homing problem with a 7i92
13 Oct 2018 15:28 - 13 Oct 2018 15:51 #118742 by Clive S
homing problem with a 7i92 was created by Clive S
I can not see the wood for the trees. Version 2.8
I am not seeing what is wrong with the homing hal and ini files attached. System is a mesa 7i92 with a cheap Chinese bob and a simple db25 connector breakout (no optos) to the drives. the home switch is NC
When I try to home one of the axis (say X) the switch does not stop the axis moving.
Looking with halmeter signals min-home-x changes state and gpio pin 030 changes state when the switch is pressed.
What am I missing?
File Name: denford_20...0-13.hal
File Size:10 KB
File Name: denford_20...0-13.ini
File Size:4 KB
Edit I have also tried net min-home-x <= hm2_7i92.0.gpio.030.in_not
Last edit: 13 Oct 2018 15:51 by Clive S.
  • Moderator
  • Moderator
13 Oct 2018 15:48 #118743 by tommylight
Replied by tommylight on topic homing problem with a 7i92
That will have to do something with the naming of pins, had the same problem lately with enable, so have a look at the docs for the version you are using to check if the pin and signal names are the same, also upper case and lower case must be same.
13 Oct 2018 16:32 #118744 by PCW
Replied by PCW on topic homing problem with a 7i92
# external input signals
# --- HOME-X --- on bob pin 10
# ---setup home / limit switch signals---
net home-x => joint.0.home-sw-in
As Tom mentioned, Inconsistent signal names
The following user(s) said Thank You: tommylight, Clive S
14 Oct 2018 11:57 #118768 by Clive S
Replied by Clive S on topic homing problem with a 7i92
Big thanks to Tom and Peter for putting me on the correct track, all homing now is ok:blush:
Time to create page: 0.083 seconds
