Slave Y-Axis on a 5axis 7i76
- mittim
- Thank you received: 5
04 Nov 2018 20:23 #119936
by mittim
Slave Y-Axis on a 5axis 7i76 was created by mittim
Hi guys
I´d like to know how it is possible to run a 5 axis machine with 2 Servos on the Y-axis.
If I do slave one axis, I do no longer have my 5th axis.
5i25+7i76
Thanks,
Tim
5i25+7i76
Thanks,
Tim
- Thank you received: 5321
04 Nov 2018 20:44 - 04 Nov 2018 20:45 #119939
Replied by PCW on topic Slave Y-Axis on a 5axis 7i76
If you need independent control of the 2 Y axis joints (say for 2 switch gantry homing)
you will need to add some additional step/dir outputs. This can be done by adding
another breakout to the second 5I25 connector, Either a 7I85S or a low cost
Ebay 5Axis breakout will work for this.
Last edit: 04 Nov 2018 20:45 by PCW.
- mittim
04 Nov 2018 20:52 #119940
by mittim
Replied by mittim on topic Slave Y-Axis on a 5axis 7i76
I don´t need them to be independent.
04 Nov 2018 21:26 #119942
If they dont need to be independent, (for 2 switch gantry homing) you can likely just parallel the step/dir signals, perhaps using the opposite polarity for direction on one axis if the joints need to turn in opposite directions
Time to create page: 0.079 seconds
