update manager problem?
- fredo550@gmail.com
- Visitor
13 Nov 2018 00:28 #120521
by fredo550@gmail.com
update manager problem? was created by fredo550@gmail.com
Hi, I'm running v2.7.14 without problems. Before I got several updates per week; suddenly there are no more updates for the last month. Running update manager manually always reads 'you are up to date'
Any suggestions?
Any suggestions?
- Thank you received: 7470
13 Nov 2018 06:20 #120526
Replied by tommylight on topic update manager problem?
What version of linux ?
- Visitor
13 Nov 2018 14:00 #120544
Replied by fredo550@gmail.com on topic update manager problem?
Debian GNU/Linux 7.11 (wheezy)
13 Nov 2018 15:14 #120551
Most probably because there are 2 newer versions of Debian already.
You might want to check if that is the case.
- Visitor
13 Nov 2018 15:23 #120555
Thank you.
- Thank you received: 4652
13 Nov 2018 15:37 #120559
Replied by andypugh on topic update manager problem?
- Visitor
13 Nov 2018 15:43 #120561
Any suggestion to replace Wheezy? My pc is an old e-machines/32. Should I install Ubuntu or other distro?
- Visitor
13 Nov 2018 15:45 #120562
Off-topic: couldn't find how to change my username
13 Nov 2018 15:50 #120564
There probably isn't much harm in leaving a working machine alone.
The next version of linuxCNC (2.8) will still work on Wheezy.
The following user(s) said Thank You: fredo550@gmail.com
Time to create page: 0.121 seconds
