huanyang vfd modbus ok but M3 gcode not working on 2.8 master
25 Oct 2018 19:55 - 25 Oct 2018 19:55 #119405 by andypugh
It might be that the ttyS0 is in use and the dongle has been moved to ttyS1 or something. A reboot might normalise things.
Incidentally, in the configuration picker, you just needed to pick your configuration...
Last edit: 25 Oct 2018 19:55 by andypugh.
25 Oct 2018 20:12 #119408 by Mike29
rebooted multiple times and ran "ps -lt tty0" to see if there were any other processes using the tty and had none running. The tty port does work with the vfd in the debian 6 instance of linuxcnc. Thanks for the suggestion.
25 Oct 2018 20:17 #119409 by alan_3301
You might not have permissions to access it.
try ls -l /dev/ttyS0
You could try
sudo chmod 666 /dev/ttys0
but I don't think it will stay after reboot.
25 Oct 2018 20:37 #119411 by Mike29
you're correct about the permissions as it is root access only. Ill try this later today from the root user. thanks
27 Oct 2018 14:51 #119509 by Mike29
Continuing this thread, I did log in as root user and checked the tty ports and they are not being used by other processes and shown as idle. Here is the message being generated in the linuxcnc_print.text file:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
INIFILE=/home/mike/linuxcnc/configs/my-mill-25Oct18/my-mill-25Oct18.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Killing task linuxcncsvr, PID=1900
27 Oct 2018 17:20 #119511 by alan_3301
I guess copy the terminal output.. I didn't see any errors listed in what you posted.
27 Oct 2018 20:14 #119515 by Mike29
Let me say thanks for hanging in there on this and in reading the LinuxCNC documentation, as well as this output message, is it possible the "uspace" is not configured properly?
LINUXCNC - 2.7.14-41-g85b3fd171
Machine configuration directory is '/home/mike/linuxcnc/configs/my-mill-25Oct18'
Machine configuration file is 'my-mill-25Oct18.ini'
Starting LinuxCNC...
Found file(REL): ./my-mill-25Oct18.hal
Refusing to run as root without fallback UID specified
To run under a debugger with I/O, use e.g.,
sudo env RTAPI_UID=`id -u` RTAPI_FIFO_PATH=$HOME/.rtapi_fifo gdb rtapi_app
./my-mill-25Oct18.hal:4: waitpid failed /usr/bin/rtapi_app trivkins
./my-mill-25Oct18.hal:4: /usr/bin/rtapi_app exited without becoming ready
./my-mill-25Oct18.hal:4: insmod for trivkins failed, returned -1
LinuxCNC terminated with an error. You can find more information in the log:
/root/linuxcnc_debug.txt
and
/root/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
27 Oct 2018 20:54 #119518 by alan_3301
Don't try to run from the root account. We can fix the permissions of /dev/ttys0 so you can access it from the user account
28 Oct 2018 16:28 #119557 by Mike29
OK, I did change the permissions for /dev/tty and that resolved the starting LinuxCNC issue. I had one more problem with not being able to get out of E Stop. I resolved that by adding" -15-not" to the estop pin in the ini file. I'll run some g-code later today but the original problem seems to corrected. Thank you all for the help.
Time to create page: 0.127 seconds
