyboard keys sometimes stick, CRT monitor sometimes black, and so on.
Attachment not found
Now i will change to LinuxCNC and DC servos with UHU controller boards.
These are my requirements:
- Ethernet connection
- 3 axis with step/dir
- 5 limit switch sensors (machine has these sensors on board)
- some spindle and feed override, run/resume button, ESTOP
- MPG pedant later on
Think i will not need too much IO pins at the beginning.
I saw the 7i76e but it´s about 270€ in Europe, which is too much.
Found the 7i92 could do it, but have some questions.
- Could i use the 7i92 with a simple BOB or do i need a mesa breakout card?
- Could i wire directly onto the 7i92 without BOB?
- IO expansion should be possible, if needed.
Any suggestions welcome. Thanks in advance.
29 Sep 2018 14:29 #118179 by Deckerjwd
Replied by Deckerjwd on topic UBM1 mill with LinuxCNC
why not use to parallel ports. think one would have the basic i/o covered.
if the servos feedback is only to the drive then should have plenty of io on the parallel port. you can add a second later if you need one. if your servos have feed back then definitely go with a mesa card and an interface card
30 Sep 2018 08:29 #118224 by mane
Replied by mane on topic UBM1 mill with LinuxCNC
At the moment i use one parallel port. But for future i want ethernet and no second parallel port.
The 7i92 seems to be a good alternative. But could i use it with a simple bob or wire directly? Or do i need additional mesa card, for example 7i76?
  • Moderator
  • Moderator
30 Sep 2018 10:10 #118229 by tommylight
Replied by tommylight on topic UBM1 mill with LinuxCNC
Or just one 7i96, it has a 7i92 and a 7i76 but with less I/O. And it can also be expanded later on.
01 Oct 2018 15:28 #118297 by mane
7i96 would be also an option. I thought it does not work with ether rtai or preempt.
I have Linux CNC 3.4-9-rtai-686-pae #1 SMP PREEMPT Debian 3.4.55-4linuxcnc i686 GNU/Linux
Iḿ not sure if it will work with my system.
01 Oct 2018 16:41 #118301 by PCW
Replied by PCW on topic UBM1 mill with LinuxCNC
"3.4-9-rtai-686-pae #1 SMP PREEMPT"
is a bit misleading, that's a RTAI kernel, not Preempt-RT
You need Preempt-RT kernel for a 7I96
01 Oct 2018 18:41 - 01 Oct 2018 18:45 #118306 by mane
Do i need Preempt-RT kernel for all ethernet based cards? Found an older post here.
forum.linuxcnc.org/39-pncconf/29692-can-...-7i92?start=10#63328.
In this case i need Preempt-RT anyway.
I will try this instructions to install Preempt-RT, it hopefully will work.
linuxcnc.org/docs/html/getting-started/getting-linuxcnc.html
Attached a picture from my machine.
Last edit: 01 Oct 2018 18:45 by mane. Reason: added link for installing preempt-rt
02 Oct 2018 09:10 #118338 by andypugh
Replied by andypugh on topic UBM1 mill with LinuxCNC
Just install LinuxCNC + Debian Linux using this image:
www.linuxcnc.org/testing-stretch-rtpreempt/
Note that the warnings there are likely to soon disappear, it has now been extensively tested.
02 Oct 2018 11:43 #118340 by mane
Thanks for this Information. But i will try it to see if it works. If not, i will use the Preempt-Rt iso Image.
Is it right that all mesa ethernet boards require the Preempt-RT kernel?
02 Oct 2018 12:04 #118341 by andypugh
Yes. I think this is because kernel modules (as used by RTAI drivers) do not have access to the ethernet hardware.
Time to create page: 0.367 seconds
