Backlash
- surfron
06 Nov 2018 11:51 #120098
by surfron
Backlash was created by surfron
hello,
i am wondering how the backlash compensation in linuxcnc works.
i know what backlash is, and thats better to get rid of it in hardware ...
i know how to configure it in the .ini file ...
i also know the requirement about the higher speed and accel entries for the setp generator ...
but how is it realized if for example the X-axis changes direction?
what speed and accel values are used for the compensation?
where to finde some documetation about the source code?
thanks for helping!
surfron
thanks for helping!
surfron
- Thank you received: 4652
08 Nov 2018 11:54 #120248
Replied by andypugh on topic Backlash
I had a quick look through the source-code, but couldn't actually see where it happens.
Have you looked?
Have you looked?
- surfron
08 Nov 2018 15:51 #120273
by surfron
Replied by surfron on topic Backlash
yeah, i also found the code and had a quick look through ...
it tries to use 150% of joint acceleration to compensate but have not found anything about speeds.
i have some strange behavior with very slow speeds ... it looks like compensation takes place after the move and not as soon as possible.
i will post a vid to that topic - but it will be in december - going today on vacation.
surfron
surfron
