- LinuxCNC
- General LinuxCNC Questions
- Connecting differential Encoder phases A and B and also a 5V TTL index to 7i76
- billnixon
13 Nov 2018 13:53 #120540
by billnixon
Connecting differential Encoder phases A and B and also a 5V TTL index to 7i76 was created by billnixon
4 axis mill with 5i25 and 7i76
Our spindle motor is connected to the spindle via a belt and pulley. The spindle motor has a differential encoder and is connected to a 7i76 and the counts and velocity are working correctly. We installed a 5V hall effect sensor on the spindle pulley so we could get an index signal for coordinated moves. Can I set the encoder jumpers on the 7i76 to have phases A and B differential and the index signal be 5V? If so, which jumper is for the index signal, W4, 5, or 6?
Do I rather need to run the index signal through a gpio pin on the 7i76? It seems that the 7i76 encoder component built into the 7i76 replaces the need for a separate hal encoder component. Is that correct? I'm not sure how to route the index signal to the built-in encoder on the 7i76, if not through the encoder inputs.
I'm stumped both methods. Any help would be appreciated.
- Thank you received: 5321
13 Nov 2018 14:04 #120545
Replied by PCW on topic Connecting differential Encoder phases A and B and also a 5V TTL index to 7i76
The 7I76 encoder interface has individual mode jumpers for A,B and Index so you would just jumper A/B for differential and Index for TTL
W4 Index mode
W5 B mode
W6 A mode
W4 Index mode
W5 B mode
W6 A mode
The following user(s) said Thank You: billnixon
- billnixon
13 Nov 2018 20:41 #120613
by billnixon
Replied by billnixon on topic Connecting differential Encoder phases A and B and also a 5V TTL index to 7i76
Thank you! It worked great.
- LinuxCNC
Time to create page: 0.071 seconds
