Tweaking spindle speed and spindle at speed PWM
8 years 2 weeks ago #118992 by sharpshooterser
With a lot of help from Andy I managed to make my BOB correlate with SPINx1 and to get the spindle working through VFD.
Now, my spindle speeds up to full speed slowly, and I wanted to insert spindle-at-speed option into HAL. I followed the instructions found online, but I get error messages, until I use a file like one attached (pc5.hal attached). And then, tool starts cutting even if the spindle isnt at full speed. I guess that hal has to be modified some more - its missing something.
Second problem - when I issue M3 command in MDI, spindle starts to turn. It also starts to turn if I use subroutines. However, if I start a saved gcode, with M3 Sxxxx command, spindle stays still (example ngc attached). I guess that is something simple, I just fail to see it.
Third problem, fine tuning the pwm. My spindle motor is capable of 2715 rpm. Pulley is calculated to correspond to max 2500 rpm. However I enter those values in hal, I cant get over 2000 rpm. Also, If I issue S500 I get 500 rpm. If I issue s1000 I get 1100 rpm. S1500 I get 1800 (and that is about max). Can I do something to get those values a bit closer (setting up a 25% near margin seems a bit much?).
pc5-old.hal is the first setup that gave sign of life for controls.
Any advice is appreciated.
8 years 2 weeks ago #119016 by sharpshooterser
also, my threading cycle isnt working. I get the readout on the spindle speed, but the tool advances to the start point and just sits there.
8 years 2 weeks ago #119019 by sharpshooterser
and here is the complete folder, including custom hal (that might interfere with proper operation)
File Name: pc5_2018-10-18.rar
File Size:6.03 KB
8 years 1 week ago #119071 by andypugh
I can't open .rar files, but the earlier HAL file has a number of issues.
There are some duplicated lines. This probably won't cause an error, but isn't right either.
The "near" component is connected to the "spindle-cmd" signal, but I don't see another "end" to that signal and the near.0.out doesn't go anywhere.
That section of the HAL probably needs to be
loadrt near addf near.0 servo-thread net spindle-cmd-rps => near.0.in1 net spindle-velocity-feedback-rps => near.0.in2 net spindle-at-speed near.0.out motion.spindle-at-speed
I see no sign of any attempt to allow forward/reverse control of the spindle.
Note that pwmgen type 0 will give no output for negative inputs, so you should be connecting the absolute version of the spindle command.
net net spindle-cmd-rpm-abs => pwmgen.0.value
Or, better, use pwmgen type 2, and connect the pwmgen.dir pin to an output pin to control the direction (and then you must _not_ use the absolute seed command)
Which IO pin is connected to the SPIN1x direction pin?
8 years 3 days ago #119585 by sharpshooterser
Thanks to Andy, my hal and ini are configured properly, and PWM is functional.
I had to change "setp lowpass.0.gain 1.000000" from 1 to 0.01 to get more clear reading of rpm, and g76 is also functional.
now, I wanted to tweak the speed given with S command to match the out speed, and I found a lincurve, so I tried to implement that into hal, but I get an error message on startup
#lincurve
loadrt lincurve personality=6
addf lincurve.0 servo-thread
setp lincurve.0.x-val 00 0
setp lincurve.0.y-val 00 0
setp lincurve.0.x-val 00 250
setp lincurve.0.y-val 00 185
setp lincurve.0.x-val 00 500
setp lincurve.0.y-val 00 460
setp lincurve.0.x-val 00 750
setp lincurve.0.y-val 00 745
setp lincurve.0.x-val 00 1000
setp lincurve.0.y-val 00 1055
setp lincurve.0.x-val 00 1500
setp lincurve.0.y-val 00 1765
net spindle-raw-motion.spindle-out => lincurve.0.in
net spindle-corrected lincurve.0.out => pwmgen.0.in
but I get error for "pwmgen.0.in pin" (input speeds are 250,500,750,1000,1500 and speeds achieved are 185,460,745,1055 and 1765)
what did I miss?
8 years 3 days ago - 8 years 3 days ago #119587 by andypugh
The pin is "pwmgen.0.value"
You already have a signal connected to that, so you will need to make a couple of changes.
Currently you have:
net spindle-cmd-rpm <= motion.spindle-speed-out ... net spindle-cmd-rpm => pwmgen.0.value
So you need to change the signal name in both places and insert the lincurve
net spindle-cmd-rpm-raw <= motion.spindle-speed-out net spindle-cmd-rpm-raw => lincurve.0.in ... net spindle-cmd-rpm-corr <= lincurve.0.out net spindle-cmd-rpm-corr => pwmgen.0.value
Last edit: 8 years 3 days ago by andypugh.
Time to create page: 0.376 seconds
