Mesa 7i76e wiring
7 years 11 months ago #120764 by Bello
Mesa 7i76e wiring was created by Bello
Hi all,
I have bought a mesa 7i76e for my machine.
I'm trying to setup it but I really not understood how to wires it.
From documentation I read that if I want use a 10.10.10.10 ip address on mesa I just move w3 jumper from down to up and I have done it.
After that I have edited the /etc/network/interfacesfile and added the following rows:
auto eth0
iface eth0 inet static
address 10.10.10.1
netmask 255.255.255.0
and restarted the network service.
Now I'm able to see my eth0 configured on the 10.10.10.1 ip.
When I try to ping the mesa I obtain:
Destination is Unreachble error message....why?
I'm using a normal ethernet cable between PC and MESA (directly without passing via any router or switch) and I have connected the board to 5v power supply. I see only the mesa led lighting....
What I wrong?
Can I directly connect the mesa with Linuxcnc PC using a normal ethernet cable or I need a crossed (or specific other) one?
Please help me!
Thank you in advance.
7 years 11 months ago - 7 years 11 months ago #120766 by PCW
Replied by PCW on topic Mesa 7i76e wiring
"Destination is Unreachable" is likely a host network setup issue
what does the command:
ip a
report?
( also the 7I76E uses a Ethernet interface with the "MDIX" feature so either crossover or straight Ethernet cables will work equally well )
Last edit: 7 years 11 months ago by PCW.
The following user(s) said Thank You: Bello
7 years 11 months ago - 7 years 11 months ago #120770 by Bello
Replied by Bello on topic Mesa 7i76e wiring
this is the output:
user@debian:~$ ip a 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 16436 qdisc noqueue state UNKNOWN link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo inet6 ::1/128 scope host valid_lft forever preferred_lft forever 2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN qlen 1000 link/ether 68:b5:99:e2:df:c7 brd ff:ff:ff:ff:ff:ff inet 10.10.10.1/24 brd 10.10.10.255 scope global eth0 3: wlan0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN qlen 1000 link/ether cc:52:af:0c:90:69 brd ff:ff:ff:ff:ff:ff inet6 fe80::ce52:afff:fe0c:9069/64 scope link valid_lft forever preferred_lft forever
and this is the ping result:
user@debian:~$ ping 10.10.10.10 PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data. From 10.10.10.1 icmp_seq=1 Destination Host Unreachable From 10.10.10.1 icmp_seq=2 Destination Host Unreachable From 10.10.10.1 icmp_seq=3 Destination Host Unreachable From 10.10.10.1 icmp_seq=4 Destination Host Unreachable From 10.10.10.1 icmp_seq=5 Destination Host Unreachable From 10.10.10.1 icmp_seq=6 Destination Host Unreachable
Last edit: 7 years 11 months ago by Bello.
7 years 11 months ago #120772 by PCW
"NO-CARRIER"
do you have link lights on the 7I76E?
7 years 11 months ago #120774 by Bello
Yes I have. CR1 lighitng in green and CR2 red.
Could depends that maybe I m using a wrong kernel ?
I read here that could depends from it but I m really confused now:
forum.linuxcnc.org/9-installing-linuxcnc...-find-module-hm2-eth
my version is:
user@debian:~$ uname -v #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
I have downloaded the image from www.linuxcnc.org/linuxcnc-2.7-wheezy.iso
I ve tried it in live mode and not, got the same issue.
7 years 11 months ago #120776 by PCW
CR1 on means that the FPGA could l not load its configuration data
So you may have a bad power supply or corrupted Flash data
I would verify that you have a good 5V supply and if that good try the alternate flash chip
Time to create page: 0.252 seconds
