Error after update
15 Nov 2018 15:25 #120758 by aaron
Error after update was created by aaron
Hi EMC
Please can you help. I have just updated my debian system, but now I am unable to run my CNC router. I am getting the error message below as well as the longer one attached.
'Invalid Options
Usage: update_ini [-d] [-f] filename.ini
If the -d flag is used then a dialog box will be displayed
describing the purpose of this script, and giving the user the option
to change their mind
If the -f flag is used then no questions will be
asked and the conversion will proceed blindly.'
Can someone please let me know how to deal with this problem
Thanks and regards
Aaron
15 Nov 2018 15:56 - 15 Nov 2018 16:00 #120762 by dgarrett
Replied by dgarrett on topic Error after update
Invalid Options
indicates a bug handling an inifile with blanks in the file name and/or directory name.
rename with underscore like: foam_xxyz/foam_xxyz.ini
or wait to test fix when new commit is incorporated in deb:
github.com/LinuxCNC/linuxcnc/commit/d191...872ab51766f54b6efb65
Last edit: 15 Nov 2018 16:00 by dgarrett. Reason: dirname too
