Mesa 7i76e wiring
7 years 11 months ago #120777 by Bello
Replied by Bello on topic Mesa 7i76e wiring
The supply seems good, I will try another one asap and will let you know.
What you mean for alternate flash data?
The mesa is new and I have only unpackaged and connected it, how flash data was corrupted ?
7 years 11 months ago #120778 by PCW
Replied by PCW on topic Mesa 7i76e wiring
The 7I76E has 2 flash chips and you can select between them with a jumper
(this is described in the manual)
I would not expect a corrupted flash chip but it does happen occasionally
7 years 11 months ago - 7 years 11 months ago #120780 by Bello
You mean W3 modes or you are referring to another jumper one?
Which test can i do to verify that all is OK?
When you say link lights are you referring to those ones on the ethernet port? Because really those arent lighting in a mesa and the same on the pc
Last edit: 7 years 11 months ago by Bello.
7 years 11 months ago - 7 years 11 months ago #120784 by PCW
Check page 4 of the manual under heading:
FPGA FLASH SELECT
(if the FPGA does not load you will not get any link lights)
Last edit: 7 years 11 months ago by PCW.
7 years 11 months ago #120786 by tommylight
Replied by tommylight on topic Mesa 7i76e wiring
Also for the 7i76E you need the Stretch version of linuxcnc.
Your network should be set using the network manager, there are also provisions for setting the gateway and DNS there, without them network will not work properly.
Network setting should be like so:
IP 10.10.10.2 up to 254 ( excluding 10, and never 1 )
Netmask 255.255.255.0 or /24
gateway 10.10.10.1
Dns 10.10.10.1 ( works without this line )
The following user(s) said Thank You: Bello
7 years 11 months ago - 7 years 11 months ago #120787 by Bello
@tommylights I will try with stretch also
@PCW Are you suggesting to move w9 jumper down to enable to load the backup and retry?
Which is the best way to turn off it and rollback the change if will work?
Time to create page: 0.062 seconds
