LinuxCNC+EtherCAT+Servo
05 Nov 2018 13:32 #119990 by myz
LinuxCNC+EtherCAT+Servo was created by myz
I want to build a Linuxcnc + EtherCAT + Servo demo environment, I used a master card, it provides some APIs, can send and receive ethercat datagrams. The slave is a servo driver that drives the servo motor. My initial thought was: call the datagram api of the master card in base-thread or servo-thread, read the motor-pos-cmd and pass it to the slave, and at the same time, the master reads the position feedback of the slave. Passed to motor-pos-fb, however, I have some questions:
1. Is the idea above me correct?
2. How do I configure the .hal file and the .ini file?
3. What components are needed? For example, the components in the servo_sim.hal file, in addition to the analog components, do you need the rest?
05 Nov 2018 15:43 #119997 by andypugh
Replied by andypugh on topic LinuxCNC+EtherCAT+Servo
I don't know if you have found it, but there is a big EtherCAT thread here:
forum.linuxcnc.org/24-hal-components/22346-ethercat-hal-driver
07 Nov 2018 07:42 #120154 by myz
Replied by myz on topic LinuxCNC+EtherCAT+Servo
but that is a software master,my card is a hard master
07 Nov 2018 10:47 #120161 by myz
but that is a software master,my card is a hardware master,Can they be used together
07 Nov 2018 14:07 #120167 by myz
07 Nov 2018 23:53 #120225 by cmorley
Replied by cmorley on topic LinuxCNC+EtherCAT+Servo
so you need to make a device driver for HAL.
A HAL driver needs a function to read the card and a function to write to the card and a way to decide what HAL pins to make.
Usually this is a command line way of configuration on initial loading, but there are other ways.
That in very general terms is what is required.
Chris M
The following user(s) said Thank You: myz
08 Nov 2018 09:23 #120242 by myz
I know what you mean. However, the API that receives the ethercat packet and sends the ethercat packet is in user space, so I can only create a user space component, define the pins in the component, and in the.hal file, use the 'net' command to connect the pins I defined to the system pins (for example,net target_pos <= axis.0.mortor-pos-cmd net slave_fb => axis.0.mortor-pos-fb) Then, I loop through the API to send target_pos to the slave station, then call the API to receive feedback, and assign the value to slave_fb. Is this solution feasible? I feel like there's no real time like this, but I can't find examples to refer to.Is there another way?
Time to create page: 0.087 seconds
