What is the correct version for a Mesa 7i96
- Clive S
- Thank you received: 486
17 Oct 2018 22:38 #118963
by Clive S
What is the correct version for a Mesa 7i96 was created by Clive S
After using a 5i25/7i76 on my lathe and mill just changing the configs that has worked flawlessly for the past two years .
I had the opportunity to use a 7i92 using 2.8 successfully with the help of the forum.
I now want to try a 7i96 I am aware there has been a lot of changes recently. So for my next machine just 3 axis with 3 mpg's and a spindle encoder.
What is the most suitable Linuxcnc version to use?
- Thank you received: 5321
17 Oct 2018 22:45 #118964
Replied by PCW on topic What is the correct version for a Mesa 7i96
The 7I96 is fully supported by LinuxCNC 2.8
- Clive S
18 Oct 2018 09:20 - 18 Oct 2018 11:20 #118983
by Clive S
So would this be the correct version linuxcnc-stretch-uspace-amd64-r12.iso or linuxcnc-stretch-uspace-amd64-r12.iso.zsync
edit :I see on further reading that the zsync file is basically the same but with a different download method.
After the download is this the correct image from the packet manager . linux-image-4.9.0-8-rt-amd64 4.9.110-3+debu6
Replied by Clive S on topic What is the correct version for a Mesa 7i96
Last edit: 18 Oct 2018 11:20 by Clive S. Reason: added text
- Thank you received: 4652
18 Oct 2018 22:28 #119032
Replied by andypugh on topic What is the correct version for a Mesa 7i96
That's the right kernel, but v2.7.
For max 7i96 support you probably want 2.8. But that can be got via an upgrade from the buildbot:
buildbot.linuxcnc.org
And you also get the fun new bugs brought in my Multispindle.
- pmconsulting
26 Jun 2019 17:46 #137917
by pmconsulting
Replied by pmconsulting on topic What is the correct version for a Mesa 7i96
Can you tell us what the actual image file should be? Buildbot doesn't show dates, version numbers, etc. There isn't enough data on that page to know which are newer and which are older. Some might know that Precise & Wheezy represent different versions, but of what? and which one is newer? Also, even armed with those answers, it's still completely unclear what version of Linuxcnc is actually included. I have a 7i96 board and am hugely frustrated because I don't know how to check the version I currently have installed, or which one I need to switch to and how.
26 Jun 2019 18:08 #137920
If you started with the Debian Stretch ISO then you should download the Stretch version of master
- BigJohnT
- Thank you received: 994
26 Jun 2019 22:00 - 26 Jun 2019 22:03 #137931
by BigJohnT
Replied by BigJohnT on topic What is the correct version for a Mesa 7i96
Depending on the OS your using you can see instructions for getting 2.8 from buildbot on my web page for Uspace.
gnipsel.com/linuxcnc/uspace/
I have a 7i96 configuration tool here
jethornton.github.io/7i96/
JT
JT
Last edit: 26 Jun 2019 22:03 by BigJohnT.
The following user(s) said Thank You: TheFabricatorAG
Time to create page: 0.174 seconds
