Tip: Always sending Spindle to Z-Max
- 3D-Master
- Thank you received: 5
13 Nov 2018 00:01 #120520
by 3D-Master
Tip: Always sending Spindle to Z-Max was created by 3D-Master
Okay first off this is not a question, and i am sorry if this is inappropriate, but a tip if you wanted something like this always.
Did you know that you can send the Z axis all the way to Z max everytime with Gcode?
G53 G1 Z #<_ini[AXIS_2]MAX_LIMIT> Fxxx (this would be something similar to Heidenhain´s M140 MB MAX)
It will send your spindle always to ZMax, even if you change the Softlimits later (otherwise either the spindle may not get to Zmax or will error out saying Softlimit would be overshot) The benefit is that if you have some .ngc files with known values for z Max (for example G53 G0 Z151) or your postprocessor spits out something like that, you wont have to edit each file when you have to change your softlimit.
if there would be any disadvantage i havent thought about let me know.
just a tip
just a tip
The following user(s) said Thank You: Mike_Eitel, pommen
- Thank you received: 4652
13 Nov 2018 15:14 #120552
Replied by andypugh on topic Tip: Always sending Spindle to Z-Max
This requires G-code access to INI items to be configured on, as described here.
linuxcnc.org/docs/2.7/html/remap/remap.h...i_file_configuration
- 3D-Master
13 Nov 2018 17:28 #120582
by 3D-Master
Replied by 3D-Master on topic Tip: Always sending Spindle to Z-Max
thanks, forgot about that
Time to create page: 0.071 seconds
